Okay, now that I've got a bunch of good input, that I totally appreciate, thank you, and I really mean that. I know there are already some good twin engine designs out there, I've seen the Twin Pathfinder fly and like everyone says its a super flying plane. Now, I want one that is kind of my own aesthetic design, even though I will probably borrow, steel, copy and whatever else I can come up with, from other peoples designs and have what I am working toward. I have the plans drawn, it will use one of Randy Smith's Vector wings in the 610 to 630 sq. in. range. The weight I'm shooting for is in the mid 40 range and this will be a profile fuse with the twin nacelles. The reason for the OS .30s's engines is the weight at 7 ounces, so that is 14 ounces of engine weight, plus they only use about 3.5 ounces of fuel, and a 9x6 prop of some brand, probably wood. That is 18 inches of prop zipping around. Hopefully I can get the remainder of the 26 to 30 ounces of weight together in an achievable fashion.
The other reason for the OS .30s engines is I have a couple and Randy says he has some, so they are not unobtainable (yet). At best this is an experiment to see if it will work. Hopefully by use of other peoples ideas and designs it has a somewhat probable chance of working.
