General control line discussion => Open Forum => Topic started by: Dennis Toth on July 25, 2012, 10:33:33 AM
Guys,
In my current build project for OTS I am getting to the point on selecting a bellcrank. The ship is non flapped and the 3" bellcrank fits nicely in the wing space. The ship is a 35 size around 32oz. I know for a flapped ship theres lots of geometry going on and forces but it seems that for a simple elevator to bellcrank setup it shouldn't make much difference as long as the bellcrank moment arms are in the same proportion (as long as you get the needed elevator deflection with reasonable bellcrank movement). Am I missing somethink here?
Best, DennisT
Getting more line movement for the elevator movement gives the springiest part of your system (the lines) the most leverage.
Folks seem to think that's important. I'm not that good of a flyer to know, but I can understand the mechanics, and I can regurgitate what I've read.
So if you cram a 4" bellcrank in there, with the same pushrod-hole to pivot-hole spacing as your 3" bellcrank, then you'll have to move the lines 33% more to get the same pushrod (and presumably elevator) movement. This means you can move your lines out on the handle, and gain more mechanical advantage around your lines, which is good.
That having been said -- there's a lot of 32-ounce class stunters out there flying on 3" bellcranks that seem to do just fine.
It's more likely with a 3" BC that you'll end up with narrow handle spacing of 2"-2.5". The wider the handle spacing (3"-4"), the more precise your controls, because slight hand/wrist errors are not so magnified. Yes, you could slow the controls enough to require 12" handle spacing, but I think that would be clunky at best. Like flying a stunt kite with a single handle...
Somebody I know typically uses about a 5" spacing (by my eyeball), which seems about the maximum practical. Maybe he will comment on the why, how, and results? ??? Steve
Tim,
That's the way I see it. On the last OTS ship, a S1 Ringmaster I had a Sig 3". At first I had used the outer most hole on the bellcrank and this gave way to much elevator even with the longest tail horn I could practically get on it. I had an opportunity to get into the bellcrank (read this as crashed) so on the rebuild I move to the inner hole and it was then reasonably flyable but could have gone in a little more and still had plenty of elevator deflection. I have the handle spacing pulled in to about 3 3/4". The new ship is an El Diablo. I think with the bellcrank pushrod hole set at 1/2" it should give plenty of control with a little wider handle spacing.
Best, DennisT
Every S1 Ringmaster I have ever built (about 5) have ended up with too much elevator movement! The only practical solution is to extend the elevator horn. Using those Nylon horns, I've had to put ply spacer under the horn and use longer bolts.
I have been working on a short monograph on this subject. It's not finished yet, and I hesitate to put down the conclusions, because some arm-waver will dispute them, then I'll need to duplicate the derivation, which nobody will look at anyhow. In brief, 1) use the big bellcrank, and 2) nothing you do with handle spacing can overcome too little control leverage at the airplane.
I've been using hand made wooden four inch bellcranks in 1/2A up to 15 size stunt airplanes. It is a challenge to get a 4 inch bellcrank into a 6 inch chord wing.
I'll bet it flies well when you do.
But, Howard, all you need is a bigger handle and then you can apply more torque, like a "cheater bar". Or you need a smaller one, and then you get a better mechanical advantage. Or something like that.
You and your so-called "mathematical truth" and strange runes. I think it's entirely possible you might be a witch.
I'm currently throwing together an old Ringmaster kit. The ply horn was garbage, even the geometry was wrong so I made it 90 deg. to the elevator and 3/4" from the hinge. The bellcrank is an old Top Flite 2 1/2"
I was under the impression that 4" bellcranks are for large flapped stunters for more leverage at th BC and handle.
Doug,
Don't use the 2 1/2" bellcrank in the Ringmaster (full 35 size). You need at a minimum the 3" and use the inside hole on a Brodak type bellcrank (if you use the Sig 3" drill a new hole below the existing inside hole say 3/16" down). I have one with the Sig 3" and changed from the outer hole to the inner and have a 1" tail horn and it is still to much elevator. I use a handle spacing of pulled down to 3 3/4" it works but I would go with a closer bellcrank hole and wider line spacing if I were doing it over again.
