  • April 16, 2024, 11:38:09 AM
Author Topic: Frank Bowman  (Read 6659 times)
Offline Louis Rankin
Frank Bowman
« on: March 06, 2007, 08:05:50 AM »
Everyone knows that Frank produces outstanding rings; however, he also produces wrist pin and crank pads.  I have been converting McCoy 40 Redheads to McCoy 40 Hybrids.  The Series 21 wrist pin used in the conversion always needs new teflon pads.  I was pulling my hair out trying to find wrist pin pads.  I contacted Frank on a hunch and discovered that he produces them.
The pads are reproduced very exact and the fit is outstanding!  Thanks Frank!!!!!!!!!
« Last Edit: March 06, 2007, 12:30:15 PM by Louis Rankin »
Louis Rankin
Somerville Tennessee
AMA 10859
Re: Frank Bowman
« Reply #1 on: March 06, 2007, 12:57:50 PM »
Hi Louis,
Frank makes a lot of really good products!
How do you machine the Red cases for the Series 21 jugs to fit?  I have done the 35 ansd 29 with no problem.  But I run into an interference with the 40s.
Bill <><
Re: Frank Bowman
« Reply #2 on: March 06, 2007, 03:39:16 PM »
Bill,
No machining is necessary.  The Series 21 piston fits in the Red Head liner.  Take the Series 21 piston, head, rod, and wristpin and install in the RH case.  Mount an APC 10.5 X 4.5 and go fly.
Louis Rankin
AMA 10859
Re: Frank Bowman
« Reply #3 on: March 07, 2007, 08:12:29 AM »
Bill,
I have been swapping the entire *jug* for the other sizes.  DUH!  I just didn't try the piston *by itself*.
Thanks, Louis.
Offline Chris Fretz
Re: Frank Bowman
« Reply #4 on: April 05, 2016, 07:37:03 AM »
What do you use now that Frank is retired? If your are still using the series 21...
Formerly known as #Liner
AMA 1104207
Advanced
