  • July 31, 2025, 02:59:50 PM
Author Topic: 1/2a display stands  (Read 3694 times)
Offline Dane Martin
  • heli pilot BHOR
1/2a display stands
« on: November 03, 2020, 07:10:15 PM »
My buddy 3d printed some display stands for me.
I mounted a Holland Hornet and a K&B stallion 049 just to see how cool it is. It turns out it's prett cool!
Offline Dane Martin
  • heli pilot BHOR
Re: 1/2a display stands
« Reply #1 on: November 03, 2020, 07:10:49 PM »
K&B 049 under construction
Offline Larry Renger
« Reply #2 on: November 03, 2020, 09:41:45 PM »
The ideal display stand for a Holland Hornet is a Toshi Matsuda free flight Zero floating in a thermal. 👍
Offline Dane Martin
  • heli pilot BHOR
« Reply #3 on: November 03, 2020, 09:47:33 PM »
I'm actually building a Satellite 320 and a Ramrod 1/2a. I was considering either of those. However, I couldn't stand the thought of losing it, so I'm saving up for an RDT system so I can bring it down in case of trouble!
These stands are really for my ok Cubs and wenmacs. But this looked sweet for now
Offline john vlna
« Reply #4 on: November 04, 2020, 10:38:36 AM »
I mounted a Holland Hornet and a K&B stallion 049 just to see how cool it is. It turns out it's pretty cool!
Yes they are cool, I really like the idea. The 3D printing is opening up all kinds of modeling opportunities we never thought of before.
Offline Dane Martin
  • heli pilot BHOR
« Reply #5 on: November 04, 2020, 02:00:21 PM »
Here's another one. One of my OK Cub 049B engines.
« Reply #6 on: November 04, 2020, 04:37:07 PM »
Definitely best possible use for a stock Cub.
Oddly, Cubs can be made to run very well. Clean up the crankshaft porting, balance the shaft, clean up the burrs in the bypass ports and run high nitro and they will absolutely scream on small props. They have very low compression ratio, so a hot plug and hot fuel are tolerated very well indeed!
Oh yes, replace the needle assembly with one from a Cox ready to fly engine. A fun project, but not unless you really, really want a hot Cub just to say you have it.
I flew one at Taft on a 1/2 A Spacer, and walking back from retrieving the model one guy who saw the flight eyes bugged out and said “THAT’S A CUB?” Guess I got it right.   ;D  I was using 60% Nitro +P fuel, but that is what makes a Cub sing.
Or buy a better engine..... VD~
Anyone want to run a Cub RPM contest? Now THAT could be a challenge. Say specify APC 5.5x2.5 prop and 30% nitro fuel. (Or higher if readily available). Don’t look at me, I no longer have any fuel stuff. Totally e-power now, but will happily talk to people in the real world.   >:D
« Last Edit: November 04, 2020, 04:58:57 PM by Larry Renger »
Offline Dane Martin
  • heli pilot BHOR
« Reply #7 on: November 06, 2020, 09:09:59 AM »
I'd be in for an RPM challenge!
If anyone is looking to display their engines, here's the link
https://themakermedia.com/collections/drone-accessories/products/cox-model-engine-display-stand
Offline Chancey Chorney
« Reply #8 on: November 06, 2020, 03:47:39 PM »
Great looking stands your friend printed for you there.
