  • June 26, 2025, 01:53:14 AM
Author Topic: edle valve spring  (Read 1926 times)
Offline Bootlegger
edle valve spring
« on: September 25, 2016, 07:26:52 AM »
   Guy's I need a needle valve spring for a Cox Medallion .049 engine. Where can I get one?   Thanks
8th Air Force Veteran
Gil Causey
AMA# 6964
Re: edle valve spring
« Reply #1 on: September 25, 2016, 10:43:32 AM »
A length of silicone fuel tubing works well for me.  Pick a diameter (medium) and length (around 1/2 inch) so that it's compressed a bit at the right setting, but not riding over the shoulder on the needle valve.
Or, Cox International.
Edit: I only just now noticed that yours is a Medallion, not a reedie.  The fuel tube should still work but I don't have personal experience with that one.  If not, Cox International has needle stuff for Medallions, too.
« Last Edit: September 25, 2016, 11:48:59 AM by Tim Wescott »
Offline Fredvon4
  • Central Texas
« Reply #2 on: September 25, 2016, 11:12:30 AM »
What Tim said I my method also... if you find the Needle step is to small a diameter and is sliding into the fuel line, use a small #2 washer it fits over the threads but wont pass the first step before the knob
Trick is finding the running needle setting and then cut the fuel line just barely a tad longer but not too much
seals out air, stops vibration changes of the needle
Fred von Gortler IV
Offline david beazley
« Reply #3 on: September 25, 2016, 05:28:00 PM »
How about a spring out of a ball point pen?
AMA # 2817
« Reply #4 on: September 25, 2016, 06:02:53 PM »
They're too wimpy.  If anything, fuel tubing works better than stock if you're willing to fuss with it a bit.
