stunthanger.com
CLICK HERE---->    <----CLICK HERE
Welcome, Guest. Please login or register. March 27, 2017, 12:50:15 AM
Pages: [1]   Go Down
  Print
Author Topic: Fly by wireless  (Read 28326 times)
Gustavo Urtubey
Trade Count: (0)
Ensign
Offline Offline
« on: August 12, 2015, 01:58:31 AM »
It is not new and it is coming to the aviation industry very soon.
The objective is to save weight and downtime due to faliures in connectors, wires and sensors.
New technology options using sensors potentially for data connectivity and micro/nano technologies are making it possible to retrofit existing vehicles, such as large commercial fleets and already designed models.
An A 380 contains 530 km. of wire and 40.000 connectors.
May be  in the future it would be easy to have this technology for model planes.
I imagine a stunter with no pushrods, wires or connectors, just an electronic module that could be located anywhere, even as a tip weight and send signals to flaps, elevators, motor rpm's and that it could be set up from the Iphone.
Logged
RknRusty
2017
Trade Count: (0)
Admiral
Online Online
Rusty K
WWW
« Reply #1 on: August 12, 2015, 05:09:11 AM »
That sounds really cool for sport flying and building. It sure would make for some hair-pulling rules discussions in Stunt, Carrier and all the other CL disciplines.
Rusty
Logged
Dennis Toth
2014 Supporters
Trade Count: (0)
Admiral
Offline Offline
« Reply #2 on: September 24, 2015, 07:59:01 AM »
I think the rules already address how control surfaces can be moved. It requires that the control input is through the control lines. The surfaces can be moved by either hard linkage or servo's as long as the control signal/command comes from movement of the control lines. It doesn't matter if that signal goes through pushrods, wires, radio signal or fiber optic as long as the input come from movement of the control lines.
The use of servos for control surface movement actually is interesting in that it could allow some new and interesting designs where you don't have to have straight line hookup of the surfaces to the bellcrank. Drawback is the added weight of servo and battery, but still could be fun for some.
Best,     DennisT
Logged
phil c
2015
Trade Count: (0)
Admiral
Offline Offline
« Reply #3 on: October 01, 2015, 08:46:24 AM »
One of the big reasons some people like C/L  is that you can feel what the airplane is doing.  Without force feedback, or a lot on internal sensing in the electronics, the pilot won't be able to respond to what the plane is doing.
Logged
Sean McEntee
Trade Count: (0)
Captain
Online Online
« Reply #4 on: April 25, 2016, 10:38:21 PM »
I agree.  Besides the romantic part that Phil mentioned, I think it would be very difficult to relearn how to fly precise maneuvers with out the aerodynamic resistance on the controls.
Logged
TigreST
TigreST
2017
Trade Count: (0)
Commander
Offline Offline
« Reply #5 on: January 06, 2017, 10:04:45 AM »
.......... I think it would be very difficult to relearn how to fly precise maneuvers with out the aerodynamic resistance on the controls.
 :!You would not have to worry about "relearning" anything...there will be a "ap for that".   Stand in the middle of the circle hold onto to a single line attached to the middle of your handle. Open the ap on your cell phone.  Push the go button,...then just move about to allow the application to fly your pre-programmed pattern for you.
Logged
Tony Bagley
Sarnia, Ontario, Canada
Trade Count: (0)
Admiral
Offline Offline
« Reply #6 on: January 27, 2017, 09:39:38 AM »
I have flown scale ships that that have the elevator controlled by a servo.  The feel at the handle is not a lot different.  The reason for the set up was that it was a large scale model built from a converted RC kit.  It flew great but it was lead sled. This is OK for scale but not so good for stunt.  On top of all that as I read it scale rules no longer allow elevator control by a servo.  All other functions are ok.  I don't see any future for servo controlled flight surfaces in stunt.  Sport flying is another thing.  I have wanted to build a RC controlled model that is tethered by a mono line attached to a chest harness.  It would have active ailerons and rudder.  could make for some interesting maneuvers.
Logged
phil c
2015
Trade Count: (0)
Admiral
Offline Offline
« Reply #7 on: January 27, 2017, 05:39:47 PM »
One area where this could be really helpful is in trimming.  Got a bit of a roll, trim it out.  A bit twitchy, slow the elevator response and/or travel a little.  Rabe rudder causing trouble, reduce movement and/or travel.  You could trim almost anything related to the controls in one or two flights.  Add a moveable trim weight and you could even trim the CG.
As Brett has pointed out many times though, once the system is built there is no practical way to prove that it isn't acting as an autopilot of sorts to smooth out maneuvers, minimize over control, control the engine run which is already allowed in electric(very bad decision that ).
Logged
Pages: [1]   Go Up
  Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.21 | SMF © 2015, Simple Machines
Valid XHTML 1.0! Valid CSS! Dilber MC Theme by HarzeM
