  • July 25, 2025, 11:29:22 AM
Author Topic: A really cool idea for hinges!!!  (Read 3476 times)
Offline Robert McHam
« on: April 02, 2009, 05:58:39 PM »
 Does anyone use metal hinges for planes with less than .09 CID?
 Seems like I ran across an idea somewhere so I will not call it mine. I just don't know who to give credit to.
 That said, I saw a plan that showed how to fold over a piece of tin? or shim stock? over a piece of wire and bring the ends together flat to slide into a slot in the area to be hinged. Not so new of an idea? Maybe but it came to me that this could work on a really small scale. Smaller than you would expect.
 For the shim stock I propose to use a soda can. For the wire I was thinking an ordinary office staple. Or you might substitute a small diameter wire bent into a U shape.
 I have no staples on hand but plan on getting some to play with soon. Remember the Swingline Tot 50 stapler? I have one (but again no staples) Those are really small and light. I am probably going to have to go to Lincoln to get some of those. None around here.
Pros? Cons? You tell me!
 I think they would be plenty strong, light and could easily be slotted into a 1/16" sheet for nice solid hinges.
 Now for a better hinge you could use a small piece of aerosol straw such as you would find on a can of brake cleaner, carburetor cleaner or WD-40. This would eliminate any metal to metal contact.
This idea could be use to make a strip hinge as well using just one length of wire.
 To make installing the hinge a little easier you could shorten the mating surfaces and using 1/32"X 1/4"X length sheet and sandwich it in, no problem.
The poor drawing I did with Paint shows a crude example.
Robert
Offline John Rist
Re: A really cool idea for hinges!!!
« Reply #1 on: April 03, 2009, 08:38:01 AM »
I guess I am a little slow but I don't quite understand how this works.  Does the staple go in one surface and the wrapped around peice of sheet metal go in the other?
Or is there 3 peices of folded sheet metal, two on one surface, and the third between the 2 on the other surface with the paper clip as the pin in the hinge?  What say you Robert
Offline LARRY RICE
« Reply #2 on: April 03, 2009, 09:20:53 AM »
Metal hinges go way back in time. Jim Walker made some that were alum. and fitted over the stab. and elevator, Perfect made them to fit into a slot in the surfaces and the early ones had barbs in them so that they would not pull out. There were many more but i have already showed my age.
Larry
« Reply #3 on: April 03, 2009, 09:31:41 AM »
John, no you are not slow. It's me not providing more precise descriptions.
OK. Lets try to clear things up.
"Does the staple go in one surface and the wrapped around peice of sheet metal go in the other?"
Answer: Yes! Hopefully this (also hurried and rough) drawing will be understood better by all.
In the middle box I have shown how the aerosol tube would be used if you choose to. The tube being red in color.
The bottom image is what a single hinge would look like if laid flat and viewed from above.
I hope this helps!
Quote by Larry Rice:
"Metal hinges go way back in time. Jim Walker made some that were alum. and fitted over the stab. and elevator, Perfect made them to fit into a slot in the surfaces and the early ones had barbs in them so that they would not pull out. There were many more but i have already showed my age.
Larry"
This is true but none are marketed this small these days to my knowledge and from time to time the question comes up on how to hinge. Usually the answer is sewn or cloth or mylar. I wanted to present an old idea updated some using lighter and more modern materials.
Robert
Offline John Rist
« Reply #4 on: April 03, 2009, 10:03:35 AM »
Cool. Got it now.  The only problem I see is keeping the staple from pulling out.  Perhaps an L bend of the staple legs and install them in a small slot with a drop of epoxi.  Looks like a cool ideal that I will play around with on my next project.  Also looks like music wire comes in .015 diameter. That may be small enough to bend your own U shapped hinge wire.  That way you could controll the hinge width and the leg length and shape.
Offline minnesotamodeler
  • Me and my Chief Engineer
    • Minnesotamodeler
« Reply #5 on: April 03, 2009, 03:22:44 PM »
Why would they not perform well? I suppose you'd have to pay special attention to alignment, but otherwise it looks like a sound idea.
Robert, you could also make them up without the staple, install them in both surfaces (staggered) and run a continuous wire through them.  Then the control surfaces would be removable.
--Ray
AMA902472
« Reply #6 on: April 03, 2009, 05:00:52 PM »
I agree that the ones marketed were not ideal but if you took a little care by doing it yourself, you would have a better hinge.
Ray, your suggestion is in line with my mention of the strip type hinge in my first post. Making the wire removable is a great suggestion to go along with it.
This is why I posted the the idea here and while it may not be the best solution, does provide another way of doing something we need. The staples may not be the best idea but John Rist pointed out a nice solution.
The biggest problem I have faced with hinges on small models is that they were too stiff. Always needing a lot of power to move them.
When Ace R/C came out with the nylon half A hinges I just knew there was a problem solved. Not so. I kept cutting them narrower and even tried drilling small holes where the hinge line was and they were still too stiff.
 So long as the alignment is good (this is important with all hinging as we all know), the type hinge I am suggesting here will provide slop free movement with almost no play or resistance.
Mylar hinges are cheap, easy and work very well. This includes the floppy disk kind as well.
