I am pleased to inform that the problem with the Black Tiger 4250C combo has been solved.
Firstly, I have to apologize to Eric Rule (RSM Distribution) for doubting the quality of his stuff.
It was my mistake to use the wrong Power/Weight parameter and, consequently, to expect about 40% more power from the electric setup.
The Power/Weight parameter I used in my calculations and initial sizing of my next three electric planes was 11 Watts/oz. (176W/lbs).
(ref:
http://www.wattflyer.com/forums/showthread.php?t=24238)
At the time I discovered this number, and it was about three months ago, I knew very little about electric C/L flight and 11 Watts/oz seemed reasonable while expecting "the unlimited 3D aerobatics" including the drag effect of the lines.
Since August 2015, I have learned a lot and gathered practical experience flying my experimental paper and foam Little Great White (LGW) with Cobra 2808/22.
I have also purchased new engines and electric motors and the complete electronics package to check and test whatever requires checking and testing.
Purchase of the Black Tiger 4250C with the rest of the 61-74 class combo from RSM Distribution was the last step to be properly equipped before "building and basement life" season ( alternate name: winter) in Toronto.
I would like to thank many people who shared their electric setup data with me but special thank you goes to Chris Behm and Keith Renecle who provided their Power/Weight parameters.
The low number is 101 Watts/lbs (6.3125 Watts/oz.), the high one - 130 Watts/lbs. ( 8.125 Watts/oz.).
Now, I can easily match my electric motors to batteries and future planes.
Two static tests today using Black Tiger 4250C with 5S 2600mAh 30C battery, 13x4.5 APCE pusher, 60Amps ESC and KR Governor.
Initial voltage = 21.00 Volts
RPM = 9430 - 9450
Static current = 28.8 - 26.7 A.
Comment: using my "Law of 3/4",
the average in-flight current of whatever is flying C/L stunt will be 0.75-0.80 of the static current, in this case 21.6 to 23.04 Amps and 20 to 21.36 Amps.
I feel the 0.75-0.80 is a constant of the electric stunt.Time of run achieved: 5.0 minutes with proper warning in the end.
Battery capacity used: 2350 MAh ( 90%) - a little high.
Black Tiger 4250C electric setup above will competitively fly any stunt plane having 59-60 " wings span, 630-700 sq. inch. wings and flaps area and RTF weight 59-64 oz.
Matt
