  • May 10, 2024, 06:52:41 PM
Author Topic: Evolution 36 Control line engine  (Read 30272 times)
Dave Adamisin
« on: March 20, 2008, 10:30:49 AM »
Re: Evolution 36 Control line engine
« Reply #1 on: March 20, 2008, 11:01:25 AM »
I just wish I new more about how they ran before I plunk down $80 for one. They look kinda neat!
Offline Mike Spiess
  • bikemike
  • AMA #4060
« Reply #2 on: March 20, 2008, 11:14:20 AM »
WOW I wounder if it's an eazy starter like their RC ones.
You don't stop flying cause your get OLD
You get OLD cause you stopped flying
St Peter MN
Present Master of the Figure 9
Offline Balsa Butcher
  • High Desert Flier
« Reply #3 on: March 20, 2008, 11:31:40 AM »
The tongue muffler pictured is sure a contrast to the usual mufflers that are provided with modern engines, especially the converted R/C ones.
Pete Cunha
Sacramento CA.
AMA 57499
Dave Adamisin
« Reply #4 on: March 20, 2008, 11:48:22 AM »
The package actually also includes the standard cast muffler which is very quiet and efficient as well as three different venturis (0.218. 0.235 and 0.272"). It gives you a very flexible power profile for just about any classic and old time model. We've flown it with all of the configurations and found it to be easy to handle and VERY powerfull and responsive to the needle. Clean four cycle and nice break. Full hemi with small squish combustion chamber. The small case makes it easy to put into classic stunter designs.
  • High Desert Flier
« Reply #5 on: March 20, 2008, 11:51:44 AM »
Clint:  I see another engine in your future - and FWIW Chipmunk made it to Gallup fine, it has taken up residence in my spare bedroom.  The other (garaged) stunters are jealous  <=
Dave: Props used?  RPM?  Planes?  Did you use the remote needle valve or convert to std. configuration?  Thanks
« Last Edit: March 20, 2008, 12:22:23 PM by Pete Cunha »
Pete Cunha
Sacramento CA.
AMA 57499
Offline Peter Ferguson
« Reply #6 on: March 20, 2008, 12:32:54 PM »
Horizon must have noticed an uptick in sales for CL engines, presumably at Tower, good sign.
Peter Ferguson
Auburn, WA
Dave Adamisin
« Reply #7 on: March 20, 2008, 12:37:01 PM »
We used it with the remote valve. It's nice and progressive. It weighs a little less than an once so if weight is a consideration... Proped from 9x6 to 12x5. With the 0.272 vent it's more of a 40 to 46 replacement. with the .218 it spins an 11x4 Powerpoint at 9400 - clean no break four- the larger vents add about 500 rpm to that in equal steps. The liner was redesigned from the rc version to make it more stunt friendly with changes to both transfer and ep area area. It tolerates just about any fuel. Really a friendly and trust me, powerfull piece. We have been flying a Vector arf (0.235 vent 11X4 and 11X6)) with it as well as a cardinal arf (0.218 vent 11x5 or 6).
  • High Desert Flier
« Reply #8 on: March 20, 2008, 12:56:26 PM »
Thanks Dave - those are impressive numbers.  And Ditto on the good sign  #^
Pete Cunha
Sacramento CA.
AMA 57499
« Reply #9 on: March 20, 2008, 12:59:04 PM »
At 10.3 oz without a muffler, seems a bit heavy for classic applications to me. Considering the Fox 35 most used. Then when you consider an LA .46 weighs like 8.4 oz with no muffler. Dont know anything about the motor other than what the specs read to be honest. The cooling fin design has always seemed odd to me, but then I am used to the "normal" config and I am one of the weird guys that like the blue LA finish, so take it for what its worth
Offline Mike Foley
« Reply #10 on: March 20, 2008, 01:24:40 PM »
  1st time I've seen a tongue on a Manufactured motor from a major company. Now if they would only get rid of the remote needle valve setup.  Could be a possibility if it compares with the Aerotiger 36. I see the Liner is specific for control line. Would like to see more non biased opinions and I may be in the market. Good to see more interest in control line is being noticed by the companies.  Competition is good for the consumer
Offline Leester
« Reply #11 on: March 20, 2008, 01:32:24 PM »
I'm wondering if the specs. given are for the R/C version ? The keys state 9.3 oz with tongue muffler.