Best, DennisT
Dennis,
FWIW...
When I worked with Walter to create the LD kit we did everything sneaky (and legal) to slow down the controls and minimize the elevator movement. Particularly on the LD! Then Hunt comes along a while back and blows Red's secret! (Red lived with, and worked in Jim's shop for years. Bob and Red were like bro's.) Red used the classic 3 inch aluminum BC and drilled a new pushrod hole as close to the pivot as he could and still get balanced movement. He was also known to have cut his own BC'c with over sized dimentions.
Ward-O
You're the one who does the pentangles after every pattern.
Pentagrams are intended to WARD OFF evil, not invoke it. It has been less than entirely successful, of course.
There is actually a reason for it, but I expect that no one will figure it out.
If he weighs as much as a duck....
Ah! A nerd test, somewhere between INT and ADV skill class. To win the Chapman Cup, you will have to do a lot better - like a scene-for-scene reenactment of The Crimson Permanent Assurance from memory. Promising start, however.
ok, here is another outlook Tim,, If you have the same lines,,same airplane same weight,, you can assume the same stretch with the lines right?
so given that, if you move the lines 3" for max control deflection, versus 1 inch for max control deflection,, given the same stretch,, which will feel more connected??
ok so math to understand better,,
lets assume 1/16 of line stretch just for grins,,
so with a setup using 3" or travel , to derive the percentage of stretch,, .0625/3= 2.08 percent of line movement is stretch
with a setup using 1.5 inches of line movement for full deflection
you would be looking at .0625/1.5= 4.16 percent of the line travel,,
I think while you may not be able to feel the difference and recognize it as line stretch,, you would be able to tell that it is not manuevering as crisply,,
my two cents worth,,
Here I was, just thinking about a simple test to determine if Howard is a witch, and you go and bring up a whole new skill class to complicate things!
I'm just a lowly intermediate it would seem, since its been since school that I watched Meaning of Life and I forgot what the pirate scene was called :(
Great explanation.
Look, if I watch all those movies and all that TV to keep up with you guys, I'll never get anything built. I don't even know from the Matrix.
Howard,, I was wondering how you got your new plane built so fast,, and apparantly it looks as nice as the last one too,,I mean, the last one took what,, multiple years?
Great explanation.
whew,, I was waiting to get shot down cause I didnt think of some intrinsic nuance,, ;D
I kind of went around on this with Pat,, he thinks pretty simply that you just keep narrowing the handle spacing to get the control response,, and to a point its valid,, but it does change the feel,, so I have been trying to establish a baseline controls ratio in the airplane that will allow me to get my spacing where I want it,, ( mostly cause I dont build normal airplanes,, I always have to change something,, sick puppy that I am,, )
thats ok, the next one will be a mainstream, real life, copyed, from someone else,, design,,
(Snip -- TaW)
Yup. The only thing that I can add is something that's come up in these forums: the line stretch isn't just the amount of stretch that you get in the cable itself in similar circumstances. The line is effectively more springy because of drag -- it's bowed, and the more you pull on it the less it bows, and the less you pull on it the more it bows. That all adds up to a much more compliant system than just the cables being pulled on the ground.
Yup. That's my plan for my next one, too. In fact, to make sure that it's really normal, I'm going to be copying from two or three "someone else's" designs.
I have to note that one thing I'm taking as guidance on this thread and on past related threads is that while folks often recommend using a bigger bellcrank than what a kit or plan called out, I don't see anyone saying "oh, no, it'll work better with a smaller bellcrank". Even the response to a 4" bellcrank in a 1/2-A plane isn't "that's dumb", it's "Wow. Hard to fit".
Granted, going along with the consensus often means that you're a sheep happily running over a cliff with all the other sheep. But often it means that you're a sheep happily running to greener pastures with all the other sheep. I think the latter case holds here.
