  • June 16, 2025, 11:44:29 AM
Author Topic: Light Weight Coverings for 1/2A's ?  (Read 2176 times)
Offline Bill Barber
« on: May 12, 2009, 04:08:08 PM »
   I am in the process of stripping an old 1/2A model of silkspan and want to cover it with something even lighter.
Used to use Airspan which you iron on then clear dope it to fuel proof , can't seem to find it now. What about Sig Aerokote lite or
Coverite lite  ?   Looking for some recommendations !
    Bill Barber
AMA 325076
Offline minnesotamodeler
  • Me and my Chief Engineer
    • Minnesotamodeler
Re: Light Weight Coverings for 1/2A's ?
« Reply #1 on: May 12, 2009, 07:57:50 PM »
Coverite Microlite, slightly over 1/2 oz/square yard!  Also, Nelson made a similar stuff, same weight, called "Nelson Litefilm" but I don't know if they still do or not. These are self-adhesive iron-on plastic films.  Handle with care as they are easily torn while applying.
Here's a pic of a 1/4A model with Microlite on the wings.
--Ray
AMA902472
Offline Roger Vizioli
  • CLiner
« Reply #2 on: May 12, 2009, 08:30:33 PM »
Bill,
I have successfully used UltraCote Lite on my 1/2A's, ie Pathfinder and RM207 and "Little Legends".
Roger V.
Roger Vizioli
AMA L-2408
Florida/Space Coast
Offline Ralph Wenzel (d)
« Reply #3 on: May 12, 2009, 10:13:35 PM »
You might also consider the "LW Tissue" (almost like PolySpan) from www.bphobbies.com  They have several other interesting offerings, as well.
Ralph Wenzel
AMA 495785 League City, TX
Offline Stan Tyler
« Reply #4 on: May 13, 2009, 02:22:41 PM »
Bill,
Try Coverlite from Coverite. Light weight and fuelproof out of the package, needs no dope. It does not have an adhesive on it so you will need to use SIG Stix-it brushed on the framework before you can iron it down.
Larry Renger has had good luck with this and I used it on my 1/2A version of the Twin Flight Streak.
Later,
Stan
Stan Tyler
AMA 3239
Offline Bill Barber
« Reply #5 on: May 13, 2009, 02:48:55 PM »
       Stan , went through my stash of covering materials and found a new package of  Coverlite .  So gonna use that on the wings .
  Thanks for the input .
        Cheers , Bill
AMA 325076
Offline Larry Renger
« Reply #6 on: May 13, 2009, 11:16:25 PM »
Bill, you have flown my Sky Sport.  It is Coverlite covered and has stood up to about 4 years of hard use with minimal damage.  I just cornered the market on the stuff, as I was told it will be discontinued!  Tower has it in stock, and it seems to "keep", so stock up!
Offline George
  • Love people, Use things.
« Reply #7 on: May 17, 2009, 09:02:06 AM »
If you don't want iron-ons, plain old Japanese tissue. Stick on with dope, thinned white glue, or a glue stick.
George
George Bain
AMA 23454
« Reply #8 on: May 20, 2009, 12:53:49 AM »
Coverlite is 1/2 the weight of doped Japanese Tissue!  And 1000 times as puncture resistant.  I own bunches of both, and haven't touched the tissue in years.  Tissue MAY give you more warp resistance.
