Vendors Corner => RSM => Topic started by: eric rule on July 20, 2012, 09:00:21 PM
The machine shop finally delivered my 4" Carbon Fibre Bell Cranks.
They are CNC machined from commercial grade 1/8" thick carbon fibre sheet. This means there are no "voids" in the material that you often get with hand layered carbon fibre. The bushing is a high tech material similar to what is used in computer hard drives. It has a very low coefficient of friction so movement is silky smooth. We bush the line end holes with brass so that you do not have to bend tubing.
Cost is $19.99
What are the dimensions?
Hi Milton;
The bell crank is 4" between the eyelets. Material is 1/8" thick commercial CF sheet.
Regards
Eric
Looks good, Eric!
