Brett Buck has noted here that the venturi area is fairly constant for a full-sized stunter, regardless of engine displacement. That's the area that's not blocked off by the spraybar, so you need a bigger hole if you're going to go block it off with a bigger spraybar.
So, what Dennis said for just about ANYTHING two-stroke.