That is true enough,, however I elected to ignore that point ,, my thinking being that the "bow" in the lines,, ( I cannot recall what its called, its not parabolic,, it has another name) would be fairly consistant with both systems,, but it certainly is an addative,, note also that thicker lines will have MORE arc given other factors remain constant,( weight, speed, line length,,), therefore have more compliance,,
Now,, where is the break point,, thinner lines have less drag,, so have less arc in them, but they stretch more than thicker lines given constants remain, well,,, constant,, so at some point, the reduced drag arc compliance,, and the stretch compliance should converge,, At MY piloting level, I have felt,, ( or beleived I felt) that the thicker lines feel more connected on MY airplanes,,, so that is where I go,, and now that I have moved up to larger airframes,, ( read heavier) I happily no longer have to be concerned with that decision,,
I should state that a lot of my thought process on line size was motivated by Dirt talking about using .012 lines versus .014 on his flight streaks and other smaller airplanes,, and the stretch that came from smaller lines,,
Oh lord,, Tim,, Tim tim,, thats not quite what I meant dude,, copy ONE design per airplane,, sigh,,
I have stated this before, "Try it and see if it works for you. If it does fine. If not file it away and it may work on the next model". I am going back to what the plans call for on the planes. I figure the designer knows more than I do. H^^
Could one of you CAD guys just draw out the relationship, handle to elevator? And how about making one of those cool calculator things that starts with the desired elevator deflection and ending up with line spacing at the handle? Or a spreadsheet? IMO, 15 degrees is more than enough at the elevator.
Every time I hook up the lines to the Eagle 7 and wiggle the handle, I'm shocked with how little elevator deflection there is, and how hard a corner it can make. I'm considering reducing the handle spacing more...probably will if I have to fly it in any real heat or at altitudes over 500'-1,000'. I'm also thinking about adding a little nose weight, tho it shows none of the usual indicators (glide's good).
This topic started out as a Ringmaster subject, so let's look at that...the one thing you absolutely do NOT want on a Ringmaster is too much elevator movement. The wing can be too easily overloaded, with no flaps to increase lift. Ergo, use the 4" BC...unless you can cram a 5" BC in there. H^^ Steve
And my own recent experience with my first S-1 in ages is that I got it wrong, with my lines way too close together at the handle and the thing is still (as far as I can tell) stalling in the corners, yet is showing signs of too much springiness in other places.
Argh. Sigh. Etc. I just do not want to tear into the wing of that thing. Maybe I'll extend the elevator horn and put a wheel on the end of it. Or put an idler right behind the wing to reduce the elevator pushrod motion by a factor of 2 from what comes out of the wing. Or something.
the mighty RM is a flapless airplane,so there is literally no excuse to NOT fix the problem,, since options exist to avoid cutting into the wing,, but trust me Tim, yours is not the first to have this,, my Gee Bee flew the first year with like 2.25 spacing at the handle,, until one fatefull crash opened up the wing centersection sheeting for me, and i moved the attachment on the bellcrank,,
just lenghten the elevator horn,, some is better than none,, put a skid on the tail,, and pretend you meant it that way,, or put a matching skid on top of the nose to protect the needle valve, then you have continuity of design,, y1 y1
Well, here's the "linearized" math -- that means that it ignores the "anti-exponential" effect of bellcrank rotation and the "pro-exponential" effect of elevator rotation, and the fact that the motion is not all on one geometric plane, etc.
I can't post a spreadsheet -- the system won't accept it. I tried.
Inputs
- h is the handle spacing
- b is the bellcrank spacing
- c is the distance from bellcrank center to control rod
- f is the distance from the flap horn hole to the hinge
- fe is the distance from the flap horn elevator hole to the hinge
- e is the distance from the elevator horn hole to the hinge
- rh is the handle rotation
outputs:
- handle to bellcrank ratio (degrees/degrees) = hb = h/b
- bellcrank to flap ratio (degrees/degrees) = bf = c/f
- handle to flap ratio (degrees/degrees) = hf = bf * hb = (h * c)/(b * f)
- flap to elevator ratio (degrees/degrees) = rfe = fe/e
- handle to elevator ratio (degrees/degrees) he = rfe * hf = (h * c * fe)/(b * f * e)
When you want to go take all the angles and whatnot into account, then it gets complicated -- which is why Howard keeps talking about posting results, but hasn't gotten around to working through the math yet. I suspect that the above is good enough to get you into the ballpark, though.
