  • July 05, 2025, 08:10:43 AM
Author Topic: Ukey Build Part 2  (Read 3643 times)
Offline Tom Dugan
Ukey Build Part 2
« on: June 03, 2006, 11:41:34 AM »
The inside of each wing core is marked as inboard and outboard.
3.  The cores are mounted to the fuselage by the 3 wood dowels on each side.  The cores are already drilled for the, so the wing halves slide right on.
4.  The elevator uses a clevis with a threaded control horn for adjustment.
