  • August 05, 2025, 07:44:16 AM
Author Topic: Fuel for 50s & 60s Cox , OK Cub and Wen-Mac Tether cars with .049 engines  (Read 2612 times)
Offline Frank Imbriaco
Getting back into these. Now that these manufacturers  are no longer are in business to manufacture engines or  fuel, what is recommended as far as nitro & oil percentages ?  Oil- castor , synthetic or a blend?
These engines have different requirements than air versions.
If you know of any manufacturer producing fuel for 1/2A s, I'd be interested in that , too.
Offline Mark Boesen
    • 049 Collectors
1/2a's like a higher Nitro level then normal R/C fuel, about 25%. Oil percent (all caster or at least 50/50) should be 18-20% for Coxes and probably higher (25%-28%) for the Cubs and Wen-Mac as their tolerances aren't as close as the Cox engines and will wear fast.
Surf the 'net for 1/2a engine fuel, they're several companies making fuel that fit these specs.
Good luck,
Mark Boesen
http://groups.yahoo.com/group/049Collectors/
Offline david beazley
I use Sig Champion 25% nitro.  Works good for me in Cox, Norvel, Fox, 1/2A's.
AMA # 2817
Tower sells a quality 1/2 A fuel with 25%  nitro and 18% Klotz oil, but ouch  $7.99 for 8 ounces !
Glad my thirsty R/C engines don't need that stuff !!
Offline Dennis_Langworthy
There is also a guy on ebay that sells fuel.  His name is glowplugboy.  Cox International also has some info on their site about mixing your own fuel.
http://coxengines.ca/pages.php?pageid=5
I do not have a local source (hobby shop is great, but about an hour away through tough traffic! LOL!!) so I have bought the 1/2A fuel from "Glowplugboy" on ebay.  24% Nitro, 17% all castor.
Kinda steep, $10 a quart IIRC, plus shipping, but a quart goes a long way with 1/2As! LOL!!
I would also use the Sig Champion 25% if I could get it.
Big Bear