Leester
ama 830538
Dave Adamisin
« Reply #12 on: March 20, 2008, 01:35:40 PM »
Hi Mark. Good point on the weight. Horizon seems to have copied the specs verbage in part from the RC engine. In the write up it specs the weight (with the tongue) at 9.4 oz. the 10.3 is with the very large rc carb.
Offline Rudy Taube
  • Ret Flyboy
« Reply #13 on: March 20, 2008, 01:42:05 PM »
Hi Dave,
Thanks for the heads up on a new CL engine. I have always been a big fan of Horizon products. I have several of their planes and radios, they make a quality, well engineered product and back it with excellent customer service. My guess is that this CL engine will be a good one. :-)
There seems to be some confusion on it's weight. They mention 9.3oz "with" the tongue muffler twice in their write up. Then they show 10.3 engine only in their data section and 2.x oz for the "real" muffler. Do you know what the actual weight is?
Rudy
AMA 1667
Offline PeteBergstrom
« Reply #14 on: March 20, 2008, 01:59:02 PM »
Guys,
The specs were indeed copied from the RC page.  I have updated the page today.  The bare engine weight is 9.3 oz.  Remember that this includes two ball bearings, not sleeve bearings when you are comparing.  the tongue muffler weighs in at 14gms (.5 oz) and the Std expansion muffler at 2.1 oz.  Both are included and the choice is yours to use.
Thanks for the encouragement.  You'll see more in the future from the guys at Horizon...
Pete
Offline Mike Spiess
  • bikemike
  • AMA #4060
« Reply #15 on: March 20, 2008, 02:36:50 PM »
Pete
Kits ARFs? n~
St Peter MN
Offline Crist Rigotti
« Reply #16 on: March 20, 2008, 02:51:52 PM »
Pete,
Nice job and appreciate the support that Horizon Hobby is giving the control line world.  Can't find a nicer bunch of guys at HH.  How about doing the same thing with the 52?
Crist
AMA 482497
Waxahachie, TX
Offline ash
    • I build guitars to pay for CL models!
« Reply #17 on: March 20, 2008, 03:16:53 PM »
This is an interesting development. Its good to see the guys at horizon taking us seriously. Long may it continue! I will certainly show my appreciation in the form of a Saito 62 CL in the near future.
From my point of view, the Evo36 is unfortunately in a category already brimming with excellent CL options at a good price. What I would LOVE to see is one of those low cost brands cobble together a rear exhaust 60 or bigger with stunt worthy timing and weight uder 13 oz. Far easier said than done, I know. RE castings aren't exactly commonplace. But I'd be all over it. Maybe a side exhaust 65 in a 52 case is more do-able... one can dream ;)
Adrian Hamilton - Auckland, NZ.
Offline Dennis Adamisin
« Reply #18 on: March 20, 2008, 03:29:32 PM »
Can't resist jumping in here.  As Dave mentioned one of the test birds is a Vector ARF - here's a couple pix of the installation.
The remote needle works EXTREMELY well with real broad resolution.  Having the needle exit on the opposite side from the muffler and well behind the prop will spoil you for "normal" engines.  The height is such that it works very well with bottle tanks too...
Denny Adamisin
Fort Wayne, IN
Offline Elwyn Aud
    • Inferalandings Photo Page
« Reply #19 on: March 20, 2008, 06:18:01 PM »
A tongue muffler and three different venturi's as standard issue is a nice touch. Some companies seem to charge more for taking off the carb and replacing it with a venturi. I wonder if the venturi's or muffler will fit other brands of engines. What's the cost of a venturi these days? Ten dollars or more? With the tongue muffler and extra venturi's it's kinda like getting $30 or so worth of extra goodies.
Offline Lyle Spiegel
« Reply #20 on: March 20, 2008, 06:43:58 PM »
Is  the motor mount hole pattern common with OS LA 40/ 46 or B40?
