stunthanger.com
CLICK HERE---->    <----CLICK HERE
Welcome, Guest. Please login or register. June 19, 2013, 03:00:15 AM
Pages: [1]   Go Down
  Print
Author Topic: Enya venturi inserts  (Read 1512 times)
Bill Morell
2013 Supporter
Trade Count: (0)
Commander
Rate User 71
Online Online
« on: July 06, 2008, 04:51:35 PM »
Recently I had some of these done Lee's Machine shop. These are not conventional venturis but rather the type that fit down inside the case. They were absolutely perfect! They are hard to come by and really about the only chance you have of getting these is to have someone that knows what they are doing make them. I highly reccomend Lees Machine shop if you need something like these made for you.
« Last Edit: July 10, 2008, 11:26:55 PM by Bill Morell » Logged
Bill Morell
dennis lipsett
Trade Count: (0)
Admiral
Rate User -16
Offline Offline
« Reply #1 on: July 06, 2008, 08:56:44 PM »
Recently I had some of these done Lee's Machine shop. These are not conventional venturis but rather the type that fit down inside the case. They were absolutely perfect! They are hard to come by and really about the only chance you have of getting these is to have someone that knows what they are doing make them. I highly recomend Lees Machine shop if you need something like these made for you.
Bill,
Your not saying which venturis you had made. Randy Smith has factory  venturis for most all of the Enya lineup. Now if he made them for the square venturis found on the 5224 that would really be something.
Dennis
Logged
Bill Morell
2013 Supporter
Trade Count: (0)
Commander
Rate User 71
Online Online
« Reply #2 on: July 06, 2008, 10:04:56 PM »
Dennis, he made inserts for the Enya 63 and the 35 6001 and therefore are indeed really something. There really isn't much point in having someone make the square venturi's when they are readily available direct from Enya. Try buying these that I had made from Enya sometime.
Logged
Bill Morell
James Lee
Moderator
Trade Count: (0)
Commander
Rate User 20
Offline Offline
« Reply #3 on: July 09, 2008, 08:56:26 PM »
A picture of what Bill is talking about.   The inserts are symmetrical, with an inside taper on each end.   And the slit accommodates variations in the id of the venturi.  They have to be pushed firmly into place.    Bill provided originals to copy, and after he sent them, I found an old Enya of a different size to better understand how they fit.
Interesting project...
Jim
Logged
dennis lipsett
Trade Count: (0)
Admiral
Rate User -16
Offline Offline
« Reply #4 on: July 14, 2008, 04:32:14 PM »
Jim
I forgot about those,
dennis
Logged
Garf
SH Supporter
Trade Count: (0)
Admiral
Rate User 8
Offline Offline
WWW
« Reply #5 on: September 24, 2012, 04:13:34 PM »
Very similar to the K&B Greenhead.
Logged
Pages: [1]   Go Up
  Print
Jump to:
