  • July 07, 2025, 07:04:04 AM
Author Topic: 1/2A Pathfinder build log  (Read 19302 times)
Offline John Rist
« on: June 15, 2016, 08:41:46 PM »
I have started to build a Brodak 1/2A Pathfinder.  The kit seem to have good wood.  The only wood missing is the sticks required to do the fuselage and tail feather cutouts.  I did have a few minor problems figuring out how to do certain things.
The first was figuring out where to place the leveling stick that goes under the trailing edge of the ribs. The problem is that the pictures in the instruction book are faded and it is hard to see detail. It soon became obvious that the leveling strip went along the inboard edge of the trailing edge sheeting.  This caused the spar to be at right angle to the building board.  Speaking of the spar, when gluing on the plywood doubler place scrap piece form the wing ribs in several of the wing slots to make sure the notches are aligned.
The next problem was the cutting in half of the short ribs.  I cut them exactly in half. It is best to leave a little of the v notch on the top half of the rib.  This way it is easier to align the rib on the leading edge. Also it is necessary to keep the two halves of  each rib together.  That way they glue back together straight and true.  As you can see in the picture I laid them out on the plans as I cut then in half.
The line slider and wing tips were a little vague.  The 4-40 hardware that came with the slider seemed a little large.  I replaces it with 2-56 hardware.  I made a nut plate from a piece of tin stock with a 2-56 nut soldered to it.  The wing tip that holds the slider has it's center section removed to allow the lead-outs to pass through.  Before installing the wing tip I only cut out about a 75% gap.  Per the plans I then cut the notches for mounting the slider and glued the slider in place.  I then glued the wing tinp in place making certain it was centered.  After the last of the win tip ribs were installed I removed the reaming 25% of the gap. This assured the wing tip held is shape while being installed.
I built a sanding jig to taper the ailerons.  The strip of plywood glued to the base is the same thickness as the un-sanded ailerons.  I mark two sand-to lines on the to-be-thinned part of the ailerons.  The masking tape on the sanding block slides along plywood strip.  When sanding I check often to make sure I am sanding straight and am sanding to the sanding line.  Of course you flip the aileron to remove equal amounts from both sides.  I did not do the cut-out option of the inboard aileron.
The bell crank, aileron hinging, and aileron tips were all per the instructions and plans.  The out board aileron tip is mounted with the provided sheet metal tabs allowing it to be used as a trim tab.
So the wing is ready for it's final sanding and covering.  Next I will build the tail feathers.  I will do the lighting cut-outs and add the stick bracing on these parts.  I prefer a noise heave aircraft to a tail heavy one.  It takes a lot less weight in the tail to achieve the correct CG
Offline John Rist
Re: 1/2A Pathfinder build log
« Reply #1 on: June 15, 2016, 08:42:54 PM »
More pictures
Offline John Rist
« Reply #2 on: June 15, 2016, 08:43:47 PM »
The last of the wing pictures
Offline John Rist
« Reply #3 on: June 15, 2016, 08:48:52 PM »
OOPS two more pictures
Offline badbill
« Reply #4 on: June 16, 2016, 04:50:03 AM »
Great job, Thanks!
Bill Davenport
AMA 28141
Offline Duke.Johnson
« Reply #5 on: June 16, 2016, 10:10:45 AM »
What power system are you going to use? Nitro? Electric?
Offline John Rist
« Reply #6 on: June 16, 2016, 01:51:40 PM »
I have on hand a NV AMD 061.  I plan to run it on a balloon tank.
Offline Roger Vizioli
  • CLiner
« Reply #7 on: June 16, 2016, 09:48:59 PM »
John,
I have hundreds of flights on Pathfinder/Norvel Big Mig .061's combos.
Be interested in the performance w/ the AMD as I have two in the drawer.
Roger V.
Roger Vizioli
AMA L-2408
Florida/Space Coast
Offline John Rist
« Reply #8 on: June 17, 2016, 06:30:03 AM »
John,
Roger V.
What size tank and is it set up as a uniflow?  I have had good luck with balloon tanks but they require replacing the balloon.  A hard tank would be nice if it works well.
  • CLiner
« Reply #9 on: June 17, 2016, 07:48:07 AM »
John,
Tank is 2 oz Sullivan, only two lines , (1) brass feed line and surgical tubing to clunk, (2) fuel fill and "ram air" , line terminates in the "bubble on the tank. Fill by pointing nose down until desired amount of fuel is seen in in the tank or as measured from syringe.
I dont believe this will work w/ the AMD confi guration as they do require more fuel feed pressure than my Pathfinder config. will provide.
They do make a backplate with a pressure tap that I have not tried, might work!
