  • July 08, 2025, 01:52:38 AM
Author Topic: blank  (Read 1689 times)
blank
« on: April 04, 2013, 08:19:38 PM »
blank
« Last Edit: September 06, 2021, 06:15:19 PM by Motorman »
Offline pat king
    • PDK LLC
Re: 1/2A Design Help
« Reply #1 on: April 04, 2013, 09:52:55 PM »
Send me an email at: patdk at aol dot com and I'll send you a full size .pdf of my Ringmaster 150. It has a 26 1/4" wingspan and 150 square inches of wing area. It has won 1/2A stunt contests.
Pat
Pat King
Monee, IL
AMA 168941
Offline Duke.Johnson
« Reply #2 on: April 04, 2013, 10:15:57 PM »
Pat
Is te RM 150 the same as the electric?  I think I have your plans for that.  This would be what I was talking about for a TD carrier plane.
Duke
Online Curare
« Reply #3 on: April 04, 2013, 10:48:52 PM »
Greg Kowalski
AUS 36694
Offline bob werle
« Reply #4 on: April 05, 2013, 06:34:23 PM »
The White Lightning is a great little 1/A plank wing ship.  My thumbnail print shows me with mine.  It builds easy and flys great.  Mine had a Brodak .049 MK II.
Bob
ama 5871
Offline kenneth cook
« Reply #5 on: April 05, 2013, 07:25:45 PM »
                         I found the White Lightning to be problematic. In fact it builds so incredibly tail heavy I don't know how you would balance it using a TD .049. I rubber banded a TD .09 to it and it balances perfectly. The TD .09 is 2x the weight of the TD .049. I sent e-mails to the designer who claims that by no means should I change moments and that I should just add the required nose weight. A sheet wing when designed like the plan shows flexes far too much which totally kills performance. You would find a built up wing to not only be stronger, but it would fly far superior to a sheet wing. I feel that Pat's recent plane that was on paper the Pegasus would give extreme performance. There just isn't many options as many are for reedies. Ken
Offline Larry Renger
« Reply #6 on: April 05, 2013, 09:33:15 PM »
Take a look at the SkySport from RSM. It will fly great on a TD .049 on 37.5' lines.
« Reply #7 on: May 13, 2013, 11:14:10 AM »
My two favorite flyers are a pair of Baby Flite Streaks, one with a Tee Dee .051 and the other with a Big Big .061. I fly them both on 45' lines, the Tee Dee with a 5.25x3 prop and the Big Mig with a 5.5" or 5.75x3 prop. I've been building kits since I was a kid, but with no experts to help me. And when I flew my first Baby Streak, I felt like I was flying my first plane that wasn't a toy.
Offline john vlna
« Reply #8 on: May 13, 2013, 02:03:40 PM »
If you are looking for 1/2A carrier ideas check this thread, http://stunthanger.com/smf/index.php?topic=29888.0 I posted some plans on it .