Lyle Spiegel AMA 19775
Dave Adamisin
« Reply #21 on: March 20, 2008, 11:13:58 PM »
Did you guys notice the clever cowl outlet Dennis pulled off........
« Reply #22 on: March 20, 2008, 11:25:22 PM »
Yeah, the "E" for Evolution. Pretty cool.
« Reply #23 on: March 21, 2008, 06:08:01 AM »
Where are these engines' made?
Anybody know the ulitmate source?
The ad says "available May 08".
As mentioned above, $80 for on engine with three venturis, an NVA, and good muffler is give-away.
« Reply #24 on: March 21, 2008, 07:56:20 AM »
 This is some great news! With the optional mufflers and venturis included, it seems like a very fair price at $79.99. I will second Crist's suggestion on doing the larger engines as well. Kudos to Horizon! y1
Online Will Hinton
« Reply #25 on: March 21, 2008, 08:35:29 AM »
Yea, that Dennis is always showin' off.  Seriously, wish I only had one LA46 in the stable, I'd cough up for one of these in a heartbeat! y1 y1 y1 y1
Dennis, nice lookin' ship, ya bringin' it to the FCM this year so we can see the motor perform?
Blessings,
Will
« Reply #26 on: March 21, 2008, 08:38:53 AM »
I cannot add anything here EXCEPT: The Adamisin's are world known for their engine work, and they do know what a stunt engine is supposed to do.  If they say it is good for Stunt, I believe them. y1
Thanks for the information, guys!
Offline Charlie Pate
« Reply #27 on: March 21, 2008, 09:20:29 AM »
What are the mounting dimensions (holes) ?
 Same as fp40 ?
 ST46?
 Fox 35?
Willis Swindell
« Reply #28 on: March 21, 2008, 09:28:00 AM »
Looking at the Vector it looks like the 36 has a lower profile then the Brodak 40. The 36 is down inside the cowl The Brodak 40 is above the Vectors cowl.
Willis
Dave Adamisin
« Reply #29 on: March 21, 2008, 09:59:03 AM »
Willis
Hi Willis. Yes it is smaller than most of the 35 to 40 engines. It's more like a 25 or 30 in volume. I'm working on a small chart of comparitive demensions.
Willis Swindell
« Reply #30 on: March 21, 2008, 02:13:22 PM »
How does the mounting holes compare to a LA ?
Willis
Dave Adamisin
« Reply #31 on: March 21, 2008, 02:38:03 PM »
Willis
I believe it's real close to the Thunder Tigre. The LA is about .68 to .59 on the Evo on the lug and 1.59 LA to 1.49 Evo across. It's only 1.77 total width which matches up to a LA25 or Magnum 25. It runs like a LOT more than that. We've been flying a Cardinal with the Evo 36 with the smallest vent turning an 11x6 Power Point at 5.3 to 5.4 (set for 4-2-4 break, clear 4 in level flight) lap times on 63's. If that gives some perspective.
« Reply #32 on: March 21, 2008, 03:15:35 PM »
Blessings,
Will
YES we will be at FCM, hopefully in full force.  Expect to have EVO's in a couple birds in a couple classes.
BTW if anyone is keeping score, since last season Horizon has brought out 4 new CL engines plus bought major ad space in Stunt News...  I like that!
Denny Adamisin
Fort Wayne, IN
Offline Bill Hodges
« Reply #33 on: March 21, 2008, 04:55:43 PM »
I couldn't resist.  I tried to place an order online but Horizon's address verification service did not like my address so I phoned them and got on the list to get one.  I made it a point to let the lady I was talking with know that we appreciate Horizon taking an interest in us controliners.  I ask her if there would be a Saito 40 cl version coming out. She did not know.
Bill Hodges
Bill Hodges
AMA 12450
Offline bruce malm
« Reply #34 on: March 21, 2008, 05:46:17 PM »
I put my order in today with cc info. Hope they come in in early May like they said. What other control line engines do they make ???
