  • June 16, 2025, 06:41:33 PM
Author Topic: WACO CABIN MODEL  (Read 1665 times)
Offline LARRY RICE
WACO CABIN MODEL
« on: April 03, 2009, 10:28:46 PM »
      Available it Black Hawk Models Authorized Dealers in about two weeks the Walt Musciano WACO CABIN MODEL. Designed in 1953 and now available again. This biplane should be a show stopper at the Musciano contest this year. The Cox production would be a perfect match for the model.
Larry
Offline nobler
Re: WACO CABIN MODEL
« Reply #1 on: April 03, 2009, 10:58:02 PM »
Hi Larry. I have one that I got at a swap, already painted and ready to go. It is intended to take a .020, but a Black Widow would make this thing a monster. Never flew it. It had crud on it from sitting for decades, but it cleaned up well. The builder trimmed it just like the box art.
Smallest span of all the Hollow Logs...
Currell
Offline LARRY RICE
« Reply #2 on: April 04, 2009, 07:17:20 AM »
     Someone sent us a Waco, a long time ago, but it was not a priority so it just sat around. Now with more Musciano events I took another look at it and th plans that you had sent to us. If someone hollowed it out some more this would be real fast, a racer.
     Currell, I am looking for a set of plans for the Cessna "210" Glider and or the powered version that appeared in a Mag. article.
Larry
Offline Robert McHam
« Reply #3 on: April 04, 2009, 08:56:29 AM »
I like that a lot!
Curell mentions it having the Smallest span of all the Hollow Logs, What is the span? I'm curious!
Robert
Offline LARRY RICE
« Reply #4 on: April 04, 2009, 09:21:27 AM »
       Scientific never said what the span is, only that it had a 32 sq in area (on a bipe). The upper wing is 13" - 22 sq in area, lower wing 9" - 10 sq in, I do not have the plan here with me but I think that is right. The plan is at the draftsman's place drawing up the Black Hawk Models plans and decals. The wing is thicker than our other bipes so it can be airfoiled. The Fuselage is a little heaver than later models but you can lighten it up.
Larry
Offline nobler
« Reply #5 on: April 04, 2009, 09:49:13 PM »
I just went over to the shop to measure. It is 11.75" top, 8.75" bottom.
Small.
Currell
Offline LARRY RICE
« Reply #6 on: April 09, 2009, 10:56:48 PM »
Here are the changes that we made in the kit:
We extended the wings to 12" and 9".
We moved the landing gear forward slightly to make room for a fuel tank.
Because our bellcrank is a little we moved the bellcrank forward 3/16" on the wing a slightly toward the wing tip to clear the cowling.
Larry
Online Dalton Hammett
« Reply #7 on: April 10, 2009, 06:59:52 AM »
Hello Larry
    Nice,,, I always liked that plane, I build one of the larger Sterling kits years ago.   I will watch for one at
    Maxwell's *******************
 Dalton H.
Dalton Hammett
Albion, Pa.
Bean Hill Flyers
AMA  29918
Offline LARRY RICE
« Reply #8 on: April 10, 2009, 07:10:59 AM »
Let Joe know that you want one and he can put it on his next order. Tell him that it is FS 3600 and sells for $30.00. It will be in the next newsletter in June. The kit also includes a FREE control handle and lines.
Larry
