  • June 18, 2025, 06:20:50 AM
Author Topic: 1/2 A fuel Hose! Great stuff  (Read 2539 times)
Offline Larry Renger
« on: November 07, 2008, 10:04:41 PM »
McMasters Carr, which has an online website sells silicone hose in a variety of sizes.  One is absolutely the best I have seen for 1/2A use!  It is .125 OD and .078 ID.  Big enough to pass fuel easily, small enough to fit the 1/2A fuel nipples, and very flexible.  Pricey at $0.89 a foot in 50' quantities, so I now have 50'.   ~>  Let me know and I will part with it at $1/foot including shipping.  5' minimum (considering the cost of a 1 ounce letter, I exactly break even!)
Or you can order your own stash!  It is good stuff!
Offline minnesotamodeler
  • Me and my Chief Engineer
    • Minnesotamodeler
Re: 1/2 A fuel Hose! Great stuff
« Reply #1 on: November 08, 2008, 06:39:02 AM »
Hey Larry,
I'll take 5' of it now just to see, more later if it works well.  $5 to you ASAP.  Thanks.
P.S. Sent you a PM.
--Ray
AMA902472
Offline jamtx
« Reply #2 on: November 09, 2008, 02:47:59 PM »
I'll take 5' also. Pm sent.
 James Karnes
James Karnes
Abilene,TX.
« Reply #3 on: November 10, 2008, 11:17:04 AM »
Just an interesting update:  I have a Baby Clown which I set up to take a Space Hopper engine (precursor to the Tee Dee, but reed valve, and a darn hot runner usually).  With standard small fuel hose, the engine would not run.  Simply could not suck fuel through the standard small ID hose.  I put on some of the new stuff and it runs gangbusters!  Happy me!!!   #^
    • Minnesotamodeler
« Reply #4 on: November 10, 2008, 02:37:28 PM »
I actually use "large" fuel line with my production Coxes, 'cause it's stiff enough to poke down thru the channel in the backplate & slip onto the fuel nipple. On the other hand, I have a Brodak .049 that won't hold anything bigger than "small" on its NVA. Looking forward to getting your fuel line, maybe it'll work for everything.
--Ray
AMA902472
Offline kenneth cook
« Reply #5 on: November 10, 2008, 03:01:25 PM »
        LARRY, would this fuel tubing work for the Cox tubing thats used on the internal fuel tanks? I was just asking a club member this weekend about the type that was used inside of the Cox engines. The older style Black Widows and Babe Bees used a small diameter hard tubing. The newer versions used a slightly larger more flexible tubing used on the plastic backplates. I've been trying to switch to all die cast backplates due to the failures of my plastic ones. A lot of my 1/2 a planes now are using external tanks. My son has intiated some of the club members to try some 1/2 a mouse racing. I've been searching for any way possible to recondition and hop up my black widows. Not to change the subject, we just bushed a crankcase with an oillite bearing. I've been noticing most of my crankcases from the 80's are now terribly worn out . I noticed most of the fuel pick up tubes were in very bad shape when we dismantled these engines. Hopefully, if the weather holds out a few more weeks we can get a few races in.   Ken
« Reply #6 on: November 10, 2008, 05:21:36 PM »
The hot tip on internal tank fuel hose is to use aluminum tubing bent to put the pickup exactly where you want it.  Then use a bit of silicone fuel hose as a coupler to the backplate.
Yes, for some years (before I fixed it) the plastic backplates had a sharp corner at the bottom of the screw recesses.  These would split open at the least provocation.  I don't know where the other guy went to school, but WE learned about stress risers and adding radius to inside corners.  Added the radiuses, end of problem.
Could you please outline how to add oilite bushings to a Cox crankcase?  Where do you get the material, how do you prepare it, assemble it and match it to the crankshaft?  Would you do this for others as a (paid) service?
« Reply #7 on: November 10, 2008, 06:58:34 PM »
          Larry, for quite some time now I've been constantly asking myself why one Black Widow works better than some of the others. I noticed the majority of them which I purchased in the early eighties have a lot of side to side crankshaft play. This wasn't always a bad thing until the point in which they just wouldn't turn up like they used too. The engines would develop a harmonic vibration which would kill rpm's off. This was audible in flight as well. I would go through my junk pile of Cox parts and search for better fitting cases. You had mentioned before of polishing Ok crankshafts in a drill press. I took this idea and applied it as well to the cases when I'd retrofit them. This brought back a lot of life in these engines. I discovered that any varnish in the oil groove would act as a brake when the engine got hot and surely wouldn't allow the rpm's were lookin for. I talked to Dan Banjock about this and we figured we could bush the case provided there was enough room. We discovered several things prior though. The Sure Start cases seem to very soft compared to the older 70's version cases. We also figured the anodizing in the Black Widow cases allowed for tighter fits at least until the anodizing wore off. The eighties version Black Widow case is what we opted to use. Dan made a jig to hold the case which bolted to the back of it. He then bored the hole for the new bearing. He didn't want to have to machine the bearing from the inside once it was installed so using the same jig he pressed the bearing until it seated on the jig. We discovered that some of the cases had a bit of a difference from back of drive plate to the inside of the case where the crank seats. Dan also filed an oil groove in the bearing just like the stock case had. I ran the engine this past weekend for the first time. I didn't fly it yet but I was very shocked in the smoothness of the ran. Dan and I want to tach the engine as it is currently then take the piston cylinder off and switch it into another case and check the rpm's. Dan feels if we don't see a significant increase in rpm's its just not worth it. I feel otherwise though. First off, he's already made the jig to hold the case in the lathe, the longevity of this case makes it worth it. I will let you know more about this engine. I have a few others that I'd like to see done.  Ken
Offline Bootlegger
« Reply #8 on: January 13, 2013, 06:26:57 AM »
  Larry, do you have a part # for this tubing?  Thanks
8th Air Force Veteran
Gil Causey
AMA# 6964
« Reply #9 on: January 14, 2013, 11:21:27 PM »
It seems that Small Parts company no longer exists. Major bummer! Anyone know of a similar company?
You should be able to look up the hose in the McMasters-Carr online catalog. Look at silicone hoses
« Last Edit: January 15, 2013, 08:58:33 PM by Larry Renger »
Offline Curare
« Reply #10 on: January 15, 2013, 08:35:18 PM »
Here's something for you guys that run the little teensy cox motors, like tee dee .010 and .020's.
Finding fuel tube small enough that's not vinyl and goes hard is a pain for most modellers, but if you have friends who fly electric, see if they can strip some 14AWG wire, the sheath is silicon, and works wonderfully as fuel tube. Also it comes in either black, or red, which as you know goes faster.
I guess you could also use 12AWG for .049's and the like too.
Greg Kowalski
AUS 36694
