  • April 25, 2024, 09:12:49 PM
Author Topic: FP .20 Fuel Consumtion  (Read 2093 times)
Offline Larry Fernandez
« on: May 20, 2017, 03:17:09 PM »
Its been a while since I have run an FP .20 and I'm currently building a Top Flite Peacemaker powered with the FP .20.
I'm building tanks today and don't know how big to make it.
How much fuel can I expect to burn for a seven minute pattern?
Brett?
Larry, Buttafucco Stunt Team
Re: FP .20 Fuel Consumtion
« Reply #1 on: May 20, 2017, 03:44:31 PM »
   Around 2 ounces. I would make the tank about 3 ounces to accommodate up to 20% nitro, or a "new" 25LA, if you are building the tank into the airplane.
« Reply #2 on: May 20, 2017, 04:31:56 PM »
Thanks buddy.
I'll post pix of the Peacemaker later.Its pretty damn cute.
One of my dads favorite.
« Reply #3 on: May 20, 2017, 09:03:28 PM »
Which version are you building?
« Reply #4 on: May 20, 2017, 09:41:53 PM »
From Model Airplane News, April 1960.
Top Flite kitted it a couple of years later, but used that funky-ass "Super Form" fuselage construction.
Online wwwarbird
« Reply #5 on: May 21, 2017, 07:07:33 PM »
 Brett,
 What prop, fuel, and launch RPM would you use with the FP.20 here?
« Reply #6 on: May 21, 2017, 07:39:22 PM »
 Brett,
  APC 9-4, and 10% nitro 18-20% blend, and about 12500. Set engine to peaked out, then back off until there is a noticeable RPM drop, maybe 5-6 clicks. Engine/muffler should be BONE STOCK, no changes whatsoever, stock needle/spraybar, stock venturi, stock muffler including internal cone.
« Reply #7 on: May 21, 2017, 07:42:20 PM »
 Brett,
I had good luck running an FP .20 in a Still Stuka, set up with a APC 9x4 prop, Power Master 10% nitro 20% oil 50/50 castor-Klotz I think I launched at just under 12K
The Peacemaker and Still Stuka are pretty much the same size so I expect the same performance.
Another note, I flew the Stuka on .012 lines 59 foot long.
Larry Buttafucco Stunt Team
Online wwwarbird
« Reply #8 on: May 21, 2017, 08:07:09 PM »
 Good info, thanks guys!
« Reply #9 on: May 21, 2017, 08:10:48 PM »
AFAIK you want the E-2030 muffler -- some FP20 engines came with one bearing a 3-digit part number, which doesn't have the magic.  I think.  Maybe.  If Brett says I'm right.