I do use bladders on my 1/2A Barecat. There is a pic of it in the photo gallery section. district 5, 2nd row from bottom, left side (blue and white) Also pic of one of my Pathfinders , 16 rows up from bottom, right side .
Both are very capable performers.
Note: I do a dry assembly of my Pathfinders to get cg location. They normally build nose heavy. I dont like to add weight to a 1/2A if it can be avoided. I normally shorten nose 15/16" and cg is in area of those on plans. Never have added nose or tail weight for balance.   Finished model without fuel normally weighs 11 oz.
Any other questions, please ask
Roger
Roger Vizioli
AMA L-2408
Florida/Space Coast
Offline John Rist
« Reply #10 on: June 17, 2016, 08:19:36 PM »
Tail feathers are ready for shaping and final sanding.  I make cutout templates by copying the plans and use a glue stick to attach plan to part.  I then use a jig saw to cut out the center chunk.
Offline John Rist
« Reply #11 on: June 17, 2016, 09:28:42 PM »
I appears I am mistaken on what NV engine I have.  Per a NV blog web sight If you look in the muffler port you can see the inlet ports.  It says the AME will have 3 elongated ports and the BigMig will have 5 round ports.  Mine has the 5 round looking ports.  This blog post talked about an AME and a BigMig.  The current NV web sight lists an AMD and a BigMig.  I wounder what is the difference between the AMD and the AME.  Anyway it looks like I have a BigMig so it should run good as a 1/2A stunt engine on a standard tank.  I have had good luck with a balloon tank and I may use that.
Speaking of mufflers I don't have one for this engine.  NV sells one for this engine.  Would I really want to run a muffler on a 1/2A?
Offline Target
  • C/L Addict
« Reply #12 on: June 18, 2016, 12:11:04 AM »
 It's my understanding that the Big Mig is more of a low rpm, bigger prop (relatively) than the AME, which is more of a high rev engine.
If that is correct, you have the better of the two for stunt.
R,
Chris
Chris
AMA 5956
  • CLiner
« Reply #13 on: June 18, 2016, 07:03:33 AM »
Chris,
Agree, off to club annual picnic and some flying before it gets toooo hot! Will add more info re my config. tonight.
John,
Sorry I hijacked your "build thread".
Roger
Roger Vizioli
AMA L-2408
Florida/Space Coast
Offline John Rist
« Reply #14 on: June 18, 2016, 08:27:08 AM »
By the way looking at the picture below if I ever build another 1/2A pathfinder I would not cut the short ribs in half.  I would load then onto the spar before I installed the leading edge.  I would not glue them at this time.  When installing the leading edge I would glue the full ribs first and then square up and glue the short ribs last.  Should take less glue and save a little weight.  It would definitely be faster.
Offline Target
  • C/L Addict
« Reply #15 on: June 18, 2016, 10:02:19 AM »
It's, funny, I was wondering about that with the ribs myself. It would be interesting to hear what the designer had to say about that and why they instruct to do it that way.
I'm happy to read your thread.
Kind regards,
Chris
Chris
AMA 5956
  • CLiner
« Reply #16 on: June 18, 2016, 07:45:35 PM »
If you remove the head/plug assembly you can see the ports easily.
Roger
Roger Vizioli
AMA L-2408
Florida/Space Coast
  • CLiner
« Reply #17 on: June 18, 2016, 07:50:39 PM »
John,
I've always done it this way. It works!
Roger
Roger Vizioli
AMA L-2408
Florida/Space Coast
  • CLiner
« Reply #18 on: June 18, 2016, 08:00:17 PM »
Chris,
John,
Roger
Great picnic, good food, lots of flying!
My Big Mig .061's use a Galbreth (sp) head, two Norvel head shims, Nelson plug, APC 6x2 prop. Have never seen a need to go above 15% Nitro, power is more than adequate.Engines tach over 24000 on the ground and, if i remember correctly, run at ~26750 in the air (we have access to an audio tach). Lap time w/ 48' x .008 lines is 3.9 - 4.0 seconds..
« Last Edit: June 19, 2016, 07:39:32 AM by Roger Vizioli »
Roger Vizioli
AMA L-2408
Florida/Space Coast
Offline Target
  • C/L Addict
« Reply #19 on: June 18, 2016, 08:14:59 PM »
I just took the carburetor off my .061 and put on the venturi.
Now all I have to do is finish the 3 molded carbon racing sailplanes (that I install gear for other people in), then finish my 1/2A Stuka.
That's all....
Sigh.
