  • June 19, 2025, 10:58:38 PM
Author Topic: Pipe Length RO JETT .67 - 76  (Read 2939 times)
John Leidle
« on: May 27, 2016, 10:48:24 PM »
   I'd like everyone to put down their pipe length for their setup . I have Dave Tribles & Joe Gilbert's but I'd like more guys to post their's. So Pipe length & venturi size would be appreciated.
Re: Pipe Length RO JETT .67 - 76
« Reply #1 on: May 28, 2016, 02:37:08 AM »
I haven't run my 67 on a pipe yet so I'm a little curious for settings for that also.  My current plans for the 67 is on a header muffler in my Collossus (classic).
My 76 runs at 18.25 inches at 9600 RPM at launch with a Randy PA 75 pipe, and uses 7.25 oz of 18% nitro and 18% oil (15% Klotz and 3% Castor).   I fly at 2300 ft altitude in Tucson AZ. (Hot sometimes).  Engine runs cool.  Glow plug is Enya #3,  prop is Mejlik 13-4.25 three blade (narrow blade), 68 ft 18 thou lines.
John Leidle
« Reply #2 on: May 28, 2016, 07:58:30 AM »
    Thanks Randy.  Is the venturi  stock ?
« Reply #3 on: May 29, 2016, 02:10:56 AM »
Sorry... No it's not stock.  It's .006 larger than stock, but has one layer of panty hose over it!  I typically trim this way.  Keeps out the pebbles too!  It does not have a "spigot".  I tried that but found it temperamental to tune.  I realize a lot of the "big boys" use the spigot but it didn't seem to work on this particular engine for me.  It might have if I had spent more time fiddleing with it but I simply went back to the afore mentioned setup because it worked very well and was very easy to deal with.  I would imagine that at sea level things might be a bit different and a smaller venturi might work better.  I would mention that it regulates very well with this setup and a bit better than others that I tried without the pantyhose which probably indicates that a slightly smaller venturi coul be used even here!
Offline big ron
« Reply #4 on: May 29, 2016, 08:23:03 AM »
John could you give Dave and Joe's setups for us
John Blanchard
Brusly, Louisiana
 AMA 1054488
John Leidle
« Reply #5 on: May 30, 2016, 12:12:41 AM »
  Ron , this is the info I  recieved from the afore mentioned users,,, if I write something that is false I only wrote what info I recieved,   Joe sets his .76 up with a .205 venturi & the pipe is set to 19.25"  Dave has a .205 venturi & the pipe is set at 21.5".
Offline big ron
« Reply #6 on: May 30, 2016, 07:00:33 AM »
Thanks just looking for info on how long to make the tunnel to pipe don't want to not leave enough
John Blanchard
Brusly, Louisiana
 AMA 1054488
« Reply #7 on: May 30, 2016, 09:01:52 AM »
Hi John.  A little difference,  Joe uses the .67, and I the .76.  I get a two inch pipe difference between the .61 and the .76- using the same prop and roughly the same RPM.  The pipe for the .76 is also larger in diameter.
« Last Edit: May 30, 2016, 09:24:32 AM by Dave_Trible »
Offline big ron
« Reply #8 on: May 30, 2016, 05:14:30 PM »
I'm gonna be using the 67 thanks for the info
John Blanchard
Brusly, Louisiana
 AMA 1054488
