  • June 29, 2025, 01:32:59 PM
Author Topic: Baby Clown Electric  (Read 1386 times)
Offline Jim Moffatt
Baby Clown Electric
« on: September 05, 2009, 02:11:53 PM »
Here is my Electric Baby Clown. It is a stock Brodak ARF with the following modifications; fabricated balsa/ply motor mount, increased wheel size to clear an 8" prop, installed horizontal stab in line with wing for equal up and down elevator authority, cut pocket in wing to match the battery and provide correct CG. It is flying well on 40' . Lap times are typically 3.5 sec with a governor.
Because I can't do 3.5 sec lap times due to dizzyness I fly it RC style around a pylon (Weighted Camera tripod). That is why it has an RC receiver and elevator servo.
« Last Edit: September 05, 2009, 03:12:38 PM by Jim Moffatt »
Offline John Castle
  • The Bent Pin
Re: Baby Clown Electric
« Reply #1 on: September 05, 2009, 02:45:20 PM »
OK I'll bite...You have a servo operated elevator. How and why ??? ??? ???
John Castle
McMinnville, Oregon
AMA# 589650
Offline Jim Moffatt
« Reply #2 on: September 05, 2009, 03:10:22 PM »
I get too dizzy for anything leass than baout 5 sec lap time so i fly it RC style around a pylon (weighted camera tripod). If I didnt get dizzy I would use a handle.
(I added this info to the original post)
Offline minnesotamodeler
  • Me and my Chief Engineer
    • Minnesotamodeler
« Reply #3 on: September 05, 2009, 03:50:51 PM »
Longer lines, Jim, longer lines...I'm using 48' with a Norvel .061.  Try even as long as 52'.
I don't get how you're RC-flying it around a pylon with the rudder offset the way it is...unless you're going clockwise?
--Ray
AMA902472
Offline Larry Renger
« Reply #4 on: September 05, 2009, 04:31:21 PM »
I think he has it tethered to the pylon, and flies it from outside the circle with the radio link to the elevator.  A more modern way to do what some have done with hideous mechanical linkages.
Offline John Castle
  • The Bent Pin
« Reply #5 on: September 05, 2009, 05:10:33 PM »
That's very interesting. Do you have any photos of the tripod setup and other setup tips? I think that my elderly father might enjoy participating like that.
John Castle
McMinnville, Oregon
AMA# 589650
Offline Jim Moffatt
« Reply #6 on: September 05, 2009, 06:13:14 PM »
Here is a video that shows another plane setup with my tripod.
Click the image to play the video.
For the Baby Clown I use a 40' line of 20 lb test monofilament. My current power setup which flies the 3.5 sec laps consists of
1. A BP Hobbies 2217-9 outrunner with 950 kv
2. A 20 amp ESC with governor.
3. A hyperion 3S 850 mah battery
4. Either an APC 8x8 prop or 8x6 prop.
I found a minimum of 40' is required for the Baby Clown to have sufficient "airspace" for stunts.
To get good line tension on overhead 8s I need the 3.5 sec lap time. To get this performance the battery power is about 100 watts. I am still experimenting to optimize the motor and prop combination but this setup is entirely satisfactory and is probably what I will stay with. The weight on the tripod to keep it from being pulled over is 15 lb.
    • Minnesotamodeler
« Reply #7 on: September 05, 2009, 08:41:09 PM »
OK thanks, I get it now, very clever.
Yeah Larry, I remember the mechanical setups that were supposed to accomplish the same thing; sit beside the circle with a joystick, hooked with lines along the ground to a bellcrank-like gizmo on the pivot that in turn worked the 2-line system...or something like that.   I believe your word "hideous" adequately describes it.
 I think the RC way is better!
--Ray
AMA902472
« Reply #8 on: September 06, 2009, 07:56:55 AM »
Yeah, a young guy by the name of Bob Underwood designed a plane and had it published that could be control line, tethered with the radio for the throttle and elevator.  Then the same plane could be flown strictly RC.  Can't remember the name of the plane.  He was District VI VP for years before moving to headquarters.  He was the one I went to to get control line mentioned in his articles as Swope Park was in his district.  I live in district IX and could nothing out of our VP.  Having fun,  DOC Holliday
Offline Jeffrey Olijar
« Reply #9 on: September 09, 2009, 09:11:18 PM »
you should hook a bellcrank to your transmitter with a short length of lines and a handle to get a more true effect.  ;D
If it ain't broke, fix it till it is.
