Here's one from Larry Renger, and if I can locate it, one from Nils Norling...
"Zingers are exellent prop kits. Good wood and lots of it to work with. The key changes are to add undercamber and Phillips entry (a bit of upcurve on the underside below the leading edge), a ROUNDED leading edge, a thin trailing edge, move the high-point of the airfoil to 33% from the 45 or 50% position that is provided, and thin the blades. Basically, you are taking a propellor blank and airfoiling it with a good, low Reynolds Number airfoil.
If you are using a big spinner, it is easier, as you have little work to do at the hub. Otherwise, you have a LOT of work to do at the hub.
First off, I work the underside of the prop. I draw a circle on top and bottom of the hub to give me reference for how far in I need to re-contour. Then, I rework the hub area to match a helical surface in as far as the circle with a nice smooth fillet to lead in from the hub to the blade bottom.
Next, I draw a line at about 10% chord from the leading edge, and then lightly bevel that part upwards about 5 degrees. Just enough to see. Now the magic part! If you angle a cutter (I use those Tungsten Carbide round rods you can get from Micro-Mark) outward from leading edge to trailing edge about 45 deg, it will automatically cut in undercamber. I actually start at 30 deg at the root and end at 60 deg at the tip, but who'se counting.
You should see the center of the blade get cut first, and then the cut area extend from your new leading edge contour to the extreme trailing edge. At this point, I will sand the bottom smooth and blend in the undercamber to the new leading edge upsweep. This gives you a good base for your next step.
Now it is time to thin the blade. I mark 1/2" stations, and on a 10x4 prop, start at about .200 and taper evenly to .060 at the tip. I suppose one should compensate for the increase of chord toward the middle of the blade, but I don't. The thickness must, of course match the bottom surface of the blade, I use a caliper which gives me a good flat reference to the bottom.
OK. Now, draw lines on the top at the 1/3 chord and 1/2 chord position all the way out. Start hogging away at the rear section of the blade to give you a very thin trailing edge (.015 or so) and a flat surface to the 50% chord line.
From here on, use a point-source light, and your eyeballs to shape a nice airfoil everywhere. Add your choice of tips (I like Hoerner {Flite-Streak} tips), sand smooth and balance the prop. I have the Top Flite Magnetic balancer, but tossed out that plastic junk hub. I got the nice machined balance hub from Great planes, and use it in the magnets. Superb!
Finally, I give a couple of coats of Urethane spray varnish, recheck the balance, and then I have a real gem of a prop.
Larry Renger
think S.M.A.L.L."
"NilsN
Member
USA
posted March 18, 2002 12:49 AM
Reworking props can make an amazing difference in the performance of a stunt ship.
Due to easy availability I use Zinger "kits" for prop blanks too. I do have one *very
important* suggestion- if you are going to be reworking props, by all means get a pitch
gauge first so you can see what you're doing when you start sanding on your props!
I usually start with an oversize prop & trim it. I use a razor saw to get the blades close,
then use my disc sander to get the final length. The saw makes tiny rips in the wood &
the sander removes them.
I use a 1/2" X 1" stick about ten inches long with a quarter inch dowel glued through one
end to check length. I put the dowel through the hole in the prop & turn the prop end to
end to make sure the blades are the same length measured against marks I've made on
the stick. I have it marked for props from 10" out to 13" in quarter inch increments.
Next I set the pitch to what I want by sanding the back of the blades with 150 grit
Stickit paper on a home made styrofoam sanding block. I have found it to be true that an
extra quarter inch of pitch at the tips makes for more line tension up above. I don't know
why, but it does. For instance my ST.46 on my profile Cardinal likes 12-5 Zingers cut to
11 1/2" & repitched to 5.75 on the main blades with 6.0 at the outer 3 stations (about
3/4").
I only undercamber props when I want to load the engine a little more for a given pitch.
After I get the pitch I want I start sanding the front of the blades to move the high point
forward to about 30%. I count the strokes I make on one side & then give the other
blade the same until I get them thinned & shaped the way I want them. I like my props
fairly thin & the edges semi sharp. There is a lot of meat on a Zinger especially on the
trailing edge & I get rid of most of it. I take wood off of the high point of the factory
airfoil (which is about in the middle of the blade front to rear, usually) when I move the
high point forward, so the entire blade is thinner. Generally they come out very close to
the same when I put them on the balancer.
I should point out that I've been sanding bondo for 33 years, so I'm fairly handy with a
sanding block, your results may vary.
Something I have found after checking dozens & dozens of them, is that very few wood
props are actually pitched at what they are marked. Some are off a little & some are off
a lot! Some are off the same on each blade & some are off up to an inch (or more!) from
side to side. Therefore, just because your airplane worked great with an 11-5 Zinger (for
instance) once, doesn't necessarily mean it will work well with another 11-5 Zinger after
you bust the one you've been using. They could be quite different.
Another thing I've found is that it's easier to pitch a prop "up" than it is to pitch it
"down", i.e.: if you want to make a 5 pitch prop, it's much easier to start with a 4 & sand
the back of the leading edge than to start with a 6 & try to take all that meat of the
rear trailing edge. Generally taking that much off the trailing edge will change the overall
outline of the blade by the time you get what you're after as well.
Note to Currell- to make a Phillips entry on your prop you sand a bit of taper on the
"back" of the leading edge, in effect upping the pitch slightly. Say you have a prop that's
working pretty well but you want a little faster lap time, sand a little Phillips entry into it.
(Conversly, if you want to slow it down a tad, sand in some undercamber to load the
engine a bit.) The pitch is determined by a line from the very front of the blade to the
rear, sanding the back of the leading edge moves the effective leading edge increasing
pitch.
Hmm, I'm not sure I'm explaining this very well. Maybe it would help if you imagined
changing a flat bottom wing to a semi-symmetrical by removing some of the lower leading
edge. I hope that makes it a bit more clear.
Btw, I learned a lot of this prop twiddling business from watching several of Windy's
videos. The rest I learned by quizzing the guys flying Expert & trial & error.
I haven't tried CF props yet, but I'm looking forward to it.
Fooling with props is time very well spent, it can really make a huge difference in
performance.
I hope I've been of some help.
Nils"
