  • June 19, 2025, 06:07:05 AM
Author Topic: Plane for the TeeDee 010  (Read 2435 times)
Offline Richard Koehler
« on: November 28, 2011, 06:01:21 PM »
Does anybody know if there has ever been a small plane designed for the Cox .010 engine?  A friend just found one and is looking for plane for it.
Re: Plane for the TeeDee 010
« Reply #1 on: November 28, 2011, 06:23:29 PM »
Do a search on these forums.  There have been lists posted on several occassions.
To answer your question:
Yes.
There have been a number of models designed for the Cox .010 engine.
There are even some for CL and have been published.
For these such lists, you might have to go back a year or more.
Offline kenneth cook
« Reply #2 on: November 29, 2011, 03:26:21 AM »
           The .010 would fly the Queen Bee bipe. I use a .020 Pee Wee but I feel the .010 makes good power. The Wee One is a full bodied stunter designed for the .010. Ken
Offline pat king
    • PDK LLC
« Reply #3 on: November 29, 2011, 06:46:09 AM »
I sell several laser cut kits for the Cox TD 010. Those include a profile scale F82 twin. These kits all use a sheet wing. There is a Micro Ringmaster, Micro Ringmaster Bipe, Micro Flite Streak, F82, Micro Sopwith Camel, Micro Fokker Dr1.
Pat
Pat King
Monee, IL
AMA 168941
Offline Dennis Saydak
« Reply #4 on: November 29, 2011, 08:29:15 AM »
I have a Charles Mackey Liberty Bell.
Offline Larry Renger
« Reply #5 on: November 29, 2011, 11:32:05 AM »
Randy Heydon published the Little Bit.  It was a fully aerobatic stunter capapble of the full pattern.  He commented on it in this forum recently, so do a search and ye shall find.
Offline Thomas Wilk
    • Tom Wilk's old mag plans on CD
« Reply #6 on: November 30, 2011, 09:08:48 AM »
Queen Bee  by Larry Scranzzi
« Reply #7 on: December 01, 2011, 06:02:18 PM »
You could scale this bad boy down. Wouldn't have far to go, it's already small.
« Reply #8 on: December 01, 2011, 09:47:01 PM »
Not a particularly good recommendation.  That Stiletto was for 1/2A Proto which at the time it was published, rules required a minimum span of 14 inches and a minimum area of 45 sq in.  That design, like all 1/2A protos had a thin solid wing and an extension shaft almost 3 inches long with a bearing to carry the shaft behind the propeller.  The engine was buried in the fuselage with the head of the engine behind the wing LE.  Hardly a practical subject to adapt for the TD .010 unless the builder realy wants to do something different.  If that is the case, the builder would probably not be asking about designs for these engines.
It is/was a neat airplane.  From American Aircraft Modeler, Dec 70.
« Last Edit: December 02, 2011, 01:56:42 AM by Trostle »
« Reply #9 on: December 02, 2011, 07:24:27 AM »
Keith,
Absolutely and I agree.  ;D
However, I don't understand your conclusion about the model I suggested?  ???
The recommendation was fine. Richard's inquiry made no mention of competition or entering the model in any event. "Rules," and I'm asked all the time why I never competed.  LL~
I'm actually drawing that model up for a larger size engine, giving no considering to any rules to do it.
CB
Offline Carl Mataratzo
« Reply #10 on: December 04, 2011, 05:57:19 AM »
if you do decide on a queen bee, the span should be 11 inches
a scanned and reprinted page for me resulted in a slightly smaller model
cm
Offline pat king
    • PDK LLC
« Reply #11 on: December 04, 2011, 09:32:16 AM »
Pictures of some of the Micro airplanes.
Pat
Pat King
Monee, IL
AMA 168941
Offline KenP51
  • K Pitts
« Reply #12 on: December 08, 2011, 07:53:53 PM »
When I was a teenager I made a .010 control line using the horizontal tail from a crashed Jr. Falcon. Home made ply bell crank. Did real basic stunts. I did the same thing with a falcon 56 tail and a .049. That flew rather well.
Early recycling H^^
But as for me and my house, we will serve the Lord
« Reply #13 on: December 14, 2011, 06:22:49 AM »
I would go with the Queen Bee or the Wee Wun. (sp?)  Also the micro models Pat King has available.
Big Bear
« Reply #14 on: December 14, 2011, 06:33:58 AM »
OOPPPSSS!!!!!!  I forgot Danny Banjock's Little Bitty Bi-Slob.
Big Bear
