  • August 01, 2025, 05:24:08 AM
Author Topic: blank  (Read 2526 times)
blank
« on: September 14, 2021, 08:57:22 PM »
blank
« Last Edit: September 21, 2021, 06:37:04 PM by Motorman »
Offline 944_Jim
Re: White Lightening
« Reply #1 on: September 14, 2021, 09:52:03 PM »
MM,
Is that a profile fuselage, slab wing plane with 28" wingspan?
Offline 944_Jim
« Reply #2 on: September 15, 2021, 03:53:10 PM »
That is too funny! ISTR every time I've seen the model on websites, it has always been white. I reluctantly posted the image after careful review if your blue one. Full size plans are out there. I'll see if I can find them quickly.
Offline 944_Jim
« Reply #3 on: September 15, 2021, 03:57:18 PM »
Offline kenneth cook
« Reply #4 on: September 15, 2021, 05:25:39 PM »
              I built one a few years ago. The plans called for a Cox TD or a Norvel. Well, neither balanced the model. Just as a idea, the weight of a TD .09 is approximately what 2 TD .049's weigh. It took that much weight. I asked Bruce about this and he said their example worked. I liked the design, the simplicity but the wing flexes which compromises maneuverability and this also happens on smaller sheet wingers like the Skyray. I removed the wing and had Phil Cartier cut me a extended version of his Lil Hacker foam wing. I moved the wing back and it flew a lot better.
             https://www.hippocketaeronautics.com/cl_sp_white_light_build.htm
