  • August 01, 2025, 05:25:51 AM
Author Topic: 20 lb test lines Hi Vis yellow  (Read 4605 times)
Offline Bootlegger
« on: May 30, 2021, 06:50:16 PM »
 Fellows I am looking for some 20 lb flying lines , I already checked on the search area, no luck..
 I think that they are Pro Power.  Hi Vis yellow is what I am looking for, I went to Bass Pro, but they didn't have them, I know that someone on the hanger can help..  I posted on the  open forum also... Be Much Obliged
8th Air Force Veteran
Gil Causey
AMA# 6964
Re: 20 lb test lines Hi Vis yellow
« Reply #2 on: May 31, 2021, 07:58:01 PM »
I got mine at Fisherman's Marine.  I don't know where you are located.  But, my Hi-Viz yellow is about gone, so I have to fall back on my green.  Every time I go to the flying field, I stop in to see if they have any more, since the store is right next to the park where we fly. But they don't seem to want to stock the yellow any more.  And they haven't had 10# test in a couple of years.  I may have to break down and order some online.  I prefer 10# for my 1/2A planes.  I know most people don't go below 20#, but I did some failure tests a few years ago, and the 10# test was breaking at around 18 pounds.  More than good enough for my 1/2A's.
Mark
« Reply #3 on: May 31, 2021, 08:08:32 PM »
Just looked this up.  10# Hi-viz yellow, 500 yards.  That should last me for years.  I'm gonna order it when I get home:
https://www.amazon.com/PowerPro-21100100500Y-Braided-Spectra-Fishing/dp/B000SHUGXQ/ref=sr_1_13?dchild=1&keywords=power+pro+hi-viz+spectra+10+pound&qid=1622512840&sr=8-13
Didn't have any luck searching for 20# yellow, though.
Mark
« Reply #4 on: May 31, 2021, 09:52:14 PM »
Mark
  To stretch out your supply of yellow, just make one line with yellow and the other green. You will still be able to see where your lines are in the grass.
« Reply #5 on: May 31, 2021, 10:12:05 PM »
 :o
« Reply #6 on: June 04, 2021, 10:02:11 PM »
I was in the local Bi-Mart this evening to pick up some garage organizer items, and stopped by the fishing department to grab some split rings.  I looked to see what they had for Spectra line and saw this:
Mark
Online Robert Zambelli
« Reply #7 on: June 08, 2021, 07:58:52 PM »
I bought this from Amazon:
Power Pro Maxcuatro Fishing-Equipment, 20 lb X 150 yards, Hi-Vis Yellow.
$28.00 delivered.
Offline 944_Jim
« Reply #8 on: June 09, 2021, 04:02:32 PM »
Gents,
I asked this in another thread, but I guess it got lost.
Are you tieing off your synthetic on split rings, or straight to the connector (without a split ring) that will then clip to your lead-outs?
Thanks in advance.
« Reply #9 on: June 10, 2021, 12:46:08 AM »
I do both, depending on what I'm doing.  I can't give you a hard and fast rule, it is just what I feel like at the time.
Mark
Offline bobsrc
« Reply #10 on: June 10, 2021, 12:11:33 PM »
The Power Pro labeled as clear is actually white and is just as visible on grass as the yellow.  I've been flying 1/2 a with 15# test Power Pro and have found that it will tear the bellcrank out of a 1/2 a before it will break.  Have fun.
Offline kenneth cook
« Reply #11 on: June 10, 2021, 04:21:32 PM »
              Even the high vis yellow will eventually turn white. It's still better over using moss green.
Offline Bootlegger
« Reply #12 on: September 17, 2021, 08:27:37 AM »
Much obliged Guy's, does any one have a phone number fro these suppliers again  TI A Bootlegger   D>K
Gil Causey
AMA# 6964
Offline Wayne Collier
« Reply #13 on: September 17, 2021, 08:00:52 PM »
I just buy the green at Walmart. Usually use 12 pound test for 1/2 A.
Braided
« Reply #14 on: October 18, 2021, 08:14:48 AM »
AND it will let you differentiate between UP & DOWN line which can be kinda handy!
