  • August 01, 2025, 08:23:57 PM
Author Topic: alternative fuel tank  (Read 3331 times)
Offline John KruziK
« on: March 26, 2008, 08:01:44 PM »
I remember reading or seeing a 35mm film case used as a tank. It would fit perfect in available space. Thanks John
AMA 874027
Offline minnesotamodeler
  • Me and my Chief Engineer
    • Minnesotamodeler
Re: alternative fuel tank
« Reply #1 on: March 27, 2008, 04:05:32 AM »
Well lessee what kind of pics I have on hand.  I use the film canisters as tanks themselves, and as containers for floppy balloons and pressure bladders.
I use 1/16" alum. tubing through punched (not drilled) holes, glued in with GOOP. Roughen up the plastic first with sandpaper.  Well cured, GOOP seems pretty fuelproof.
You can get 1 oz. of fuel in a canister, or 3/4 oz. in a balloon inside one.  When I need more (thirsty .061) I put two together with GOOP.
--Ray
--Ray
AMA902472
Offline LARRY RICE
« Reply #2 on: March 27, 2008, 07:22:25 AM »
WOW!
        That is some tank, Ray. I am impressed. In the Musciano log models a simple balloon works well too. A piece of fuel line (the clear hard stuff works best) inserted half way into the balloon with a rubberband wrapped around the neck to seal the balloon to the fuel line; ala Carl Goldberg.  H^^
Larry
    • Minnesotamodeler
« Reply #3 on: March 27, 2008, 09:10:28 AM »
Actually 3 different tanks, Larry.
Yup, I do pretty much the same thing with the balloons...I cut a couple of notches close to the end of the fuel line, so the balloon can't accidently seal it off; and use wire ties (bread loaf?) instead of rubber bands. These simple tanks work a whole better than they have any right to. I'm always having to show the skeptics!
--Ray
--Ray
AMA902472
Offline LARRY RICE
« Reply #4 on: March 27, 2008, 01:09:35 PM »
I made a mistake in giving Carl Goldberg the credit. He put them in a package with a nylon mount for the Cox production engine but "Jim" Walker used them in hie early "Firebaby" models. And the world turns again.
Larry
    • Minnesotamodeler
« Reply #5 on: March 27, 2008, 02:41:11 PM »
...and that's exactly where I first learned about it...lessee, that would be about 53 or 54 years ago!
Ecclesiastes 1:9-10.
--Ray
P.S. Did you know a Firebaby will still fly with half a wing?
--Ray
AMA902472
Offline Mike Spiess
  • bikemike
  • AMA #4060
« Reply #6 on: March 27, 2008, 03:08:23 PM »
--Ray
That would make you alot older (and wiser?) than me LL~
You don't stop flying cause your get OLD
You get OLD cause you stopped flying
St Peter MN
Present Master of the Figure 9
Offline ray copeland
« Reply #7 on: March 27, 2008, 08:06:19 PM »
Oh yes, i fly the balloons all the time,( i got the idea from MinnModeler and later saw it on the firebaby) once you figure your own fueling method (be sure to draw any air out when you fuel) and hook up on them ( i use a little piece of copper tubing inside the fuel line where i tie off the balloon, and i roll back the end of the balloon a little where i tie it off) they work great and hold about 3/4 oz of fuel. Biggest problem is finding a good container that doesn't cramp them up at full volume and connecting the container to the plane. Be sure to cut an extra pickup hole in the line as Ray said. They are definitely better than most metal tanks and much easier to handle than bladders! Once you figure out your own set-up for your plane i am sure you will be pleased.
    • Minnesotamodeler
« Reply #8 on: March 27, 2008, 08:36:57 PM »
Well, older...I'll be 65 (!) this year. When did that happen?
--Ray
AMA902472
Offline George
  • Love people, Use things.
« Reply #9 on: March 28, 2008, 10:47:56 AM »
--Ray
Remember that JW also had a pressure tank back then. Essentially a baloon between two wooden plates with rubber bands around them.
George
George Bain
AMA 23454
    • Minnesotamodeler
« Reply #10 on: March 28, 2008, 04:33:54 PM »
Quite the innovator, he was.  My kinda guy.  Sorry I never met him.
--Ray
AMA902472
Offline John KruziK
« Reply #11 on: March 28, 2008, 05:20:48 PM »
Thanks Ray great pics. I wouldn't have thought to bond 2 together. With the clear container you can also see fuel level another bonus.
AMA 874027
    • Minnesotamodeler
« Reply #12 on: March 29, 2008, 06:24:46 AM »
My pleasure.
Oh, and Larry, my first post showed 4 different tanks, not 3 as I stated.  Only pics #3 and 4 show the same one; each of the others is a different tank.
--Ray
AMA902472
