  • August 02, 2025, 05:26:32 AM
Author Topic: 1/2A Steve Wooley Cobra?  (Read 5351 times)
Offline Target
  • C/L Addict
« on: October 14, 2017, 04:24:30 PM »
Has anyone built this, or purchased plans?
Any comment on the 1" shorter outboard wing? Seems like for a 1/2A it would be less, since they don't even use that much sometimes for bigger ones now.
I was thinking that just offsetting the fuse outboard a 1/2" would be reasonable. Thoughts?
I'd do the wing in blue foam and Carboline though, maybe with molded wing tips. To keep the tips identical, and only one mold needed, I'd make the tip chord the same I think, as opposed to what the plans show. Thoughts?
Looks bitchin', in my opinion.
R,
Target
« Last Edit: October 14, 2017, 08:31:23 PM by Target »
Chris
AMA 5956
Re: 1/2A Steve Wooley Cobra?
« Reply #1 on: October 14, 2017, 06:03:35 PM »
The method shown on the plans lets to builder effectively build two identical wings and then cut an inch off the outboard.   Your method might make a more pleasing look at the expense of more complexity.
If you look at line length at differential speed, you may be made to believe that models that fly on short lines need MORE offset.
Blue, pink and green foam is TWICE as heavy as white foam.  I learned that years ago when I built ONE model with blue foam.  I used up the rest on forms & fixtures that didn't become parts of models.
Offline Target
  • C/L Addict
« Reply #2 on: October 14, 2017, 08:20:44 PM »
I'm pretty up on foam densities.
While a white foam wing with 1/32" balsa is pretty light, it still isn't finished.
Modern vacuum bagging of Carboline (it's like .006" thick, and NOT woven, unidirectional in 2 directions) with epoxy over foam that won't compress, the coring it out very thin should leave a finished product that I (hope) will be light enough, strong enough, and already fuel-proof.
http://carboline.info/
I haven't done it yet though, so just a theory at this point. One I hope to get time to prove, right or wrong.
Thanks for the reply on the tips, but for me, if I'm hot wiring foam, it's just as easy to use the same templates on two different length panels as it is to cut two identical wings then cut one shorter. Actually, maybe easier.
But double thanks on the shorter lines thing; I am kinda bummed I missed that. The smaller the radius, the greater the speed differential, now that you mention it!
Good food for thought!
Any leads on where these plans (printed) can be had?
R,
Target
Chris
AMA 5956
Offline john vlna
« Reply #3 on: October 16, 2017, 12:40:52 PM »
THE PDF posted seems to be full size, take it to Staples, Kinko's, etc and they can print it. I use Staples myself.
Offline Target
  • C/L Addict
« Reply #4 on: October 16, 2017, 12:48:28 PM »
I'm wondering if 100% will give me an accurate 1" = 1" scale though?
If it is off a bit it will be worthless. On my computer screen 97% is 1", 100% is over 1". Maybe this is of no relevance.
Has your experience been that there is no concern for this?
Also, what about copyright? I have had questions at some print places, not at others.
Thanks for the help, John.
R,
Target
« Last Edit: October 16, 2017, 02:08:01 PM by Target »
Chris
AMA 5956
Offline john vlna
« Reply #5 on: October 16, 2017, 01:21:48 PM »
Target
I don't think you can trust the screen. I measured the PDF and it is full size 1" = 1".
There is no copy right that I can see. Since I don't know the source, I can't say. I think copy right is automatically assumed, if there was a problem printing you would have to find the author I guess. But I am no expert in this area. I personally don't care if anyone prints my plans for private use, commercial  use would be another another question .
Offline john vlna
« Reply #6 on: October 16, 2017, 01:24:59 PM »
By the way the original Cobra was in the defunct AAM in 1971, so I doubt anyone would care.
Offline Target
  • C/L Addict
« Reply #7 on: October 16, 2017, 02:08:48 PM »
Copy all,  John.
Thank you.
Chris
AMA 5956
Offline Serge_Krauss
« Reply #8 on: October 16, 2017, 10:13:42 PM »
There's no guarantee that anyone's copier or copying service will give you a correct (near perfect) print anyway. I discovered that they are usually off enough for me to care.
When I went out for a copy for friends, my copier agreed that if the first copy was not right (in BOTH directions) I could give him a magnification factor to punch in, and he would run me an accurate copy. On a full sized ( say 50'-span) stunter, that was a 1/2" error for each 1% off. I just divided a key dimension by the length on the copy and got a number for them to use for correction. For instance, if a 50" wing came out at 49.5" on the first copy, 50/49.5 = 1.01. So I told them to run it off at 101%. It depends a lot on their equipment quality, and the length and width are not always off by the same amount. You just do your best, and if the equipment is sophisticated, you can go to the tenth of a percent. Building your 1/2-A should not require plans though to just adjust parts to the right size, if you know the intended span or any key part's dimension. Those copies can be expensive.
SK
Also, just a FWIW: moving the fuselage 1/2" is making one wing an inch longer than the other.
Offline Target
  • C/L Addict
« Reply #9 on: October 17, 2017, 05:36:21 AM »
Thanks Serge.
All of what you posted above is why i was hoping to find printed plans for sale. I'm not even certain this plane was ever built. Probably Someone did though.
Thanks again.