Bruce
Dave Adamisin
« Reply #35 on: March 21, 2008, 06:09:16 PM »
Hi guys. I was beavering away on measuring things and my younger bro passed this along to me. I don't know who put it together but I owe them a thank you. Here you go:
              Mtg.           Mtg.     Mtg.  Thrust
                        Hole    Case   Holes   Holes  Washer   Overall Overall
Mfg   Model   Disp.   Dia.   Width  Fore/Aft Width  Frt Hole   Width   Length
Brodak   40   0.4   0.13   1.21   0.69   1.59   1.49   1.9   2.7
O.S. Max 35S   0.35   0.13   1.21   0.69   1.58   1.43   1.85   2.53
O.S. Max 40LA   0.4   0.16   1.25   0.68   1.59   1.67   1.89   2.9
Evolution 36    0.36    0.13    1.18    0.59    1.49    1.85    1.77    3.00
Evo 40-52   .40/.46/.52 0.16    1.42    0.69    1.73    2.07    2.04    3.35
OS Surpass 40   0.40            1.28    0.69    1.65    1.89    1.93    3.05
OS Surpass 48   0.48            1.34    0.69    1.73    1.94    2.01    3.17
Enya.35 # 5224   0.35   0.14   1.26   0.58   1.66   1.74   1.96   2.8
Enya   .40XZS   0.4   0.14   1.2   0.59   1.48   1.82   1.77   3
Enya   50SS   0.5   0.14   1.35   0.71   1.67   1.93   2   3.23
Fox   35 Stunt0.35   0.13   1.21   0.63   1.52   1.14   1.82   2.25
Fox   36X   0.36   0.13   1.26   0.63   1.64   1.48   2   2.66
Fox   59   0.59   0.13   1.53   0.74   1.81   1.68      2.95
Magnum   25 GP   0.25   0.13   1.1   0.55   1.39   1.55   1.76   2.62
Magnum   25A XL   0.25   0.13   1.19   0.59   1.49   1.84   1.78   2.98
McCoy   35   0.35   0.13   1.29   0.57   1.58   1.53   1.89   2.55
McCoy   40   0.4   0.13   1.3   0.56   1.58   1.53   1.87   2.56
O.S. Max25LA   0.25   0.13   1.14   0.55   1.42   1.54   1.74   2.63
O.S. Max 25 FP   0.25   0.13   1.16   0.56   1.41   1.55   1.73   2.62
O.S. Max 35FP   0.35   0.13   1.25   0.69   1.59   1.7   1.9   2.91
O.S. Max 40FP   0.4   0.16   1.25   0.69   1.57   1.68   1.9   2.91
O.S. Max 40H   0.4   0.15   1.32   0.69   1.58   1.89   1.89   3
O.S. Max 46LA   0.46   0.16   1.25   0.68   1.59   1.67   1.89   2.9
Saito   30   0.3   0.13   1.16   0.55   1.42   1.57   1.69   3.45
Saito   40A   0.4   0.13   1.2   0.59   1.49   1.8   1.77   3.47
Saito   56   0.56   0.19   1.27   0.59   1.82   2.05   2.12   4.03
S Tigre   G51   0.51   0.14   1.38   0.76   1.65   1.95   1.97   3.24
T Tiger   25   0.25   0.13   1.12   0.56   1.47   1.38   1.79   2.45
T Tiger   36Pro   0.36   0.13   1.23   0.59   1.5   1.8   1.77   2.94
« Reply #36 on: March 21, 2008, 10:51:29 PM »
cool looking engine - bummer it is not a drop in replacement for engines like the LA......
I second Ash's opinion of a reasonalby prices Rear Exhaust 60 .....something that would be snapped up by many
Offline dave shirley jr
« Reply #37 on: March 22, 2008, 09:44:36 AM »
from these numbers it looks like a bolt in for a thunder tigre 36.
dave jr.
Offline Scott Dinger
  • ACE
« Reply #38 on: March 22, 2008, 09:53:38 AM »
As soon as I get my hands on one I will make a super light tube muffler for this engine! The 'backorder' says May. Scott@ Hyflo Muffler www.hyflomuffler.com
Offline Mike Foley
« Reply #39 on: March 22, 2008, 11:39:51 AM »
  I have to believe that some one in the Stunt community has been corresponding with Horizon to come out with this motor. How else would Horizon know about Stunt timing of the liners and different venturi sizes as well as Tongue mufflers.  I have my suspicions, anyone want to fess up?
