  • July 18, 2025, 10:43:51 PM
Author Topic: Ace Warbird for C/L  (Read 992 times)
Offline Phillip Kenney
Ace Warbird for C/L
« on: April 24, 2012, 10:48:44 AM »
In 1973 RCM had a set of plans for three warbirds using Ace foam wings. If I remember correctly it used a set of tapered chord wings and a 6"constant chord center section. Since it was for mini R/C it had a built up fuselage.. Would this be a good plane to convert to C/L?
I have 3 sets of tapered wings and a set of constant chord so I could easily build all three planes. Would a Norvel .061 be adequate power or to much.
Link to the description on the RCM plans page
http://www.rcmplans.com/index.php?main_page=product_info&cPath=1&products_id=1345
Offline Larry Renger
Re: Ace Warbird for C/L
« Reply #1 on: April 24, 2012, 08:23:08 PM »
The problem will be that the Ace wings are only semi-symmetrical.  For sport scale and casual flying, not a problem, but a real bear if you want insides and outsides to fly the same. (It can be done with thrust and bellcrank adjustments, but it isn't easy!  I managed with an undercambered Firebaby, but it was extremely challenging.)
Offline dankar
« Reply #2 on: May 02, 2012, 08:57:45 AM »
Corehouse sells some foam combat wings that would work better.
