Building Tips and technical articles. => 1/2 A building. => Topic started by: Bootlegger on April 27, 2020, 08:50:40 AM
Has anyone used the lines used for fishing on a 1/A model to fly with, and if so what size did you use and how well did they work? Thanks
Hi, Gil
I'm asking myself the same question.
Rusty Knowlton uses them with good results.
He's on the site somewhere.
I've been using Spectra for the last 7 years. I use 20# test mostly, as the local Fisherman's Warehouse didn't have 10# in the yellow high-viz spool. I sometimes use 10# if I don't care that the line is green instead of yellow. 10# is more than enough for the 5-7 ounce 1/2A planes I normally fly. If going with one of the heavier 1/2A planes, I'd stick with 20# test, although that's overkill.
Mark
For 1/2a I’ve used braided fishing line exclusively for several years. Very flexible. No stretch. Way more steady than Dacron. I use braided spider wire. 20# test. It is the same diameter as 6# monofilament. I do not recommend monofilament. Tried it, didn’t like it. There are several good brands to choose from. I think most people look for one that specifically says spectra on the package.
You have to make knots that don’t slip or weaken the line. I use a clinch knot because the main part of the line stays straight and all the twisty stuff happens on the tag side of the line connection. I also leave a short tag so it is easier to check for slippage. Lots of people swear by the palomar knot and it is a good one. Do not use a crimp or tie like you would on steel lines. It’s overkill for 1/2a and there’s to much chance of a crimp damaging the line.
After braided fishing line I would not go back to steel. I’ve never tried it on a larger model. Some people have and love it.
I usually keep 35 and 40 foot lines made up. I switch back and forth depending on the model and the wind.
At the risk of being overly repetitive, look for BRAIDED, not monofilament.
A suggestion only. There are other good knots and you may find one that works better for your use. I don’t always use the same knot.
Braided PowerPro Spectra, 30 lb test. Zero issues. Smaller works, too. Flying on this stuff is much more like using .008 stranded steel cable than the old 1/2A Dacron, but nowhere near the handling care required to avoid damage. Monofilament fishing line is a non-starter for model flying unless you are just G-lining a rock on a string.
The Divot
Wayne and all the others, THANKS for the help/suggestions this web site is great.. Thanks Sparky..
This is what I use
This is what I use
I also use 30# Spectra for 1/2A and second all the comments above. Brett submitted a proposal for the next rules change cycle on getting Spectra legalized for competition. Let's hope it finally passes.
Ara
Thanks for the illustration Wayne! Serendipity, I hope to tie some lines later today and just came here to see any new construction, the line discussion is a bonus.
Dennis
