Right, if you don't know that, you're stupid. John Garlist told me that.
I can't wait to see the engine, stroked 2", turn those pistons around 450 times per second. Don't stand too close! One also wonders how much boost pressure it takes to shove ~1000 hp through a sidevalve setup. A Fox 35 would still win the NATs every year if the judges weren't biased, er, oops, getting my idioms mixed up...
That's why I don't think this is actually serious - it has to be a parody. Although there was another "bigger flywheel for more torque" sighting, so maybe not.
Uh, as I see it he is completely eliminating the valve train, no facility or accommodations in the block for valves to go with the flat-heads,, one wonders if that's maybe the true secret he is keeping guarded,, I mean heck, we all know that the rpm limit on most rocker arm motors is the valve float component,, with no valves to float( or lifters) the rpm limit would be sky high,,
of course there is the little issue with getting fuel and air into the silly thing,, but hey thats small potatoes
