  • August 01, 2025, 08:17:48 PM
Author Topic: 1/2 A PATHFINDER  (Read 3334 times)
Offline Vincent Corwell
1/2 A PATHFINDER
« on: August 22, 2007, 06:21:01 AM »
Hi all
now have 2 flights on my Brodak 1/2 A Pathfinder with AP wasp 061
see picture in posting May 30 this year
flies really well 35' lines ( I only had 018 in stock ! )
added tipweight for 2nd flight did all the round stunts no problem
weather was very blustery and did not try any overheads, now waiting
for time and weather to come right for more flights
Quite happy so far
Vincent
Offline Larry Renger
Re: 1/2 A PATHFINDER
« Reply #1 on: August 22, 2007, 08:52:35 AM »
Get yourself a set of 50'x.008 lines and you will be amazed at the difference!  Perfect square and triangles will be within your grasp.  35' isn't enough room, and the burden of weight and drag of the lines you are using are killing your performance.
