  • August 01, 2025, 07:49:31 PM
Author Topic: Baby Ringmaster  (Read 2418 times)
Offline ray copeland
Baby Ringmaster
« on: June 22, 2007, 07:13:57 PM »
Recently purchased a Baby Ringmaster on e-b*y for 12 bucks , needs recovering and some glue,  been hanging in a barn a long time. Is this a classic stunter i should take some time with and try to restore or just patch and try to fly?  What engine would best suit it, black widow , cub a or norvel or maybe .09?  Just looking for some advice from the experts. Thanks, Ray
Re: Baby Ringmaster
« Reply #1 on: June 23, 2007, 12:29:02 AM »
Hi Ray,
As to repairs, do whatever suits you. y1  Just try to not add any weight!
I would use the Black Widow, but the others would fly it.  The .09 would be a bit much, though!
Offline Peter Hess
Re: Baby Ringmaster
« Reply #2 on: June 23, 2007, 03:31:37 PM »
Ray:
I have not flown my Baby Ringmaster for a few years, but when it was in operation in flew very well on 42' .008 cables with a Black Widow.  When I first flew it I tried it on 35' lines, but, even though I had increased the wing span by about 4" with modified wing tips, the lap times were far too fast to be enjoyable.  It was capable of doing a whole lot more than I could.  I'm sure that you will enjoy the little beastie.
Peter Hess
Canton, CT
Peter Hess
Canton, CT
AMA 485070
Offline Robert McHam
Re: Baby Ringmaster
« Reply #3 on: June 23, 2007, 06:28:50 PM »
If the lap times are too fast a sure cure would be to put a prop of the same diameter with less pitch. This would slow things down some yet not sacrifice the motor's power.
Should that prove not quite slow enough, stick a prop with one size larger diameter and one less pitch number and you, should be good to go!
Robert
Offline Richard Grogan
Re: Baby Ringmaster
« Reply #4 on: June 25, 2007, 04:51:54 PM »
Robert
Or just put the prop on backwards... it works!
Long Live the CL Crowd!
                  AMA 85745
Re: Baby Ringmaster
« Reply #5 on: June 25, 2007, 10:09:56 PM »
Yes, it does!  I did it in the past many times.