Chris
AMA 5956
Offline john vlna
« Reply #10 on: October 17, 2017, 07:58:28 AM »
This page has the post by the guy who drew the plan  https://www.rcgroups.com/forums/showthread.php?1265873-Vintage-Old-Timer-Plans-PRE-1960-PLANS-ONLY/page31#post16055014
You probably could get a CAD version from him
Offline Target
  • C/L Addict
« Reply #11 on: October 17, 2017, 01:32:52 PM »
That's awesome John,  i can print the tiled version at home and see what the inch scale shows.  Great find. Thanks.
Chris
AMA 5956
Offline Tim Thompson
« Reply #12 on: October 27, 2017, 01:23:55 PM »
Hey Target!
I've had this idea for a while but my health is slowing me down to try it myself .
It's simply this make the core a couple of inches longer. But you have to make the root a little longer and the tip a little shorter. Then cut the cores out, being careful to keep them smooth as possible. Now if you stick those cores back in, they will extend past the tip and be inside the root. Put everything back in their beds and cut the wing panel to the correct size. Then pull the lighting cores out and cover them with clear packing tape and wax them real good and PVA them.  Next put them back in the wing cores and vacuum bag as normal. After curing, pull the lighting cores out and you have an extruded wing that should be light and strong.
Tim Thompson. aka RWCLOUD.
Offline Target
  • C/L Addict
« Reply #13 on: October 27, 2017, 02:44:54 PM »
Hi,
Yes, that is about what I have been thinking, but I don't see a reason to "core the cores" before I vacuum bag the skins on.... Am I missing something?
I would V-bag the panels first, separately, then core them, do the tip box, adjustable leadouts, bellcrank, then do the center joining and tips/flaps, etc....
I might evolve the plan as I go, but that is what I am thinking initially, anyway.
Should save a bunch of time finishing, and maybe some weight also.
A vacuum bagged carbon over balsa/foam profile fuse should be stiff and light too, I would think. And fuel-proof.
Thanks for your input. Please chime in if I am totally missing something, but I don't think I need to have the inner cores cut before vacuum bagging.
Vr,
target
Chris
AMA 5956
« Reply #14 on: October 27, 2017, 07:31:00 PM »
Hi,
Vr,
target
Well, twice I've "missed " while cutting the inner cores out.  This is despite having everything lined up or so I thought. Running a rod a couple of feet through foam is tricky, at least it is for me. I'd hate to vacuum bagged a wing, then poke an 1/8 inch stainless steel rod through the skin . If I miss before it's bagged then all I've lost is some foam.  But then again Phil Barns I ain't.
Offline Target
  • C/L Addict
« Reply #15 on: October 27, 2017, 08:13:19 PM »
The smart money is on hot-pokering only half way through as Phil shows in his videos....
I've already done it on an 8% thick sailplane core before, no problem, so these "fattie" Stunt cores, especially, a 1/2A at 17" per panel should be no problem. I'll have the luxury of the extra thickness.
I used the fixture he showed in the video.
I'm actually quite comfortable hot wiring foam. I've sold about 100 sailplane cores to various characters over the years, never had a complaint, but have had some compliments.
I'll have to make all new templates though for these fat stunt bastards. At least I don't have to worry about super accuracy, and I only need to make one template at each end for the zero camber profiles....
Nice to chat with someone that knows what I am referring to. (Whooo, buddy! as Shug says).
R,
Target
Chris
AMA 5956
« Reply #16 on: October 27, 2017, 09:40:40 PM »
Yeah, I  guess 8 1/2 inches would be no problem. Wow, didn't know you sold that many wings!
Best of luck with your project!
Blue Skies. .....Tim
« Reply #17 on: October 28, 2017, 10:42:51 AM »
I cut cores for my self with a set I got from an out fit.  I too learned that you can't core foam in the horizontal mode.  I post in the basement for holding the main floor joices that were vertical that I would clamp my fixture to for the rod and foam blocks.   Heat the rod red hot and release the clothes pin.  When it hit the floor I knew it was done.  Nice straight hole to feed wire through and then hook up the bow.  I even did a lost foam wing like Bobby sells.
Offline Target
  • C/L Addict
« Reply #18 on: October 28, 2017, 10:47:18 AM »
Gravity, while often our enemy, can be our friend, huh, Doc?!
Well done.
I use a plumb bob on setting verticals when I know the stab is level....
Chris
AMA 5956
Offline Target
  • C/L Addict
« Reply #19 on: October 30, 2017, 10:24:10 AM »
I actually printed out the tiles that were attached to my file. They look to be the accurate size to build from.
If i tape them together, i should have a working plan.
While it would be great to have a one piece sheet, this should be usable to build with.
Thanks,  Ty.
R,
Target
Chris
AMA 5956
Offline Jim Howell
« Reply #20 on: November 01, 2017, 09:04:30 AM »
Chris,
Jim Howell here.  I am the club member friend that got the plans for the 1/2A Cobra from the Chief, Ty Marcucci.  I don't know if you are still looking for info, but here's bit more.  The signature block, such as it is, says:
Cobra
Designed by Steve Wooley
Adapted to 1/2A by Howard Sullivan
Cad by Gene Rock 2004
Jim Howell
Jim Howell
Huntsville, AL  AMA 545805
Tags: extruded foam
