  • April 24, 2024, 05:30:37 PM
Author Topic: Question about Randolph non-tautening green nitrate  (Read 1021 times)
steven yampolsky
« on: May 22, 2012, 08:05:27 PM »
I have a question for the users of Randolph "green" nitrate(G-6302). The product is supposedly non-tautening so what do you use on open bays to tighten paper over the bays?
Offline Allan Perret
  • Proverbs
Re: Question about Randolph non-tautening green nitrate
« Reply #1 on: May 22, 2012, 08:25:27 PM »
Randolph 210 Tautening Nitrate.
Allan Perret
AMA 302406
Slidell, Louisiana
steven yampolsky
« Reply #2 on: May 22, 2012, 08:31:08 PM »
Everyone is a comedian!  ;D ;D ;D
At least you didn't say buterate  LL~ LL~ LL~ LL~ LL~
Offline George
  • Love people, Use things.
« Reply #3 on: May 23, 2012, 10:42:49 AM »
Check here:   http://randolphaircraft.com/210dope.html
If you read the description, it is recommended for silk or silkspan.
George
George Bain
AMA 23454
Offline Jim Thomerson
« Reply #4 on: May 23, 2012, 02:24:03 PM »
I use tautening dope until the silk is tight enough to suit, then switch to non tautening for the rest of the finish.
« Reply #5 on: May 25, 2012, 07:10:41 PM »
Hi Steven,
I use Randolph's Blue non tautening Nitrate up to applying the covering, then 2-4 coats of Sig Supercoat Clear (Tautening) then Sig Lite Coat (non tautening) for the rest of the "fill".
BIG Bear
RNMM/AMM
Online Damian_Sheehy
« Reply #6 on: May 25, 2012, 07:41:08 PM »
<Snip> . . . so what do you use on open bays to tighten paper over the bays?
I use a heat gun; it does a great job shrinking Polyspan  ;D
Offline billbyles
« Reply #7 on: May 25, 2012, 10:29:16 PM »
"Snip> . . . so what do you use on open bays to tighten paper over the bays?"
Your answer is a nonsequitur - he asked about tightening paper.  Your lame attempt at humor was a flop.
Bill Byles
AMA 20913
So. Cal.
« Reply #8 on: May 26, 2012, 10:52:48 AM »
My intent was to put it out there as an option. One of the disadvantages of polyspan is the "fuzz". On a D-tube wing I finished last year, I used polyspan in the open areas and silkspan elsewhere and used non-tautening clear nitrate throughout. This approach could also be used to cover the C-tube wing Steve is working on.
