  • July 31, 2025, 02:09:38 AM
Author Topic: Cox .074 vs .090 IDent  (Read 2811 times)
Offline Gordon Tarbell
« on: May 24, 2025, 08:18:49 AM »
I have been cleaning out a fellow modeler's building room that passed away . In the engine drawer were two Cox engines that look like they could be Medallion .074 or .090 . There were no boxes for them and they are not marked, How do I know what size they are ? easily larger than the .049/.051s that I have had but not as big as the .15 Cox engine. The plastic venturi body is red and the prop hub is silver. I think it is a later production since it has a large diameter rotating barrel around the base of the cyl.  I would post a picture but not sure I can (tech challenged at 69)
Gordon Tarbell AMA 15019
Offline bill bischoff
Re: Cox .074 vs .090 IDent
« Reply #1 on: May 24, 2025, 01:59:27 PM »
There is no such thing as a Medallion .074. The only Cox .074 I know of is the Queen Bee, and it has a rear reed valve rather than a shaft rotary valve. It is quite obviously different than a Medallion. The rotating barrel around the cylinder may be an exhaust throttle.
« Reply #2 on: May 24, 2025, 02:29:45 PM »
Ok so that makes this an .090 then? It looks like a beam mount TeeDee but integral plastic venturi as part of the red portion of the case.≈
« Reply #3 on: May 24, 2025, 05:11:50 PM »
Yup.
Offline 944_Jim
« Reply #4 on: May 25, 2025, 01:10:12 PM »
There is a .09, and a .15. Post your head diameters, or wait until I measure mine. I have a couple of each.
Here is some reading material in case you want to brush up. Look to the left for Medallion and Tee Dee:
https://www.mh-aerotools.de/airfoils/cox_frameset.htm
Are you thinking of selling?
Offline kenneth cook
« Reply #5 on: May 25, 2025, 05:37:55 PM »
              In addition, a .09 uses a 6-32 prop screw and the .15 uses a 8-32
« Reply #6 on: May 26, 2025, 09:02:56 AM »
Fins on cyl head/glow plug measure .925"
« Reply #7 on: May 26, 2025, 09:05:39 AM »
Would like to build small stunt ship , maybe even a twin stunter since I have two. I have Bob Duncans twin Imitation with two LA 25's and it flies great.
