  • June 29, 2025, 04:44:20 AM
Author Topic: 1/2a Ringmaster  (Read 1622 times)
Offline Chancey Chorney
1/2a Ringmaster
« on: September 09, 2008, 07:07:05 PM »
Hi there all.  I am planning to teach my girlfriend to fly on a 1/2a PT Ringmaster re-build from an Estes kit from the late 90's I believe.  It was the all sheet one.  I had taught myself to fly on it and thought that it was the greatest thing.  Now the problem arises.  At the time, I had a choice of the all sheet model, or the model with a built-up wing.  I now regret not getting that built-up model at the time.  Would anyone out there have this plane in their hangar, or even better, the plans still kicking around.  If so I believe that the fuselage would be the same, and I think all I would need is a trace of a wing rib, along with the number required, and span of the ribs and the rest would be a piece of cake.  This would be a great up-and-coming winter project that I would love to tackle.  Thanks in advance.
Chancey
Re: 1/2a Ringmaster
« Reply #1 on: September 09, 2008, 08:21:35 PM »
I learned to fly on a Baby Ringmaster.  Back in the Sterling days the Baby Ringmaster was just what it sounds like, a roughly 50% Ringmaster.  The Beginners Ringmaster was what looked to be the same plane with a sheet wing.  The one I learned to fly on was broken and rebuilt so many times it eventually got to be so heavy it lost a lot of it's performance, but it will still fly most basic maneuvers ok.  I built another one mostly from the kit but I've never flown it...
In the pic you can see 5 ribs per wing, total wingspan is 21" if I remember correctly.  The airfoil is pretty basic, you could probably get close using a piece of 1/2" square rounded off for the leading edge and 1/4x1/2 tapered for the trailing edge with a 3/16" or 1/4" spar.  The plans don't show anything helpful and I didn't save any templates.
Offline Larry Renger
Re: 1/2a Ringmaster
« Reply #2 on: September 10, 2008, 10:49:04 AM »
Lee Strickland has a 250sq.in. Ringmaster he scaled down from the .35 kit (actually, the average dimensions from 4 kits and models!).  Weight is about 10 ounces, and it has a Norvel .061 for power.  A real dynamite combo, if I could ever get him to fly it again!  This plane is what Leprechaun Stunt is all about.
Offline Just One-eye
  • Another Old Fart
Re: 1/2a Ringmaster
« Reply #3 on: September 10, 2008, 01:09:53 PM »
Dee Rice and Pat Johnston are supplying plans and laser cut rib sets through "Brothers of the Ring", for numerous sizes of Ringmasters.  Check them out at
http://www.brothersofthering.com/
Re: 1/2a Ringmaster
« Reply #4 on: September 10, 2008, 03:48:07 PM »
thanks for the help so far guys.  I will just end up grabbing a symmetrical airfoil from another 1/2a plane and inserting it.  Should not be that much different.  Thanks.
Offline Jeffrey Olijar
Re: 1/2a Ringmaster
« Reply #5 on: September 29, 2008, 04:13:39 AM »
I found this image over at the rc groups fourm.  I have flown both the sheet and the built up wing.  The built up wing was way more stable.  If I were you I would pick that one.  my $.02 if I were to change one thing it would be to make it a thicker airfoil.
« Last Edit: September 29, 2008, 05:01:25 PM by Jeffrey Olijar »
If it ain't broke, fix it till it is.
Re: 1/2a Ringmaster
« Reply #6 on: September 29, 2008, 08:09:56 AM »
Thanks all for the help.  Much appreciated.
