  • April 26, 2024, 09:13:22 PM
Author Topic: Sig Twister wing kit  (Read 1828 times)
« on: October 06, 2015, 04:45:25 PM »
Does Sig still offer the wing kit for the Twister.  I could not find it on their web site....???  I know that cutting ribs for the Twister is a simple procedure, but I would really like to get the wing kit.
Thanks!
Offline Dane Martin
  • heli pilot BHOR
Re: Sig Twister wing kit
« Reply #1 on: October 06, 2015, 05:16:26 PM »
I'm pretty sure they do but you have to call them. I got a banshee wing kit that was not listed also. They said the planes are still in production, so they will have parts.
« Reply #2 on: October 06, 2015, 05:31:19 PM »
Thanks for the info, Dane!  A call it is ;D
Offline Ara Dedekian
  • Ara Dedekian
« Reply #4 on: October 06, 2015, 07:55:02 PM »
        I ordered the wing kit listed in Steve's reply. All balsa and lite ply are provided but no hardware or instructions.
     Ara
Offline Ward Van Duzer
« Reply #5 on: October 07, 2015, 08:47:42 AM »
Bill,
Don't know what you're intending to do with the Twister wing, But personally I feel the Chipmonk wing is a better wing to work with. This was used by MANY folks during the 50's and 60's for those Nobler look-alikes! If you recall my last disaster at the Criterium, My profile piped force was built around the Chip wing. Per instructions (and plans) from Unca Mikey. Was still available a couple of months ago...
Ward
« Reply #6 on: October 07, 2015, 01:42:18 PM »
The Twister wing is a better wing to crash with, at least if you want to repair afterwards.
Just sayin', because I don't know what Bill's cooking up.
« Reply #7 on: October 11, 2015, 08:42:25 PM »
Hi All,
I have never built a Fancherized Twister.  As I am basically starting all over after my cancer, I want a simple to build, easy to repair profile to get back in to it.  What I don't know yet is if I will use a .46LA on it. ;D
The planes I had under construction are not suitable for what I want right now.  I have several "Hi-Zoot" stunters near completion but I do not want to begin back with models that I have put a LOT of work into.  I need something I can dink this weekend and have flying again the next.  Don't PLAN on crashing but I feel pretty sure it will happen until I get my "sea legs" back! LOL!!
« Reply #8 on: October 11, 2015, 08:49:14 PM »
Bill, that sounds like a good plan.  I can't vouch for the difference between a regular ol' Twister and a Fancherized one, but my Fancherized Twister has taken me all the way from the middle of Intermediate to the bottom of Expert, so it can't be that bad of a plane.  Mine's heavy at 53 ounces, and flies quite well with a 46LA -- you could do worse in your choice of engine.
« Reply #9 on: October 12, 2015, 05:34:02 AM »
Thanks, Tim.  I have about any engine you could think of but I like the idea of the .46LA.  So simple to run and plenty of power to get the job done on that size airframe.  I feel pretty confident I can bring it in well under 53 ounces. ;D  The idea of re-learning with full blown stunt ships just isn't appealing right now, I don't need anything to give me a fear of the ground now.  I don't fly much over pavement so when i do plant it, it should be quickly repairable.  Will let everyone know when it gets started!  And when I have my first flights.........
