  • April 25, 2024, 10:04:12 AM
Author Topic: Lines for ringmaster  (Read 2383 times)
Offline philip metzner
  • chevyiron420
« on: June 03, 2010, 09:35:22 PM »
I'm trying to get my S1A ringmaster in the air. Digging through my stuff i found a set of brodak braided steel lines that measure .015 with my caliper, and 50 ft long. Will these work ok?
Re: Lines for ringmaster
« Reply #1 on: June 03, 2010, 10:31:00 PM »
   For the time being. That's awfully short, need more like 56-58 I would think.
Offline peabody
« Reply #2 on: June 04, 2010, 07:41:39 AM »
What Brett says....
Most of the better flying ones locally use 56' eye to eye...
60' seems way too long.
Have fun!
Offline Allan Perret
  • Proverbs
« Reply #3 on: June 04, 2010, 08:13:18 AM »
I fly my Ringmaster/Brodak25 on .012 x 58'.
Allan Perret
AMA 302406
Slidell, Louisiana
« Reply #4 on: June 05, 2010, 08:47:40 AM »
If that is all you have right now go for it.  Just be prepared to rotate a little faster.  Or use a low pitch prop.  Just flew a John Lowrey Stuka on 52  foot lines by .015.  They are my scale race lines.  Power is LA .25  with 10-5 prop.  Felt good until third flight when engine decided to go rich at a bad point in outside loop.  Plane is fine.  the prop and needle valve assemble are trash.  I used to fly the log 1/2A's(Scientific kits) on 15 foot of line as that is all I had room for safely.
