  • August 02, 2025, 03:30:46 AM
Author Topic: Ehgine recommendations  (Read 1873 times)
Chris Wellington
« on: April 14, 2008, 10:21:46 AM »
What engines are recommended and available for 1/2a stunt that produce a reasonable sport performance ? Are the Brodaks acceptable current replacements for TeeDees on the Sarpolous warbirds etc?
Offline minnesotamodeler
  • Me and my Chief Engineer
    • Minnesotamodeler
Re: Ehgine recommendations
« Reply #1 on: April 15, 2008, 05:32:51 AM »
If "available" includes E-bay, Norvels are "it on a stick''.  Not being imported any more I guess.
I have a Brodak first generation .049 that is generally reliable but low-power.  Don't know about the later version(s).  I'd recommend an .061 (AP Wasp is available) but some joker's bound to jump in and point out that's not really 1/2A. So sue me.
--Ray
AMA902472
« Reply #2 on: April 15, 2008, 07:25:40 AM »
Hi Ray,
Have you tried the Brodak .061??  I am guessing it could possibly match a TD?? (or at least fly the Sarpolus Warbirds, I am sure)
Offline John Crocker
« Reply #3 on: April 15, 2008, 08:41:49 AM »
My votes for the AP .061, MUCHO power, but as Ray said, its not really 1/2A
    • Minnesotamodeler
« Reply #4 on: April 15, 2008, 08:56:08 AM »
Hi Ray,
I have not, Bill...it may well be a great little engine.  I've not even seen one run, know nothing about it.
--Ray
AMA902472
Offline Larry Renger
« Reply #5 on: April 15, 2008, 09:14:56 AM »
The AP Wasp is a superb running engine, and the only small engine I know that has a bronze bushed crankcase.  I have run 3 of them, and all were good runners, easily equal to the Big Mig Norvel .061.
For an .049, the Medallion from C*x has a great stunt run.  Also the Norvel Big Mig .049 if you can score one.  The MK I Brodak is an excellent choice if you add the Nelson Head, but that makes it cost about $80 total!  Tee Dee .049s run strong, but need pressure to be reliable, and won't swing as big a prop as the Medallion without overheating.
The old Atwood Shriek will pull through maneuvers well and has about the power of the Medallion, but uses smaller props to do it.   I suspect that the Holland Hornet could work well if you restricted the venturi.  I have never run one except on a free-flight, so I can't really say.
My painful experience has shown that only the C*x engines are happy with props as big as the C*x 6x3.  All the others should use things like the APC 5.7x3, or 6x2 and older props like the Tornado 5x3.  Otherwise you will get overheating about half way through your flight.  C*x engines are happy with up to 30% Nitro, the others should stay under 20%.  20% oil, half and half is good for all these engines.  More oil doesn't hurt anything but gas mileage.
 H^^
PAW diesels are also an excellent alternative, and can swing BIG props with ease.  Just be sure to use Neoprene or Vinyl fuel hose, not latex or Silicone.
« Reply #6 on: April 15, 2008, 11:54:43 AM »
AS far as fuel goes, my AP's love PowerMaster 20/20 and i'm using Master Airscrew 6x3's cause thats what I could find.
    • Minnesotamodeler
« Reply #7 on: April 15, 2008, 04:29:08 PM »
I'm running a 3-blade 5x3 on my Norvel .061 in the LittleAxe and it is the perfect combination!  Next best is APC 6x2. I use everything from  5.7x3 down to 4.25x3 on the various .049s I have.
--Ray
AMA902472
