  • July 11, 2025, 09:20:54 PM
Author Topic: Baby Clown Engine Choice  (Read 1576 times)
Offline Joe Rice
« on: March 10, 2010, 03:07:22 PM »
...Should I use the new plastic tank Black Widow, or the "real" Golden Bee on my Baby Clown HB~>  Started life as a Brodak ARC, but uses the more classic 'Jumpin Bean style nose.
Joe
Hon...another one of your airplane thingy boxes showed up at the font door today mw~
Joe Rice
AMA 740106
Offline fred krueger
Re: Baby Clown Engine Choice
« Reply #1 on: March 11, 2010, 08:13:56 AM »
I've had one with a tankless Golden Bee (used a product engine style plastic backplate) and one with a Norvell.  The 2nd one is faster, but they both flew well.  The Baby Clown is a great flying 1/2A.  Get the CG set and have a ball!   ;D
Fred
Offline Larry Lindburg
« Reply #2 on: March 11, 2010, 08:27:06 AM »
Hi Joe,   Try both engines and have fun.  Then save the faster engine for your lil Skyray so you can race with us this fall.
AMA 95707
Offline Joe Rice
« Reply #3 on: March 11, 2010, 09:01:55 AM »
Larry...thanks for the reminder on the Fall Lil Skyray races. H^^  I need to get some wood cut for the Lil Ray and squeeze the build in between the larger projects y1
Joe
Joe Rice
AMA 740106
« Reply #4 on: March 11, 2010, 09:41:31 AM »
My procedure is to prepare all the reed valve engines I have and bench run them with a tach.  Put the best one on the plane and put the second & third place units in a Ziplock bag for when Number 1 screws up.  All the rest go back to the chop for another round.
Offline Robert McHam
« Reply #5 on: March 11, 2010, 09:48:29 AM »
Joe, with both engines being identical in size, shape, weight and mounting makes it very easy to interchange them at the field in a few minutes, so which one should not be a large issue.
As to which first, I suggest the single port Golden Bee to start with.
Paul has good advice. Better to run them both before you get to the field.
Here's to your maiden flight!
Robert
Offline Joe Rice
« Reply #6 on: March 11, 2010, 11:08:47 AM »
Paul...Robert, thanks for the insight.  I have never run these engines, so need to get that done.  On fuel... the only high nitro fuel I have is S&W 25% that I run in a YS140 RC plane.  it is 20% oil content,  50/50 Klotz/castor.  Do I need top add some extra castor for the Cox engines?
Joe
Joe Rice
AMA 740106
Offline George
  • Love people, Use things.
« Reply #7 on: March 11, 2010, 09:57:43 PM »
Joe
That fuel mix should work fine. IMHO the Golden Bee should work better because it has the stunt vented tank, and the small Baby Clown should not need more power. Good luck whichever way you go.
George
George Bain
AMA 23454