It already has a long elevator horn, any more length and it'll be hitting the ground. At least, with the tail skid that I have.
But even though I made the tail skid removable so I could put on a longer one if the spirit so moved me, it didn't occur to me. It's nice that you're standing by with roll of duct tape and a raised eyebrow to keep me on the path of expediency. I hadn't planned on flying it in OTS anyway, so I can change the LG without too many tears.
I'll try bolting on an elevator horn extension and a longer tail LG, and see if it works. Thanks.
maybe,, ballpark, but it ignores the nuances,, which can in fact add up,,
do they matter in reality, ,for Paul, Howard, and Norm,, probably so,, for you and me,, maybe,,
I think the solution is to learn Inventor,, or some other parametric modeler,, and to create the control system in 3D,,
It is my intent to do that in CAD,, however, pinning the axis of rotation on elements and having them constrained to only rotate, not move, is cumbersome,, but worth it for the knowledge,, I just want the time to do it,,
Why not just build a Skyray per the instructions Brett Buck wrote at great length about, and go fly?
Steve, with all due respect,, sometimes you have an airplane that is built,, and the process of sorting it out is educational and pays dividends in the future,, not to mention it is a valid challenge all on its own,,
not to mention that even building a skyray stock,, takes time,, and its flying season here,, ( well for those who even have time for flying LOL)
we are getting Tim headed the right way, but we need to let him exercise his "engineer" too, or he will get bored,, LOL
Because I can't fly one of those in the Ringmaster Fly-a-Thon in October.
Which is what this plane is specifically built for -- getting it tuned up so that it can at least stagger through the pattern is a plus, but isn't actually necessary to the fly-a-thon. In fact, for that event a 1/2 ounce tank and a good pit crew is probably the best bet.
Randy proved that it only has to look like a Ringmaster (kinda) to post flights for the Ring-a-Thon. Only problem with it is that his .40VF won't start. I hope he gets that fingered out! y1 Steve
I could also bring along my 12 gauge "in flight throttle shut off " tool as well,, though restarts may be a challange,, VD~ S?P
figures,, Randy with the most reliable stunt engine,, ( next to electric) ,, LOL
well he will figure something out,, hopefully before the next contest,, which I may even be able to attend,,,,
You're not the Messiah, you're a very naughty boy!
Howard,
IIRC a well known several times National Champion championed the use of handles with as much as six inch spacing in order to apply the necessary input to a three inch bellcrank he preferred in his quite large aircraft which utilized big flaps in order to develop the lift necessary to fly them. Hmmmmm.
Ted
Howard,
Ted
And I think that well know several times National Champion with the extra wide handle (he put extensions on his large EZ-Just handles for extra width) also trimmed his models which some would find more than a bit nose heavy. I cannot fault success, it worked for him.
To expand #2 above, nothing you can do with handle spacing can compensate for the varying fraction (per Mark's post 16 above) of line travel that's due to line elasticity and drag. I'll write this up after cessation of flying weather at home.
Well, here's the "linearized" math...
I offered everybody (and sent you) a free spreadsheet that has the whole 3D geometry from leadouts to elevator.
Hi Keith,
Success has little to do with the physics involved in the use of handle spacing twice that of the bellcrank spacing.
Nose heaviness has little to do with the ability to deflect the controls. Full deflection will result in the same rate of body angle change no matter how big or small the handle is. What does change is the amount of force at the handle is necessary to overcome the load due to deflecting the control surfaces.
The rotation at which full deflection will be achieved will be something like half that if the handle spacing were three inches on a three inch crank. The Netzeband wall comes to mind. I like to think of extremes to get a feel for what will happen. Think of flying a modern big stunter with a three inch handle spacing and a one and a half inch bellcrank...(a 3/4" arm trying to move those big flaps and elevators on a ship going nearly 60MPH!) tough to do!
Ted
"( I cannot recall what its called, its not parabolic,, it has another name)"
How about catenary curve...