R,
Chris
Chris
AMA 5956
Offline John Rist
« Reply #20 on: June 19, 2016, 08:49:12 PM »
Did the cutout on the fuselage.  Next step is to add plywood doubters and motor mounts.  I have a question.  Is the cowling and spinner ring add anything but good looks?  To save weight I plan to omit them.  Also it permits me to use lock nuts instead of blind nuts for mounting the motor.
Offline John Rist
« Reply #21 on: June 21, 2016, 07:34:03 AM »
By the way when you do the fuselage cut out you don't have any place to put the push rod flex guide.  Whats the fix for this?   ???
  • CLiner
« Reply #22 on: June 21, 2016, 08:55:36 AM »
John,
The .080" wire provided in kit will flex without a support.
I have used .10" OD  threaded one end, P'rod wire without flex support, never a problem. Clevis's both ends, one threaded/one slip fit JB welded on final assy. after flap/elev locked at 0 - 0 .
With the "current"  old pic posting problems, dont want to over load Sparky's repair tasks so sending my P'rod pic to your e-mail.
Roger
Roger Vizioli
AMA L-2408
Florida/Space Coast
Offline John Rist
« Reply #23 on: June 21, 2016, 09:46:41 AM »
John,
Roger
Got the picture. The .10 OD is 4-40 rode.  Sound like a the way to go.  Thanks!
Offline John Rist
« Reply #24 on: June 28, 2016, 02:53:08 PM »
its starting to look like a PATHFINDER.  I am covering the pieces separately.  Pictured is the start of a dry fit. As always, my finishes are 10 ft view-able only.   LL~
Offline John Rist
« Reply #25 on: June 29, 2016, 01:10:25 PM »
I was hoping for 11 oz.  Looks like it will be around 12 oz.  Should still be a good flyer.
Offline Target
  • C/L Addict
« Reply #26 on: June 29, 2016, 01:17:58 PM »
Might be better in wind at 12 oz?
What is the wing area??
Looking like maiden flight is drawing near, "YAY"!
R,
Chris
Chris
AMA 5956
Offline John Rist
« Reply #27 on: June 29, 2016, 01:40:54 PM »
R,
Chris
It has 236 sq in.  Nrvel .061 power.
Offline Target
  • C/L Addict
« Reply #28 on: June 29, 2016, 02:50:34 PM »
I'm going to run the same mill on my 1/2A Baby Stuka...I think the wing area is similar, might be a bit larger in fact.
I think I will need a 1-1/4oz uni-flow tank to be safe to fly a full pattern.
What size tank will you use? Balloon, muffler pressure, or uni-flow?
Chris
AMA 5956
Offline John Rist
« Reply #29 on: June 30, 2016, 04:29:48 PM »
Not sure what tank but I have had good luck with balloon tanks.
  • CLiner
« Reply #30 on: June 30, 2016, 06:03:50 PM »
John,
We have one in our club, never weighed , but i am sure it is 12 +++ oz. Yes, it is a good flyer!!!!    #^
Roger V.
Roger Vizioli
AMA L-2408
Florida/Space Coast
Offline John Rist
« Reply #31 on: July 02, 2016, 05:39:14 PM »
It all comes together.  Installing the wing.  Much checking to make sure it is all squared up.
« Last Edit: July 03, 2016, 06:24:05 AM by John Rist »
« Reply #32 on: July 03, 2016, 02:48:40 PM »
I like the transparency.  Beautiful construction. H^^
Offline Target
  • C/L Addict
« Reply #33 on: July 03, 2016, 04:23:02 PM »
Agreed. Looks great!
Chris
AMA 5956
Offline George
  • Love people, Use things.
« Reply #34 on: July 04, 2016, 08:12:04 AM »
I believe none. I think one is Cyrillic alphabet and one is the English translation.
Many fields require it. They work well plus you can tap the muffler pressure if you desire.
George
George Bain
AMA 23454
Offline John Rist
« Reply #35 on: July 05, 2016, 03:33:26 PM »
It's ready for engine test runs and first flight.  Thank is a 2 oz round set up as a uniflow.  Motor is a NV .061 Big Mig.  Finished weight is 12 oz.  I still have to make up a set of lines.  Whats a good starting length for this airplane.  I fly on paved circles that are set up for 70' lines, so space is not a problem.
Offline John Rist
« Reply #36 on: July 05, 2016, 03:35:05 PM »
3 more pictures.
  • CLiner
« Reply #37 on: July 05, 2016, 09:16:19 PM »
John, I dont know your flying experience but it s/b good based on your construction pics!!!!!  The plane will fly the full pattern!!
I fly on various lengths of .008" multi strand. (48', 46'). I also have a set of 45' for windy days and first flights. Have not tried the Spiderwire types, as yet.
