CLICK HERE---->    <----CLICK HERE
Welcome, Guest. Please login or register. May 25, 2013, 08:28:44 PM
Pages: [1]   Go Down
  Print
Author Topic: Single channel use  (Read 1382 times)
Vincent Corwell
Trade Count: (0)
Commander
Rate User 1
Offline Offline
« on: May 18, 2007, 04:19:40 AM »
Can you show a complete set up please for
a single channel, say for throttle control
servo , battery , controller unit
 at the handle end , battery? controller
Is it viable to use only one insulated line and one standard line?
Is there a link to your web site please ?
Thank you
Vincent
Logged
Clancy Arnold
Moderator
Trade Count: (0)
Admiral
Rate User 2
Offline Offline
I am 5 Ft. 8 In., the Taube is 7 Ft. 4 In.
« Reply #1 on: May 19, 2007, 09:25:24 AM »
Vincent
Check your Email.  I sent you a copy of the Single Channel U/Tronics Instruction sheet.  Hope that answers your questions.
The use of one insulated and one uninsulated line would work, but I would worry about the different air drag because of the different outside diameters.
Clancy
Logged
Clancy Arnold
Indianapolis, IN   AMA 12560 LM-S
U/Tronics Control
U/Control with electronics added.
Clancy Arnold
Moderator
Trade Count: (0)
Admiral
Rate User 2
Offline Offline
« Reply #2 on: May 15, 2011, 03:42:08 PM »
Please note that the street address on the above drawing has changed.
Clancy Arnold
7174 Eagle Cove S. Dr.
Indianapolis, IN 46254
Logged
Clancy Arnold
U/Tronics Control
Tim Wescott
Trade Count: (0)
Admiral
Rate User 1
Offline Offline
« Reply #3 on: May 15, 2011, 04:08:12 PM »
I recall a post here from someone who had just that problem -- one thin line and one thick line, and an elevator that responded in a consistent (and unfortunate!) manner to changes in line tension.
Logged
John Rist
Trade Count: (0)
Admiral
Rate User 5
Offline Offline
« Reply #4 on: May 31, 2011, 01:51:57 AM »
DO NOT USE ONE INSULATED LINE - unless perhaps you are coating your own lines with polyurethane. Even in that case I would coat both.  See post
http://stunthanger.com/smf/index.php?topic=18806.0
I lost my Eindecker due to one insulated line.  When I slowed down and line tension got low the drag on the insulated up line drove the Eindecker up and over the top - BIG SPLAT!
Logged
John Rist
AMA 56277
Pages: [1]   Go Up
  Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.18 | SMF © 2013, Simple Machines
Valid XHTML 1.0! Valid CSS! Dilber MC Theme by HarzeM