I plan on starting a thread covering a number of hinging methods in the future. I like the sewn type myself but there are some who don't like or won't use them for one reason or another. I also like the cloth hinges. some think them unsightly. Both sewn and cloth hinges suffer a great deal from being too stiff if you get too much dope in the middle.
Besides! Some of us just like to piddle around!
  I like coming up with new uses for "found items" Stuff you can get for free or nearly so. Such as the aerosol straws and the soda can material.
Robert
    • Minnesotamodeler
« Reply #7 on: April 03, 2009, 08:17:56 PM »
You're my kinda guy...
--Ray
AMA902472
« Reply #8 on: April 03, 2009, 08:41:44 PM »
In the early 60's there was a belief for a while that rod-and-tube hinges were the really high class way to go.
There were an upgrade from the cloth hinges that would get brittle with dope and eventually fail.  With rod-and-tube your could finish the basic plane and the control surfaces seperately and delay final assembly until the end.
The downfall was that with piano wire rods and aluminum or brass tubes, they eventually wore out and the result was pretty much the same as cloth.
Nylon hinges came on the market - end of story.
« Reply #9 on: April 03, 2009, 08:59:33 PM »
 8)
Paul, your pretty much correct with everything you say but when it came the the pinned nylon hinges, they too had some kind of "hang up" in the middle. They would even make a clicking sound when you worked it past the neutral point. I didn't try Dubro, I felt I wasted more money that I should have on the Goldbergs. I tried like heck with a number 11 exacto blade to fix this problem with no good results.
The good news about this hinge is that with the use of the aerosol straw there is your bearing surface. no metal to metal contact.
Robert
Offline don Burke
« Reply #10 on: April 03, 2009, 11:02:16 PM »
Looks like a lot of thought went into making the hinges, but seems like a lot of trouble.
I use "figure 8" sewn hinges on just about everything.  I even put them on an R/C ARF when the imitation mylar hinges were so stiff the servoes wouldn't center.
BTW I now use spiderwire for the hinges.  The only drawback is the color.  I used to use "nylon 1/2A control lines", but the junk that's available now apparently isn't nylon.  I've heard that dental floss works.
don Burke AMA 843
Menifee, CA
« Reply #11 on: April 03, 2009, 11:20:38 PM »
You might try a Sharpie permanent marker to color. Yes they come in more colors than black. No they may not match completely. Try a store like "Michaels" or "Dick Blick's" to find the best selection for individual colors.
Robert
Offline George
  • Love people, Use things.
« Reply #12 on: April 04, 2009, 06:47:01 AM »
The easiest ways to hinge the elevator on a 1/2A are Chinese style (my favorite), the thread-sewn figure eight (mentioned above), and a method that IMHO is by far the easiest, just glue a single piece of cloth hinge (preferably nylon) to the bottom of each elevator to stab line. This method calls for a 45 degree bevel on the elevator to allow movement without a large gap between the elevator and stab.
George
George Bain
AMA 23454
« Reply #13 on: April 05, 2009, 07:15:31 PM »
Ty I appreciate your comments and ideas.
In post seven of this thread I made a point to let everyone know that I like the sewn type myself. All you say of them is true.
As for reinventing the wheel I hardly think this qualifies. I am only trying to improve on something that has already been invented.
This is why we are not all driving model T fords in the one and only color they came in.
Who makes the best motorcycle? Then how could another motorcycle company sell even one of anything else?
Who makes the best washing machine? Then how can there be others? And wheels! why, there are more kinds of wheels than I care to talk about.
You make a good point that I had not thought of yet about my idea.  The part where you said "The metal always seems to not want to close up"
I can see that this could still be a problem with the type hinge I am proposing here. Possibly after folding the sheet over the tube I could use a push pin or the like to perforate the metal and allow the glue to pass through and create better adhesion!
Thanks for giving ,me something to think about Ty!
Robert
Offline John Rist
« Reply #14 on: April 06, 2009, 08:17:46 AM »
I was looking for a good how-to post on sewn hinges. Does anyone have the link?
« Reply #15 on: April 06, 2009, 10:07:07 AM »
John sewn hinges are really a piece of cake to do! Here is a link that explains it pretty well:
http://www.iroquois.free-online.co.uk/knot.htm
 If you are still unsure, ask again! Here is a pic of a sewn hinge for you.
Robert
Offline John Rist
« Reply #16 on: April 06, 2009, 10:32:07 AM »
Robert
Got it thanks.  The trick that I picked up from the article is that the holes in the two mating surfaces need to be off set by a 1/2 hole spacing.  The article warns agents super glue. I can see where it could be bad.  How about dope? I have used dope in the past to do cloth henges on a Ringmaster.  Anyway all good info. Thanks!!
 #^  H^^
« Reply #17 on: April 06, 2009, 11:41:30 AM »
My pleasure John.
The good thing about sewn hinges is that they can be spaced apart as you noted or close together. Take your pick. Main thing is no slop and you will have a bind free hinge.
Also simply round the mating edges so that they will roll. You don't want to bevel the edges as you would for other type hinges.
Dope is fine, only for sealing the holes. The thread in between needs to stay flexible of course.
Robert
