Building Tips and technical articles. => 1/2 A building. => Topic started by: Bill Gruby on April 01, 2007, 07:57:27 AM
Ok 1/2A Fanatics;
What can you tell me about a VA .049. No this ain't an April Fools joke. I have a few hours to gather info on this critter before it is gone.
"Billy G" D>K
Bump to top, I bumped cause I didn't want it to get lost I don't have much time
"Billy G"
A hot Russian made .049. One version had the cylinder made in a way to make altering the timing easy. "RYOT" .... "Roll" your own timing.
Strong, like a "Hot" Norvel. Dan Rutherford had something to do with importing them, IIRC. I always heard they were good .049s.
Thanks Bill
Now for use, is it just for speed or can it have other applications? Maybe it is just a collectable?
"Billy G" D>K Coffee #2 goin
I have seen them in use with 1/2A Stunters. The "Little Legend" Series drawn by Steve Buso (and the original 1/2A Prowler, IIRC) used them. Prop them accordingly.
THAAAAAAAAAAAANK- YOU Bill
I have what I need now I will own one in a few more hours. LL~ LL~ LL~
"Billy G" VD~
I have 2 of them, Bill, and they will just about keep up with a Norvel .061 and that's saying a lot. They do like smaller props (5" or smaller) and will really squeal. Easy to start & needle. I've only run mine on pressure so far but plan to see how well it draws fuel on suction as soon as the weather cooperates. Only problem is that rear exhaust is kinda awkward to build around. Nice little engines though. I haven't got a lot of time on them yet but so far I like them a lot.
--Ray
I am not fond of the earlyest va's they're the ones with the split case.
Bill;
Thank-you; The one I am after does not have a split case. I was told the same thing this afternoon by a Modeling friend who flys 1/2A Free Flight.
"Billy G" H^^
After taking a another look at this engine and blowing it up 200% it shows what looks like a rivit or bolt at the rear on the flange. Does this make it a split case, I can see no joint line. It also states "RYOT" is this good or bad?
The RYOT was to alter timing. I am not fully sure but it had to do with lowering or raising the cylinder, IIRC. It could be tamed down somewhat from a combat to more of a "sport" engine. Well maybe not THAT far, but timing could be changed. Dirty Dan was importing them for 1/2A combat in the beginning.
Bill;
Blowing up the paperwork it does show "Dan Rutherford" as the importer. If anyone cares to take a fast peek it is item #280098863770 on the Bay. There are 2 hrs left.
"Billy G" H^^
that is the split case. if you look at the back there is no way to remove the crank. you adjust the timming buy taking the piston apart and adding shims. and the compression with head shims. they run fast but you can get case leaks.
they do run fast but they are not good for stunt, it works on a bladder.
OK Bill;
I'm all set now, my specific target use is 1/2A Combat this should be the cats' butt.
"Billy G" H^^
On the early VAs the crankcase top and bottom halves are held together with a screw at the back and by a threaded collar behind the prop driver. The collar has a couple of notches in it's trailing edge that are for a spanner wrench. The collar could be used to push the drive washer off the end of the crank, although I don't know if that was the approved method.
I have a couple I used in FF, mid 90s. The crank is very thin and an electric starter was not recommended, ask me how I know!
To all involved;
This is what this "Forum" is all about. It's to bad that more people don't get around this "Forum" more. With your help and vast knowledge of this engine I made a decision to go ahead and bid on it. My low bid prevailed and I now own the engine. I am looking forward to having a lot of fun with it . Thanks again to all of you for your time, effort. and knowledge.
"Billy G" (PE**) HIHI%% (PE**)
OK Bill;
"Billy G" H^^
Bill,
I have a few of those and you can set them up to run stunt. Most owners of these motors never did see the multi page pamphlet that Rutherford put out after the motor was introduced. There was a wealth of info in it and I have it somewhere in my files. Yes the case could leak if put together wrong. It also did benefit from a careful lapping, nothing too difficult for anyone used to working around motors.
I know that I have 3 of them and one is new never run. Alas no boxes for them but such is life. If your a collector that ruins it doesn't it.I actually planned to run all of them and did 2 of them with great success. Also got my buddies motor that he bent the rod on. This was after the MK 2 was introduced and was being sold by Larry Driskoll. Anyhow The Dirt kindly sent me parts and even more then I needed to put that one back in use. However my old flying buddy passed away so I keep it for sentimental reasons and it won't get flown again.
Oh and most of the running for stunt would be with an APC 6/2. I ran mine on bladders though.
Dennis
Update: My VAs must be later, they are one-piece cases, rear exhaust--Mk 2s? They run very strong, nice for combat. I did manage to get one running on draw today, on a test stand, but I'm not sure how well it will do it in maneuvers--needle had to be WAY out. I think it's just happier on pressure. Maybe a venturi restricter would help. I'll be messing with it some more.
--Ray
OK-----
Tried to post and it dissappeared? VA .049 arrived today. This little thing is SWEET. It is a split case but the machining is superb, I see no problems ahead. I am going to read info tonight and run it tomorrow on pressure. Thanks again for all your help.
"Billy G" (PE**)
Dontcha just love a new toy?
Robert
Bob;
You are soooooooooooooo right I put it back in the box at least a couple of dozen times now. LL~
"Billy G"
That means you took it out at least a couple of dozen times, minus 1...I know the feeling.
--Ray
All you 1/2 A guys;
I know you don't go to E*** for these things, been there. I bid $61.50 for 6 and LOST--- $10.00 a pop seems a little high? Where do you get the High Compression Glow Heads? Can I get a head adaptor to use short glow plugs?
Whatcha think can you help me out here?
"Billy G" HB~> HB~> HB~>
Galbreath head, Nelson plugs. Cheaper on plugs, and enhanced performance as a bonus. Fits Coxes, Norvels, I think VAs, at lease the new ones, I guess Cubs since Cox heads will interchange with them. The heads are $10 (but a 1-time purchase of course), plugs are something like $3.50 or $3.75. They last forever. Everything runs better with it!
--Ray
Ray;
Thats what I'm lookin for ,where do I find them. Sorry this is new territory to me. Only reason I started with the VA .049 was the price. It really is one he## of a runner.
Billy G" ;D
Kittingittogether.com or doug galbreath's website both have for sale.
"Billy G"
Only one caution w/the Galbreath head. It is not a problem, just a user tip.
Put a small amount of Anti Seize lube on the steel plug thread before inserting it in the Aluminum head. Keep lube out of the combustion chamber.
Makes plug removal much easier. AMHIK HB~>
Roger
Yes...what Roger said.
