  • April 25, 2024, 03:24:30 AM
Author Topic: blank  (Read 2725 times)
blank
« on: June 15, 2013, 09:53:17 PM »
blank
« Last Edit: September 08, 2021, 05:40:10 AM by Motorman »
Re: Heavy Wall Copper Tubing & Lead Out Swaging
« Reply #1 on: June 15, 2013, 10:08:13 PM »
Try MBS Model Supply: http://mbsmodelsupply.com/.  Nice guy.  I always forget to call after 5:00PM Kansas time, and he's still nice to me.
I think his sleeves are a bit smaller than what you're asking for, but they should still work.
« Reply #2 on: June 15, 2013, 11:30:22 PM »
Can't you buy swaging sleeves at your local saltwater tackle shop?  ??? Steve
Offline bob werle
« Reply #3 on: June 17, 2013, 07:14:21 PM »
McMaster Carr is close.  3/32 od x .065 id  3   1' pcs per pack.  Copper alloy 122. @ bout $3 per pack.
ama 5871
« Reply #4 on: June 17, 2013, 10:38:52 PM »
Thanks Bob but, that is still thin wall tubing. I may have to grind a few out on my lathe.
Actually Mcmaster Carr lists Fabrication copper tubing at 1/8 inch OD and 1/32 wall thickness
(.125 OD .065 ID).
Offline Dick Pacini
« Reply #5 on: June 18, 2013, 03:32:07 AM »
You grind on your lathe???
AMA 62221
Offline Steve Riebe
« Reply #6 on: June 23, 2013, 06:41:34 PM »
Downrigger cable crimp sleeves are really heavy duty and made from stainless steel. Try your local gander mountain or cabellas
Offline Paul Wescott
« Reply #7 on: June 23, 2013, 08:17:47 PM »
Grinding on a lathe is quite common and any machinist worth his salt knows how to do it ;). It provides the best surface finish and the highest precision parts.  Try looking up tool post grinder in Google or YouTube and you'll see.
Paul W.
Offline Dick Pacini
« Reply #8 on: June 24, 2013, 06:45:13 AM »
Paul W.
Paul, I spent a better part of my working life in manufacturing and machine tools.  I was a Field Service Engineer and Service Manager for a well known machine tool builder for 18 years. I owned my own manufacturing company for 21 years.  I have many, many years of lathe experience, both manual and CNC.
I am well aware of tool post grinders.  I am also well aware of how grit can get under bed ways and seals and shorten the life of a machine.  Even polishing on a lathe with emery cloth is not a good practice.
There are machine tools designed for grinding and there are machine tools designed for turning.  Grinding on a lathe is something I would never do.
As far as your comment, I thought it was a mistake in describing material removal.  Not everyone understands the application of turning, grinding, milling, drilling, boring and so on.  Apparently you do and choose to grind on your lathe.  My apologies for second guessing your intent.
AMA 62221
