  • June 16, 2025, 01:30:09 PM
Author Topic: On-Line Class (PHOTO'S)  (Read 3804 times)
« on: April 07, 2006, 01:11:33 PM »
Hello
If  anyone  has  questions  about what they see on the plans, or  any other  questions  please  feel free to ask.
Either Robert or myself will be  happy to try to answer  for  you.
I have all the horns  bellcranks  etc  for most  all airplanes.
THe controls setup is  critical for  best performance
Let me know If I can help
the controls ratio we  use  is  1.25 inches to the  flap horn, then either 1 inch to 1inch  or  3/4 to 3/4
Basic Material list
1-  plan  for the plane your building...let Randy know  which one
1- large pack GP  arrow hinges
2 3\8 x 1\2 inch Maple MM x 12
2-1\8 x3x 37   inch balsa
2-1\8 x3x 18 balsa
1-1\8 inch hard balsa
1- 1\4 inch hard  balsa
16-1\16 x 3 x 36 balsa
1-1\2 x 3 x 36
2-1 in x 3 x 36
1-3\16 for stringers
3 -1\4 x 3 x36
3-3\8 x 3 x 36
1-plywood 1\8 inch lite ply
1-small piece 1\16  plywood
1-pair 2 inch lite wheel
1-3\4 inch tail wheel
1-4.5 ounce uniflow tank
1-Motor  32  to  46  Magnum 36, Aero Tiger Brodak 40, LA or FP 40-46,etc.
1-Landing gear  dural or  CF 40 size
1-set axels
1-4 inch hd lite  Bellcrank
1-lead out  guide
Lead outs
Push rods set
1- pair HD 3 \32 horns
1- 1  3\4 in NN  Aero Spinner
1-ft yard cf mat
4-40 bolts and blind nuts
1-1\16 piano wire
1- 3\32  piano wire
1- set SLOW  cure  epoxy
1-tip weight  box
1- canopy  for the plane you build
Solder gun
1-3\32  wheel  collars
1-3 1\8  wheel collar
Wheel pants
Randy Smith
980 Winnbrook Dr.
Dacula, GA. 30019
1-678-407-9376
randyaero@msn.com
www.aeroproduct.net
You will also need sandpaper of various grits. 40-2000
« Last Edit: May 15, 2006, 10:27:36 PM by Robert Storick »
Online RC Storick
« Reply #1 on: May 14, 2006, 10:09:13 AM »
Today I called Randy Smith and told him of my intentions. I am going to build a different plane than planned however the build is the same so follow along.
Photos here are of the plans for my new plane. Kinda like plans on a napkin. I am building a USA 1 look alike just like Randy Powell did with a few changes. First I ordered a new PA.75. It will have Smith-Werwage-Hunt Aerodynamics. The plan form is to build a jet look and have up-dated performance. Numbers are 9.5 nose 18 tail. 61 inch span with 3/4 asymmetry, swept back tips Just like the SV Series. 24% elevator. Geo-Bolt airfoil. I will be using a foam wing however I will show how I do a built up one for the class. (stack sanding) I am also going to mold allot of parts and show how YOU can mold too!
The bench is clear and I am cutting the first wood. So about 3:00 central time look for some photos to show up. I will answer all questions However only look for this build to take a month to complete including finish. If it takes that long I will be amazed!
First photo are my plans. Second shot is truing up the top of the fuse sides and finally the last shot is the sides cut. I will now assemble the crutch and work on bulkheads. Then on to a mold buck for top and bottom blocks.
For the fuse side I tack glue them together and sand to exact shape. That way when you put them in the JIG there is no fumbling around.
« Last Edit: May 15, 2006, 10:29:12 PM by Robert Storick »
Online RC Storick
« Reply #2 on: May 14, 2006, 04:07:04 PM »
More photos. The CF vial is .05 and is sandwiched between the fuse sides and doublers. Use slow set Epoxy and as seen in the second shot heavy weight till its cured.
After doublers are dry,inset the cowl mounting pads as shown.
Next you should have your building board with a center line. Make a mark on all the bulkheads in the center. Line up on center line and add fise sides as shown.
« Last Edit: May 15, 2006, 10:28:54 PM by Robert Storick »
Online RC Storick
« Reply #3 on: May 15, 2006, 02:40:15 PM »
I have decided to carve instead of mold (for speed) I am going to try to have this ready for the NATS. I probably won't fly it but I will bring it if its done.
This where I'm at where are you?
I am as far as I can go until I get an engine on the fuse. So Hopefully I get it at weeks end. I will assemble the wings and stab-ele. Should go quick. Notice the TRICK Brett Buck bell crank?
We are 24 hrs into this project. Any questions?
« Last Edit: May 15, 2006, 10:28:31 PM by Robert Storick »
Offline sadams714441
Re: On-Line Class (PHOTO'S)
« Reply #4 on: May 16, 2006, 05:22:59 AM »
Looks Good Robert
Should have mine in the fuse jig tonight, if all goes as plan.  taking daughter to airport then back to build.
Robert do you tack glue the fuse sides and bulkheads in the jig blocks or are they just used for pressure to hold everything ?  Also is it easier to glue the stringers in before you mount the bulkheads ?  Or after ?
Steve Adams
Online RC Storick
« Reply #5 on: May 16, 2006, 06:55:27 AM »
Looks Good Robert
Glue the stringers to the sides first. Mark bulkhead local and pin in place. Use fuse blocks in jig to hold together. Only pressure holds it together. DO NOT GLUE TO BASE OR JIG BLOCKS.
Online RC Storick
« Reply #6 on: May 16, 2006, 10:54:47 AM »
36 hrs into this project I have the basic kit cut and some assembly going. Today I will show wing tips. They are done just as the plan states.
Online RC Storick
« Reply #7 on: May 16, 2006, 08:15:10 PM »
After 48 hrs it is mocked up.
Online RC Storick
Update On-Line Class (PHOTO'S)
« Reply #8 on: May 26, 2006, 08:53:04 PM »
I was checking the dates and I have been working on this project 12 days. The woodwork is done. The next thing starting tomorrow night will be finish. I will post this process. I will be covering the fuse with CF and the wings with 00 silk span. The elevators will be done in Poly-span. In Flying trim everything including tip weight (less finish) the weight as it sits here is 52 oz. I had hoped for less but this is a big airplane! So the projected weight is 60-62 oz depending on how carried away I get with the clear Urethane. I was contemplating a Blue Angels scheme but I have abandoned that idea for my old squadron colors (checkmates) VF-211. So The top of the plane will be gray and the bottom white. I will try to make an impression of a real fighter however there is no fighter of this configuration.
