  • July 06, 2025, 06:58:23 PM
Author Topic: Baby Ringmaster build for Ringathon  (Read 2584 times)
Offline Robert Whitley
« on: October 13, 2019, 06:17:59 PM »
Since we got weathered out for the Ringathon weekend, I decided to build a replica of my original baby Ringmaster from the 1970s.
Including making plans and templates, the build stretched out over about three days.  I know - pretty slow for a 1/2 A.
I did it in my original colour scheme but cheated and used monocote instead of dope and silkspan.  I did re-use the original main gear and bell crank.
Specs: 21-1/4" wingspan, 5.4 oz RTF, COX BABE BEE .049.
Looking forward to first flight and hopefully the snow stays away for awhile longer.
Re: Baby Ringmaster build for Ringathon
« Reply #1 on: October 13, 2019, 06:25:56 PM »
Pictures
« Reply #2 on: October 13, 2019, 06:26:40 PM »
more pictures
« Reply #3 on: October 13, 2019, 06:27:47 PM »
pictures again
« Reply #4 on: October 13, 2019, 06:28:33 PM »
yet again with the pictures
« Reply #5 on: October 13, 2019, 06:29:07 PM »
Last one!
Offline Larry Lindburg
« Reply #6 on: October 14, 2019, 06:04:38 AM »
Beautiful job!
AMA 95707
« Reply #7 on: October 14, 2019, 07:48:05 AM »
Thanks.
I sure had a lot of fun back then with the original and hope to repeat a bit of those good times with it.
« Reply #8 on: October 14, 2019, 07:54:33 AM »
That looks gorgeous.  Did you use a wing jig back in the day?   I know I didn't as it was a lot of pins and tape with the old Ambroid glue. H^^
« Reply #9 on: October 14, 2019, 08:54:10 AM »
As a kid in the seventies we wouldn’t have recognized a jig if it bit us.
Yep, a re-purposed door for a bench with some sort of ceiling tile board to shove pins into and usually glued with Testors since that was the most readily available brand around here.
Good carefree times.
Offline Andre Ming
« Reply #10 on: October 14, 2019, 06:07:05 PM »
Very nice! Wish I could do wingtips with Monocote as well as you can!
I'll bet your original Baby Ringmaster didn't look this good!  :)!
Andre
« Reply #11 on: October 14, 2019, 07:42:14 PM »
Thanks Andre,
Actually the original did look as good overall.
It was done in silkspan and dope with the base colours and sunbursts reversed again on the lower surfaces which looked quite sharp with the colour transition all around the leading and trailing edges of the wings and stab/elevator.
I planned that again but foolishly automatically flipped my patterns as per a normal covering application and didn’t want to waste any monocote.
I still have the original two piece metal motor mount but didn’t use it because they look so cheap and ugly.
Maybe I’ll build another with the old Golden Bee and do another dope finish.
I made a full set of ply patterns so another one would probably  only be a one day build.
« Reply #12 on: October 15, 2019, 10:01:50 AM »
Indeed I did boil it.
They’re much chewier that way.😀🤪
In case of too much propellor lawn mowing I still have about a dozen of these props to go through.
« Reply #13 on: October 15, 2019, 08:41:43 PM »
Very nice, did you boil the prop?
 Seems like I've heard of doing that before, but can't recall why?  ???
« Reply #14 on: October 15, 2019, 09:07:00 PM »
It helps relax the stiffness that older plastic props develop.
I don’t think the time they boil is any constant. I just do it until they feel somewhat more flexible and if they have a slight bend it usually straightens them.
Back when we would even do it with new props since who knew how long they were sitting on the LHS’s shelves.
« Reply #15 on: October 15, 2019, 10:34:13 PM »
Well, kind of sort of.
You might think of boiling your prop as a tempering process, except of course it's not a metal, and the analogy breaks down. What you are doing is trading strength for toughness, brittleness for flexibility. (Whereas the elastic modulus of metals is essentially independent of heat treat/temper.)  And old, bad material is just that: either bad to begin with, or now too old to be "fixed" by boiling. For example, if it has micro-cracking, boiling isn't going to make that go away. I would be particularly wary of the old Cox gray performance props. Many reports of them being extremely brittle all these years later.
Here's a pretty clear explanation from a materials scientist about moisture content vs. properties for common nylon materials. I believe it is a reputable source in the industry.
https://www.plasticstoday.com/materials/materials-analyst-part-85-fixing-brittle-nylon-product-water/141225133500
I find the long term equilibrium discussion to be most interesting. What he is saying is that you can temporarily increase the toughness (flexibility) but that if you do so, be aware that it will return to a more natural equilibrium of ~1.5% by weight of water.
