Building Tips and technical articles. => 1/2 A building. => Topic started by: Andrew Tinsley on December 03, 2012, 11:08:48 AM
Now it is getting really cold over in the UK, starting some of the small glow engines is becoming a pain. I have decided to make a small starter. Had enough of my flipping finger freezing when I get fuel on it!
Recommendations on motors need to be pretty international! Anyone come up with a neat idea for cones, switches etc? I am sure this has been done to death, but I can't seem to find the references. I suppose I could buy one from Towers, but not half as much fun as making one. Read that as me being a cheapskate if you wish.
Andrew.
Heavy duty Latex hose works for the spinner grabber. Maybe also some rubber lined automotive hose? Miller sells replacement liners made out of Urethane.
You will probably have to turn a holder for it.
I use a 1.3mAh 3s lipo to drive my old Miller 1/2A Starter. It uses a brushed motor, probably at least "Speed 400" size or larger, something around 4cm diameter and 8cm long. Housed in a bit of PVC pipe with a pushbutton at the back (I use my little finger to trigger it).
Thanks Larry,
Perfect information, now I can start making once I get a motor.
Andrew.
Hi Andrew,
My Sullivan 1/2A starter uses the Mabuchi RS-540SH motor model #7520 set up for CW rotation. This is a 4.8 to 7.2 volt motor that you drive for short periods with 12 volts to get the needed torque.
Orv.
Hello Orv,
Thanks for the tip about the Mabuchi motor, I can buy them quite cheaply in UK!
Andrew.
Go find a old battery drill. Take it apart and remove the reduction gearing.
I have a 9.6v drill based starter that is running on 12 volts for a long time.
find some PVC pipe it will fit in, and get a car horn switch from the local auto parts store
I use black fuel tubing from a lawn mower for a drive cone.
I bought a friend with a lathe a beer and he made a cup for the shaft.
I love your avatar, I haven't seen that artwork in over a decade!
I bought one of those lime green Sullivan 1/2A starters. It works great. The RPM is a lot higher than the big block starters. I find that reving it up off the engine, releasing the button, and engaging while it's coasting down provided just the right persuasion for the TeeDee .020 and .049.
I don't dare use it on a reed for fear of pushing the crank into the reed valve.
Cox Canada sells the washers to put between the drive plate and crankcase. No problem with electric starters then. It is a standard item in any engine I rebuild!
Hello Andrew
I used a Mabuchi 540 motor a nicad pack for a car cut down to fourcells,some wire,micro switch ,a small piece of aluminum round drilled for a set screw,piece of rubber hose and an L bracket to make my own.Here are some pics.
Juan, I like it! You may want to try some kind of flexible contact, weatherstrip, cement or silicon to hold the hose on. The zip tie could be dangerous.
Boy this brings back memories of many years ago when I first moved back to the KC area. Early 60's it was. Working at an injection molding plant. My brother and I worked there together. We got several guys started flying control line when Charlies Hobby Shop had a box of the McCoy .19 Redheads. Some where a little hard to start. One of the guys took a heater motor out of his car parts and connected a peice of garden hose. A push button switch and some electrical cable. Worked like a champ. It was quite a few years before I seen an electric starter advertised for R/C use.
Hey Doc, I remember when guys first started using starters back in the sixties they use Ford Thunderbird power window motors. Don't have a clue why it had to be a Ford Thunderbird window motor but that's what they used and they worked very well.
Andy
Hello David
The tie wrap has worked fine since I started to use the starter,I always use a TeeDee spinner on the engines I use a starter on. I make sure they are not flooded by giving them a few flips without the battery connected to the plug.
