  • June 19, 2025, 06:23:03 AM
Author Topic: Another White Lightning  (Read 1326 times)
Dwayne
« on: March 16, 2011, 06:13:55 PM »
This is the third one I've built they really fly great, this one has a Norvel 061 and I enlarged the v-stab and rudder wich I think looks better.
Dwayne
Offline kenneth cook
Re: Another White Lightning
« Reply #1 on: March 16, 2011, 06:29:46 PM »
             Dwayne, my White Lightning has been on the back burner for months. I cut and assembled the pieces then went to paint. I chose a piece of balsa for the fuse that was probably too light. I shaped and sanded just as the plans indicated. The fuse is very thin only 1/8th at the tail. I decided to silkspan the fuse as to get some stiffness out of it. This worked but its still a bit more flexible than I would like it to be. I chose some fairly stiff balsa for the elevator and stab. My problem is that I think if it goes in,  the weight of the tail parts may just snap the fuse. Nonetheless, I moved forward with paint and ran into some major problems. I just can't believe how tail heavy this plane is. I've heard this mentioned by others that built the model. I know it was designed around the Tee Dee or Norvel. You stated that you enlarged your stab, didn't this make yours even more tail heavy? Ken
Dwayne
« Reply #2 on: March 16, 2011, 07:15:40 PM »
Hi Ken
Yeah the first one I built had a TeeDee 051 and was very tail heavy I ended up cutting 1.5" out of the fuse this worked so I built another 1.5" shoter and cut a half inch off the leading edge of the h-stab and it still flew great. This one has the origanal fuse but I still cut a half inch from the stab also the 061 has a muffler so it weighs more than a 051 so it balances  perfect. Don't give up on it these are great flying planes.
Good luck
Dwayne
« Reply #3 on: March 17, 2011, 03:23:24 PM »
      Dwayne, this explains it. I drilled for a Tee Dee. The good thing here is that I put the spinner slightly more forward than you would conventionally. This will allow me to swap out for a Norvel which has a slightly shorter case. If I still have a problem with balance, I could go to the Big Mig.074 that I was using. The case is slightly larger but I believe it may still work. I actually bent a single wired gear for mine so a two wheel version may be in order. Ken
Dwayne
« Reply #4 on: March 19, 2011, 06:32:04 AM »
Sounds good Ken, a 074 should make it really go...lol  y1 <= #^
