  • July 31, 2025, 05:01:20 PM
Author Topic: That "new" SkyWriter construction  (Read 2089 times)
Offline minnesotamodeler
  • Me and my Chief Engineer
    • Minnesotamodeler
« on: November 12, 2007, 09:22:05 PM »
here's my SkyWriter's latest configuration, trying to pare a little weight off the tail and kill two birds with one stone (lose a little weight; move the CG forward a little).
First, the hollowed fuselage:  Basically 1/4" thick balsa with cutouts and diagonal bracing; sheeted with 1/32" balsa aft and 1/32" plywood forward.  It did come out lighter, and as an added bonus, stiffer!
--Ray
AMA902472
    • Minnesotamodeler
Re: That "new" SkyWriter construction
« Reply #1 on: November 12, 2007, 09:29:51 PM »
Next, the wing:  Hollow ribs, tips and an interior spar that stops short of full span.
Added point of interest:  3 1/4" bellcrank (3" LO to LO) with 5/8" pushrod arm--makes for slow, smooooooth controls--helps cure the 1/2A jitters.
--Ray
AMA902472
    • Minnesotamodeler
« Reply #2 on: November 12, 2007, 09:31:46 PM »
Here's the complete bones (disregard the pins aligning the rudder, it wasn't dry yet)...with engine/tank, it weighs right at 6 oz. as is.  Figure 1 - 1 1/2 oz. covering and finishing, and I've managed to lose an ounce or a little more from the original prototype.  210 sq. in. carrying a little more than 7 oz., well, I'm satisfied with that. Original, at 8 1/2 oz. or so, flies very well with a Norvel .049.
Point of interest:  I was looking at some plans online and noticed landing gear wire bent so that the wheel is against a 90 d. angle.  I copied it, see in last pic below.  Prevents the wheel from riding up on a shallow angle and jamming. I like the look besides!
Tank canister is in backwards to make use of the angle caused by the larger-diameter lid.  Puts the fuel pickup outboardmost, if that's a word.  It ought to feed better at the end of the run, and quit more cleanly.
Engine outthrust accomplished with pieces of spring-clothespin handle--the perfect taper, and nice dense wood besides.
« Last Edit: November 13, 2007, 07:34:31 AM by minnesotamodeler »
--Ray
AMA902472
Offline Mike Spiess
  • bikemike
  • AMA #4060
« Reply #3 on: November 13, 2007, 09:47:43 AM »
Looks great when are you going to kit it and make the big bucks$$$$$$$$$$ LL~ LL~ LL~ LL~
No seriously I would imagine it will fly great.
You don't stop flying cause your get OLD
You get OLD cause you stopped flying
St Peter MN
Present Master of the Figure 9
    • Minnesotamodeler
« Reply #4 on: November 13, 2007, 02:51:02 PM »
Look for it next Spring...
...and it does.
--Ray
--Ray
AMA902472
« Reply #5 on: November 17, 2007, 07:46:30 AM »
Looks great in the bare bones.  Put the old DOC on the want list also for a kit.  Have fun,  DOC Holliday
    • Minnesotamodeler
« Reply #6 on: November 17, 2007, 03:35:19 PM »
Got it, John.  Thanks!
--Ray
--Ray
AMA902472
