  • July 07, 2025, 08:01:55 AM
Author Topic: Another Mid-70’s engine question.  (Read 1692 times)
« on: September 25, 2020, 09:44:01 AM »
I was just reading the Gremlin 1/2A pattern plane article in the May ’75 issue of Model Builder by Tom Dixon, and it says the plane flies on a Cox “stunt special” engine.  The “stunt special” is a TD .049 with a Babe Bee piston/cylinder and a low compression glow head, a Kirn-Kraft NVA, and turning a Cox 6x4 prop on 5% nitro fuel from a Perfect wedge tank.  Tom says this pulls the 12 ounce model through the entire stunt pattern.  The KK fine needle would be the only thing I would have associated with “performance”.  A low compression head topping a single bypass/no boost cylinder with SPI doesn’t scream “performance”.  5% nitro on a 1/2A doesn’t scream “performance”.  A TD on suction from a standard plumbed wedge tank doesn’t scream performance.  And a Cox 6x4 doesn’t scream “performance” (unless you’re propping for torque).  And we all know Cox TD engines were made to scream.
What exactly am I missing on this?
Online Larry Renger
Re: Another Mid-70’s engine question.
« Reply #1 on: September 25, 2020, 10:01:52 AM »
Sound all wrong to me! I went the other way with a Medallion bottom end and Tee Dee top. 15% Nitro. Great runs!
Offline John Given
« Reply #2 on: September 25, 2020, 02:05:04 PM »
This is what I’d do.
Offline 944_Jim
« Reply #3 on: September 26, 2020, 08:02:46 AM »
Oh, why did I see this? This plane is cute.  Now I want to build one! For all the concern about tail weight, I wonder how it would be scaled up about 5-8%, and flying a Norvel Big Mig .061.
Thanks for the tease.
Online Larry Renger
« Reply #4 on: September 28, 2020, 08:20:45 PM »
Go with it as is and just fly on longer lines. You’l love it.
« Reply #5 on: September 28, 2020, 08:24:59 PM »
  Indeed, your method sounds a lot more plausible, the last things you want is to lower the compression or run the TD intake system
Online Larry Renger
« Reply #6 on: September 28, 2020, 08:33:10 PM »
Nothing wrong with the Tee Dee in take system, it is the wild Tee Dee crank timing! A Tee Dee with a Medallion crank shoUld run just fine as a stunt engine, it is just easier to grab the entire Medallion bottom end. (Especially if you work in the factory 🤭)
