  • July 07, 2025, 10:32:19 AM
Author Topic: A Little Force  (Read 3176 times)
Offline Larry Lindburg
A Little Force
« on: November 07, 2019, 08:26:53 AM »
The original plane had a 1/8th" balsa sheet wing.  That wing kept warping which made the plane a dog.  I removed the sheet wing and added the built up Little Teosawki kit wing.  The initial test flight showed that plane has good potential.
AMA 95707
Re: A Little Force
« Reply #1 on: November 07, 2019, 09:57:45 AM »
I like it. D>K
Offline John Given
Re: A Little Force
« Reply #2 on: November 07, 2019, 10:35:39 AM »
Nice looking aircraft !!!
Offline Jim Howell
Re: A Little Force
« Reply #3 on: November 07, 2019, 02:11:35 PM »
Larry,
Can you provide a bit more info?  I really like the look of this, having gone thru at least 3 PF's before they became unobtainable.  And, since I have one of the BMJR 1/2A TEOSAWKI kits it would be a snap use the kit wing and to make a different fuse/tail group.  But it would be useful to know if you had a specific percentage scale factor for the PF plan, and/or it would be useful to know what the wingspan of your little cutie might be.  I can work backwards from that.
TIA,
Jim Howell
Huntsville, AL
Jim Howell
Huntsville, AL  AMA 545805
Offline Bootlegger
Re: A Little Force
« Reply #4 on: November 07, 2019, 02:12:33 PM »
  Got some building plans/sketches?  I like the looks quite a bit, would like to build one...Thanks
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline 944_Jim
Re: A Little Force
« Reply #5 on: November 07, 2019, 02:21:21 PM »
Hey, that's just my size! When does a plan go public? Need another bets tester?
I fly from concrete as much as possible, and have a splash of Norvels and APs looking for something more capable than the Scientific P-40 I trashed this past summer.
TIA,
Jim in MS
Re: A Little Force
« Reply #6 on: November 07, 2019, 08:49:31 PM »
 Way cool Larry! Looks like the other guys had better step up their game in Polk City!
Re: A Little Force
« Reply #7 on: November 08, 2019, 06:03:05 AM »
Gentlemen,  I will take some measurements.  Larry
AMA 95707
Offline Jim Howell
Re: A Little Force
« Reply #8 on: November 08, 2019, 09:11:36 AM »
Great!  I'll be watching.
Jim Howell
Jim Howell
Offline 944_Jim
Re: A Little Force
« Reply #9 on: November 08, 2019, 10:55:37 AM »
Is a little Force a Bump or a Nudge? I couldn't find any neat synonyms.
Thinking Baby Force...all I can come up with is Contraction
 Lol.
Re: A Little Force
« Reply #10 on: November 08, 2019, 06:30:42 PM »
32nd Attempt to post specs:
Each wing panel: 15.5 in.
Wing root: 8 in.
Fuse. length to tail tip: 21 in.
AMA 95707
Re: A Little Force
« Reply #11 on: November 08, 2019, 06:37:44 PM »
Hooray, more specs:
Fuse. front to wing: 5.5 in.
Rear of wing to elev. hingeline: 5 in.
Elevator hingeline length: 10 in.
Elevator horn: 0.75 in.
AMA 95707
Re: A Little Force
« Reply #12 on: November 08, 2019, 06:42:45 PM »
I think any built up wing or foam wing fitting those general specs would work.  Just shape the fuselage, tails, and wing tips to the desired shape.
AMA 95707
Offline Jim Howell
Re: A Little Force
« Reply #13 on: November 09, 2019, 06:21:51 PM »
Larry,
Thanks for posting the numbers on your little PF.  That should be sufficient for what I have in mind.  Thank you!
Jim Howell
Huntsville, AL
Jim Howell
Offline Rick Bollinger
  • AMA 931589
Re: A Little Force
« Reply #14 on: December 04, 2019, 09:21:16 PM »
Larry that looks great!! Looking forward to seeing it fly. Motorman we fly off of a folding card table on grass. Larry even has a stooge attatched to his for flying solo. Then just land on the grass but with no bending over on start ups.
Rick Bollinger
AMA 931589