OK, so who's going to be the first with a 5" or 6" bell crank? Has it been done?
BIG Bear
RNMM/AMM
BIG Bear
RNMM/AMM
Yes it has been done, also a 4 1/2 inch BC I have several here
Yes! At some point the drag on the leadout guide from the larger convergence angle will start outweighing the benefits. I think all the more recent bellcranks I have made are 4.5 or 4.75" because that's the biggest one that will fit and still let me put the pivot on the spar without a lot of extra wood.
Rich Porter did it, but nobody noticed.
Agreed, Bill, yet Pete Soule' called it an accelerated catenary in an Aeromodeller Annual (1970-71?) article.
A catenary curve is the (parabolic?) sag of a cable of uniform load or weight, between its two supporting ends.
The "supporting ends" for our flying lines are at the handle and at the leadout guides. The vertical sag due to the lines' own weight is pretty negligible.
In terms of "sag aft" due to line drag: Air drag (load) on the lines increases with the square of velocity, and velocity increases with radius - from near zero at the handle to the airspeed at the leadout guide locations. Curvature tightens from the handle to the leadouts... We can see it as we look down the length of the lines... We deal with it (adjustable leadouts; CG shifting.)
Pete's 40+ year old formula is a good first estimate, given the other variables we can't put hard numbers on, regarding CL flight. I believe Pete's formula is very close to being a basis - or at least start point - for the LINE'XXX' apps, which add further refinements.
Got a notice about Brett's latest post - while I was writing this... I believe that good reasons for pivoting the bellcrank near the spar include these:
...The spar is usually near the greatest "rib" height, ... greater depth is good for 'bending strength'
...Max "rib" height is usually around 20% to 30% of chord, so there should be reasonable fore/aft space.
... The flying lines 'tend' to aim pull at the CG, through the leadout guides. If the leadout guides are properly located, the angle the lines make when they reach the guides can be continued, inside the wing, right to the CG. This should reduce friction on the guides. The friction may not be much, but leadout cables and/or guides can be damaged over time. ...cable saw, anyone?
I noticed! Everybody has fun telling Rich Porter stories but what little time I spent talking to him was interesting and I certainly learned some stuff.
Hi Keith,
(Clip)
Ted
Ted,
I think I knew some of that. I was just commenting on how one individual that we know trimmed his airplanes. It worked for him. I have flown some of his airplanes and -----
LineIII actually uses Pete's original C source code for all the math calculations.
Ted,
Keith,
Don't think for a moment I'm putting our mutual acquaintance down. Nobody did what he did better than he did and, unlike many, I thought his patterns were very competitive in terms of corner, etc. with what was being flown in that era by the other guys. He also flew (flies) pretty much flawless shapes which very few do (Dougie Moon and Ryan Young being the most recent examples I've watched who spend time making sure the tricks look like their names!) Anybody notice, by the way, that on the one "non-overun" flight Ryan flew in the Walker Flyoff--which included two stalled out bottom right 120 degree corners--scored within the noise range of Doug's excellent Walker Cup flights? These Texas guys might be shifting the stunt CG in a big way in the not too distant future!)
Getting on my soapbox, by the way, I'd like to comment on something I noted while at the Nats. The first six conversations (give or take a number or two) I sat in on after arriving all bemoaned the lack of young fliers and generally ended up with comments like "what can you do about it?", etc. Well, a week later I watched the usual crowd watching and nit-picking the top five flyer's patterns right up to Doug's exciting final victorious flight. I had judged the handful of Junior and Senior entries and missed the first two flyoff rounds but watched the ones that ended up counting in round three. While judging the young fliers I was once again (after my experience as assistant team manager in Hungary) struck by the skills displayed by Ryan Young. His flights had shapes and sizes ripped right out of the rule book and only an occasional airplane fart (his ship is heavy for its size and "will" stall if pushed too far) prevented scores in the stratosphere from both myself and the other four judges.