Offline Bob Reeves
    • Somethin'Xtra Inc.
« Reply #40 on: March 22, 2008, 11:49:37 AM »
Not real hard to figgure out, bet his last name starts with an "A"
« Reply #41 on: March 22, 2008, 01:03:07 PM »
I think the real story is that Pete Bergstrom at Horizon has taken charge of getting the 3 CL Saitos and now the CL Evolution 36 into production and into the product line.  This is no small feat!  Pete brought out the CL engines with multiple venturi inserts and the light weight tongue muffler - parts of no particular use to the RC crowd.
For any who don't know Pete, he is a CLPA flyer.  The tongue muffler got tooled up specifically because Pete KNEW what we would be looking for and set out to get it.
Bob R. must be psychic!    y1
Pete discussed the Evo36 with Dave Adamisin (one of my MUCH older brothers) starting last summer.  The engine sounded REAL good on the bench, and we picked up a Vector ARF (see pix several posts ago) for flight tests.  Dave actually "witnessed" the test flights in his living room over his phone while recovering from knee replacement surgery!  I called him on my cell so he could "listen" to it - of course he got out later...
The effort that Pete Bergstrom made to bring the new CL engines out from a major RC supplier with no prior CL product - this is really something to that must be appreciated.   H^^
Denny Adamisin
Fort Wayne, IN
Online Will Hinton
« Reply #42 on: March 22, 2008, 02:03:30 PM »
Dennis,
I couldn't have said it better about Pete - he's a winner in all respects and HH knows that.  The whole staff at HH are wonderful people and I'm glad we cl guys can have a reason to deal with them!
Will
« Reply #43 on: March 22, 2008, 05:14:31 PM »
Dennis,
Will
What he said!
Crist
AMA 482497
Waxahachie, TX
« Reply #44 on: March 22, 2008, 05:53:41 PM »
Okay fellows who going to put me up when the wife finds out.  Just completed my order for one of the engines.  Now with the patience I have can I make it to May?  DOC Holliday
Offline the original Steve Smith
  • Fly Stunt!
« Reply #45 on: March 22, 2008, 11:05:45 PM »
Ok, leap of faith - I just ordered one.  Figured I could put it on one of the two F-Twisters I got in the pipeline.
Probably can slip $80 under her nose on the cc if you know what I mean!   y1
I'll report when I get it and try it out.
AMA 2112
« Reply #46 on: March 23, 2008, 01:24:19 AM »
Darn it! Couldn't help myself. Got my name on one too.
Offline Richard Grogan
« Reply #47 on: March 23, 2008, 02:09:49 PM »
Dave,
I bought an RC version from my LHS for 40 bucks, never been run. Any idea when the venturi's will be listed on the parts list? I think a FP tounge will fit this bolt-on size..I was going to make a delrin venturi for it, but I like the looks of the blue anodyzed one shown here.BTW...did you count how many head shims come on the CL version?The RC version seems to have really high compression, so I had my LHS order me some extras..
And to think there were some naysayers saying it couldn't/shouldn't be done with this engine when I considered modifying it! Ha!!
 LL~
Long Live the CL Crowd!
                  AMA 85745
Offline Garf
    • Hangar Flying
« Reply #48 on: March 23, 2008, 03:30:11 PM »
Another engine. The last thing I need is another engine. The more I hear about this one, the more I want one. This one won't drop into any model I have. The Tutor II would have been a good choice, but that one is gone. What ARF would be a good match for this one?
  • High Desert Flier
« Reply #49 on: March 23, 2008, 03:46:36 PM »
Don't do ARF's but seen 'em all, flown some of 'em so here goes:
Clearly: Nobler, Smoothie, P-40, Vector 40, Sig Primary Force, Oriental
*Argueably: Cardinal, Pathfinder
*Fine IMHO, opinions may differ  H^^
Did I miss any?
« Last Edit: March 23, 2008, 05:13:50 PM by Pete Cunha »
Pete Cunha
Sacramento CA.
AMA 57499