FYI - with the shortened nose config I mentioned before, if tank is empty it will sit on three wheels and only takes a slight tap on the top of the rudder for the nose to lift and tail to make ground contact. Lap times of 3.95 - 4.1 are common on 48' lines.
Wishing you a great first flight. Please provide info after first flights!
thx,
Roger v.
Roger Vizioli
AMA L-2408
Florida/Space Coast
Online Larry Renger
« Reply #38 on: July 07, 2016, 07:48:39 AM »
Depending on where the elevator horn is set, you may have more flap throw than elevator. Consider moving the bellcrank to flap clevis down and the elevator drive clevis up.
Otherwise, it is gorgeous!!!  H^^
My electric version weighs about 14 ounces and does a very clean pattern. I think you will be very happy with this model!
Online Fredvon4
  • Central Texas
« Reply #39 on: July 07, 2016, 12:47:58 PM »
I like it but think the 2 0z tank will run that Norvel a long long time....grin
beautiful model and good build thread
Fred von Gortler IV
Offline badbill
« Reply #40 on: July 07, 2016, 01:20:05 PM »
Larry, Would you be kind enough to share your motor / esc / lipo setup?
Bill Davenport
AMA 28141
« Reply #41 on: July 07, 2016, 02:32:03 PM »
and pictures if you would.
Offline John Rist
« Reply #42 on: July 07, 2016, 05:37:45 PM »
I checked the elevator to flap throw.  The flap horn is long and the elevator horn is short.  It appears that I have around a 2:1 ratio between the two with the elevator moving the most.  The controls are all set per the Brodak blueprint and instruction book.
Offline John Rist
« Reply #43 on: July 11, 2016, 07:20:26 PM »
I started the test run process.  The NV 061 did not have enough suction to run a uniflow tank.  I did get in a test run in by removing the vent plug and running the tank as standard suction tank.  However it seemed that I was getting some variation from full tank to empty tank.  The uniflow tank was a Sullivan 2 oz round tank.  It occurred that this tank could be converted to a balloon tank by inserting a balloon. I have not test run it yet but this setup yielded a tank with a 1 oz capacity.  This should be enough for my needs.  Most of my flying is just sport flying.  I am planing to take a stab at the beginners pattern but I have many full size aircraft for this.
Offline Bill Adair
  • AMA 182626
« Reply #44 on: July 12, 2016, 12:08:47 AM »
Hi John,
Beautiful airplane!
Hard to tell, but it looks to me like the vent tube bends on your tank are nearly collapsed? Could they be limiting the air flow into the tank?
If you want to try muffler pressure I'll look in my tank stash to see if I have one with a pressure nipple. If I have one you can have it as I don't use mufflers on my Norvels. If you want to try pressure, send me your mail address by PM, or email it to the email address listed in my user profile.
Offline John Rist
« Reply #45 on: July 12, 2016, 07:15:42 AM »
Hi John,
Beautiful airplane!
Thanks for the offer.  Let me try the balloon tank set up first.    :!   I had a weird thought.  I have a balloon on the inside of a standard tank.  I bet muffler presser would work.  Vent the presser between the tank and the balloon.  The presser would squeeze the balloon.
  • CLiner
« Reply #46 on: July 12, 2016, 07:50:31 AM »
John,
Was it determined that the engine is an AME? If so, it does need pressure. i had a similar setup on a 1/2 A LL Stiletto and it would not run properly. changed to a bladder, problem solved. My Big Mig .061's will draw fuel from the 2 oz cylindrical tank.
Roger Vizioli
AMA L-2408
Florida/Space Coast
Online Larry Renger
« Reply #47 on: July 12, 2016, 08:55:49 AM »
The motor is a Turnigy D2826/6 2200kV. 6x4 APC prop, 1800 2s battery. I suspect that the esc is around 35 amps but the marking is buried next to the fuselage, so I can't see it.  H^^
Offline John Rist
« Reply #48 on: July 18, 2016, 12:13:23 PM »
Well I finally got an acceptable engine run from my NV 061.  The balloon tank didn't work all that well so I went to a bladder tank.  Starting a bladder tank setup is a bit of a pain, especially if you are alone.  It takes 3 hands, one to hold the airplane, one to hold the starter motor and one to release the fuel clamp. To solve this problem I made a tie down board to hold the airplane.  Once I got it set up and running I had rock steady RPMs till the last drop.  The bladder is inside a 4 oz Sulivan tank.  This is bigger than is necessary but it is what I had on hand and I needed the noise weight for proper CG.  I did have one bladder explode.  Being inside a tank contained the mess.   y1
« Reply #49 on: July 18, 2016, 12:19:57 PM »
Now I wait for the flight reports.    H^^