Well, I then watched the final round and stood around waiting for what I thought would be a very competitive Walker Cup duel between Doug and Ryan. Alas, the duel for the cup petered out pretty quickly as Ryan promptly threw up two overrun flights which turned out to be the result of the tie wraps on his pipe being so loose they spun and the connector had, not surprisingly, opened up and destroyed any effect from the pipe. Forever game, however, Ryan and his pit buddy Darryl patched up the tie downs and he went out to fly his third flight knowing full well he was dead as a duck in the flyoff as Doug had two fine complete flights to zero for himself. This time the engine ran perfectly and the flight was marred only by a couple of give ups in one corner of the triangles and the last corner of the hourglass. His score was only twelve points (IIRC) behind Doug's best effort and some of that was in appearance points!
What does that have to do with my conversations earlier in the week? Just this. The seats in the stadium were empty! All the guys wondering why we didn't have more juniors and seniors were gone after the top five fly-off and missed the opportunity to see a kid who, I predict, will win more than a few Walker Cups in the not too distant future.
Boy, did I get off track there! Sorry.
No, Keith my comments about the big handle and the small bellcrank used by our friend were only addressed because of the subject matter of the thread and the direction it was (and is) going. I'm 100% in the opposition when it comes to such a set-up but, like you, can only marvel that a man who handicapped himself in so many ways on the way to achieving his aspiration managed to do so nonetheless.
Ted
No one has mentioned the 3.5" bellcrank. I use to use them before the 4" bellcrank was easy to get. I didn't make them but several people did make them .I think I ordered mine from Rollie McDonald. They were a big improvement in Twister size planes.My vintage Juno from 1988 has one in it.
I thought it was a good diversion. Ryan is a very impressive person, as well as a good stunt flier. And I'll have you know I was in the bleachers.
"" His score was only twelve points (IIRC) behind Doug's best effort and some of that was in appearance points! ""
Hi Ted
I thought that in the past, APs were dropped in the Cup flyoff, did they not use to do it that way?
Do you know when or if it was changed?
Regards
Hi Ted
Regards
Randy, You're absolutely right and I was dead wrong to mention them. The Walker Cup has historically been competed without the APs. Still, 12 or so flying points behind a guy that had just beat the winningest flier in US stunt history is not a bad showing for a kid who had spent the entire week judging rather than flying. I continue to stand by my predictions for Ryan's future!
Ted
BIG Bear
RNMM/AMM
Windy had a 5 inch in his Foam wing Sweeper, (Bob Zambelli has it) where he placed 17th at the Nats. John Wright told me he stuffed a 4 inch bellcrank into his Barnstormer which helped to give him his Nats win. I believe the Russians were packing 5" or big levers into their stunt ships, but you didn’t hear that from me, ( ask Leon Panetta about that).
Ted
Hi Ted
No biggie, I was curious if it had been changed, and I do agree with you about Ryan, the young man has a boat load of talent.
Regards
Ed,
My late (and mostly unlamented) circular bellcranks I used in the published Imitation and Excitations were also 3.5" diameter drives. They were nicely machined by John Schwickwrath but, unfortunately, the bearing material wasn't up to snuff and they got sloppy after a few hundred flights. They did precede the switch to four inchers as well.
Ted
Guys,
The build project El Diablo is getting to the stage of installing the bellcrank. I have found a way of putting the 4" crank in without much trouble and very good support. BUT, the ED's wing is only an 1 1/8" thick and the crank fits between the top an bottom spars nicely problem is this leaves only a little over 3/8" for the pushrod to clear. I like to use cable leadouts with a brass tube "C" bushing so to get the pushrod to clear the leadout attachment it needs to come out on a slight angle. This all works except for the connection of the pushrod to the bellcrank. Normally I would use a ball-link connector but this is to tall on the 4" Brodak crank. So as I see it I can get a different style bellcrank that allows a lower profile leadout connection or use a heavy gauge wire that allows some weird bends and maintains strength.
Anyone offer a thin flat bellcrank with sideways leadout connectors?
Best, DennisT
Well, I hope you guys don't tell my Ringmaster that was built box stock by a young lad many years ago that it is not supposed to fly the way it does. Mine flies an Old Time Pattern better than some of the planes I had before. It will do it again in October. H^^
